Understanding Single Particle Interference in Quantum Physics
In summary: RegardsmarlonIn summary, the conversation discusses the confusion around understanding quantum physics, specifically in regards to the double slit experiment and the interference pattern formed by a single photon being sent through the slits. The conversation also touches on the concept of wave-particle duality and the statistical interpretation of Quantum Mechanics. One person suggests stepping back and dropping the assumption that QM applies to any single particle, while another disagrees and provides a reference to support their claim.
Smiley10
Believe it or not I'm having trouble understanding quantum physics. If we take the double slit experiment and one photon is sent through the slits at a time an interference pattern is formed. From what I've read the particle goes through both slits and interferes with itself. Now when it says interfere is it taking in a general sense or does it mean that the particle will hit itself to interfere with itself?
I also don't understand why we just assume that the particle is going through both slits and then interferes with itself. It's just as crazy to say that the particle is only going through one slit and then takes two directions at the same time hitting different positions on the screen which just so happen to cause an interference pattern. I think the attitude quantum physics takes that it can't be proved wrong so it must be right type of attitude is very poor. If we can't measure the state that the particle is in then we should only conclude that it makes an interference pattern but we shouldn't start pretending that we know what is happening to the particle before it hits the screen.
I hope you can at least clear a little bit of my confusion. Thanks in advance.
Likes Jsauce
You have to stop thinking about the electrons and photons as particles. They are quantum particles, and exhibit both wave like and particle like properties, and this enables them to interfere with each other like in the double slit exp.
Quantum physics does not try to say anything about what happens to the particles before they hit the screen, because this is what quantum physics is all about! In the double slit experiment we cannot say anything about which slit the particle went through, and still have an interference pattern on the screen. If we make a measurement and determine which slit the particle went through, the wave-particle duality is determined (to be a particle, because we know it's position at some instance) and an interference pattern will no longer form.
The way out might be to step back and drop the assumption that QM applies to any single
particle. QM certainly applies to an ensemble of identically prepared particles for it gives
excellent predictions for probabilities (many repetitions of the same experiment). At the same time QM cannot predict where exactly a single photon in the double slit experiment will hit the screen.
This attitude is called the statistical interpretation of Quantum Mechanics. The wave
function there describes ensembles of identically prepared quantum objects and not
an individual quantum object.
The theory of single quantum objects is still to be discovered.
Good question, anyway!
Cheers!
particle.
Ofcourse QM applies to any single particle at the atomic scale. What are you saying ?
So ? What is that supposed to mean ?
ANY "attidude" of QM should NOT contradict with it's basic fundaments.
Cheers!
Oooh, no, is this the single particle stuff again ? I already explained you why you were WRONG making such claims.
http://www.cs.caltech.edu/~westside/quantum-intro.html . Read the second and third paragraph on the Quantum Computer. You might actually read the very opposite of what you have been saying in this and the other thread with respect to a particle's self interference/interaction.
Greets
marlon
You are barking on the wrong tree. I am not interested in your opinion anymore.
Good luck!
Good luck!
Thanks for the mature answer but we have an obligation to correct mistakes. Otherwise this forum is not what it should be. Both Reilly and myself have asked you specific questions and clarifications in the "Statistical interpretation" thread to which you never answered. Both of us have explained you where you are making mistakes. Again, i have given you a CalTech reference where you can read the exact opposite of what you are claiming.
To be clear, you need to stop selling stuff that violates the very fundaments of physics. Such behaviour will not remain unnoticed, i assure you.
regards
marlon
Smiley10:” Believe it or not I'm having trouble understanding quantum physics.”
Read R. Feynman Lectures. If you still do not understand, leave quantum physics.There are plenty interesting problems in other areas.
LOL
Err, there is one problem though...Most of the physics area's that have direct applications to today's industry are based upon QM (semiconductors, electronics in general, spintronics, photonics, etc etc). So the OP really needs to understand what is going on.
TO THE OP : http://www.cs.caltech.edu/~westside/quantum-intro.html
Greets
marlon
Or, to quote the same Feynman: "nobody understands quantum mechanics" :biggrin:
What kind of advice is that? Did you hear it from some one yourself?
If you think you understand QM then this place is just made for you to share this blessing.
Cheers!
Thanks for the replies everyone.
This does make a lot of sense and if I didn't have the answers to my questions I'd be satisfied with that. But I still can't help being curious about how the particle side of light could work (or even if it's possible to work).
From the link that Marlon gave it's reasonable from the experiment to assume that the particle can in fact be in two different places at the same time, at least as long as the detectors are in fact detecting a single photon since I don't think this is mentioned. The photon does seem to take a random path but where the photon hits the screen isn't completely random. We know that a photon will never hit the dark spots. But still the photons appear to take a random path so at some point the photon must be heading at this direction of the dark spot so the photon must somehow be interferred. Now at this point I haven't got a clue what the hell interferes with the particle. I've read that the photon interferes with itself but this sounds pretty crazy. What appears to be two photons in fact isn't they're the same matter so it just doesn't seem right that when the same matter hits together that momentum will be transferred (or will it?).
I'm not entirely sure on the photon taking a completely random path and I'll have a read up on hidden variables, bell's theorem etc.
I haven't read the lectures but I'll have a look at them and I'm glad that someone caught onto my very subtle joke in the first sentance of my first post.
Thanks again, at this point I'm just making discussions and I believe I have a good enough understanding to write about it in my coursework :wink: . Feel free to keep the thread going.
Given more opportunities like this thread, Marlon and I might write identical posts, or, more likely, ones that say much the same thing.
Now, one of the reasons that QM is difficult to grasp -- weird, contradictory, "shut up and compute", "but we really don't understand it" -- is that the phenomena that led to QM are strange, weird -- blackbody radiation, photoelectric effect, atomic spectra, electron and neutron diffraction, pair production, spin, and on and on.
For the double slit business, first review basic probability, preferably discussed in terms of events. That will cure you of any concerns about predictions of single events. For all practical purposes, the theory of electromagnetic wave diffraction and electron diffraction are very similar -- the diffraction occurs primarily from restriction of the impinging wavefront, just like Huygens told us a few years back.
Interfere with itself? In my view, that's a personal choice. In fact, given the broader behavior of waves governed by Maxwell or Schrodinger, I see no good reason to formulate such a controversial notion. It only serves to muddy and confuse something that is basically straightforward, provided you accept that the phenomena of particle diffraction does occur . Then the point is to accept reality and figure out a theory that can explain how such diffraction occurs. QM does just that, and has done so for almost a century. Also, contrary to some contentions that have appeared in this forum, the vast majority of physicists accept QM -- albeit sometimes in different flavors.
As Dorothy said, "Toto, we're not in Kansas anymore."
Regards,
Reilly Atkinson
Vanesch:” Or, to quote the same Feynman: "nobody understands quantum mechanics".
You are right. But I don’t know what he meant: everything in QM or QED only.
Marlon:” Most of the physics area's that have direct applications to today's industry are based upon QM (semiconductors, electronics in general, spintronics, photonics, etc etc).”
If he going to be engineer, why he need understanding?
Zbyszek:” What kind of advice is that? Did you hear it from some one yourself?”
Smiley10:” I haven't read the lectures but I'll have a look at them and I'm glad that someone caught onto my very subtle joke in the first sentance of my first post.”
What is the matter with you? Jokes are forbidden?
You react with anger on my criticism of L.E. Ballentine. Is he your close relative? Before you wildly attack S.L.Adler (without justification).
You like Ballentine version of statistical interpretation? I never said that it is not legitimate (as well as other interpretations).
The situation is the following: in "ordinary" QM, the formalism is entirely understood ; in quantum field theories (such as QED), even the formalism is not entirely understood, but well enough to do some calculations. In other words, we know that the calculations that are done, are mathematically somehow unsound, but this can be explained away by saying that it must be an approximation to something else (effective field theories).
But Feynman wasn't talking about the formalism, he was talking about the "physical meaning". This is what is not understood, although several attempts with varying degrees of success have been invented. Nobody really knows what the mathematical objects in a quantum theory actually represent.
Some claim that it is just a mathematical tool which gives you statistical outcomes of experiments (in other words, that one shouldn't look for any physical meaning) - fine, but they can't come up with an explicit underlying physical mechanism ! Some (Bohr, with Copenhagen) claim that there IS no explicit physical mechanism, that all there is, is "statistics". This is essentially the "standard" Copenhagen interpretation: the quantum-mechanical formalism links statistically setups and outcomes of a "classical" macroscopic world, and there is no underlying explanation for this link. The formalism of quantum mechanics simply allows you to calculate the probabilities, but doesn't represent anything physical, because there IS nothing physical at that scale.
Others (such as me) claim that the formalism of quantum theory is to be taken seriously, and that it represents genuine physical quantities. These views are "many worlds" views, because you cannot avoid that way, to make a distinction between "the physical state" and "observed reality by an observer", which is so terribly weird.
Others think that the quantum formalism has something real to it, but that there is also an explicit "projection" mechanism. However, this usually introduces some clashes with relativity.
Still others think that there's something fundamentally wrong with the quantum formalism, although it makes correct predictions in many cases, for an ununderstood reason.
This is a discussion that goes on now for almost 80 years, and is usually referred to as the "measurement problem" of quantum theory. However, and that is the nice part: you don't need to think about all this to get the formalism working in practical cases, and in any case, it is a good idea to learn very well the formalism before delving into these issues.
So, the practical attitude to adopt when learning the formalism of quantum theory, is simply this: "quantum theory is a mathematical model which allows you to generate statistical predictions for outcomes of experiment, but for which no evident physical interpretation is known." From the moment that you try to do so, you delve into the problems of the measurement problem, which haven't really been resolved since about 80 years. This is what Feynman meant.
Is this another joke of yours? I have hard time telling whether you are joking or lying.
For those who would like to check on the moral integrity or the sense of humor (pick one)
of Anonym please read post #111 under the wave packet description thread
https://www.physicsforums.com/showthread.php?t=142399&page=8"
I believe I have provided quite detailed justification.
If this is going to turn into a flame war, then this thread will be locked and warning points issued.
Do I have a right to defend my reputation on this forum? You see, attacking somebody's
work without justification is one of the lowest things a scientist can do. I am being accussed
of doing just that.
Is it a flame war for you, vanesch? In this world, I mean.
Cheers!
The informal warning was not only directed at you, be reassured. Try to argument your position in a neutral way, or just don't argue, but try to avoid remarks of a personal nature which might trigger other remarks of the same kind and result in a silly flame war which is interesting for nobody to read. This counts for all of the antagonists. Let's keep it level-headed here...
Reilly:” Marlon and I might write identical posts, or, more likely, ones that say much the same thing.”
“Interfere with itself? In my view, that's a personal choice. In fact, given the broader behavior of waves governed by Maxwell or Schrodinger, I see no good reason to formulate such a controversial notion.”
Marlon:”Particles, in QM, ALWAYS exhibit wavelike properties : THAT IS THE ENTIRE POINT OF THE DUALITY. This duality does NOT give us an "either wave or either particle like" picture.’
“Self interaction IS an essential part of QM.”
“But i just want to be clear here : the particle/wave duality does NOT say that particles are waves or something like that. this duality just states that at the atomic scale, particles exhibit wavelike behaviour like in the double slit experiment. This ALWAYS happens for each kind of particle like electrons photons, etc etc. Wavelike behaviour is a general term that denotes all the types of interference, diffraction, etc etc...
We need this duality because we look at QM through "classical eyes".”
I identify the opposite points of view.
Smiley10:” I've read that the photon interferes with itself but this sounds pretty crazy.”
Otherwise you should to accept that a single particle may do statistic with itself.
Make your choice what is more crazy.
In the double slit the photon/electron wavefront hit the lossless beamsplitter simultaneously. The lossless beamsplitter is the macroscopic device which do not perform the measurement. No violation of the special relativity take place. Each slit may be considered as Huygens secondary source as usual. The measurement performed at the detector screen (the macroscopic device) cannot produce two outcomes simultaneously. It require the collapse of the wave packet in time, otherwise the requirements of special relativity will be violated (A. Einstein,1928).
In addition, the macroscopic physics is the theory of certain events. Translation into the language of the functional analysis say: the classical physics is a dispersion free physical theory (J. von Neumann in Foundations for example). It require the collapse of the wave packet in space.
You may see more detailed discussion in the wave packet description session with Ueit,Reilly and Zbyszek. But you should read Feynman (at least double slit and Stern-Gerlach) before.
strangely aggresive thread over something fundamental to understanding QM. haven't these issues been thrashed out already?
maybe we should all "shut up and calculate", which i take to mean try and understand better the mathematical models
Vanesch:” But Feynman wasn't talking… This is what Feynman meant.”
I agree with everything you wrote.
Vanesch:” The situation is the following: in "ordinary" QM, the formalism is entirely understood ; in quantum field theories (such as QED), even the formalism is not entirely understood, but well enough to do some calculations. In other words, we know that the calculations that are done, are mathematically somehow unsound, but this can be explained away by saying that it must be an approximation to something else (effective field theories).”
But let me joke. R.P. Feynman received nobel prize in physics for QED.
I don't exactly know what you mean but if you are implying that Reilly and myself are saying the opposite, you are wrong. You can clearly read that we are saying the same story. Indeed one can debate the concept of "self interference" but that does NOT imply this behaviour is NOT exhibited by particles. IT DOES EXIST and if you read the CalTech link i provided in this thread, you will see that this concept is directly related to (ie the same as) "superposition". For example, the qubit being a superposition of "on" and "off" states. The first and primarily second photon experiment in the link shows just THAT (ie quantum interference).
Also, keep in mind that noth of us were debating the content of zbyszek's posts (like the stuff on preparing the electron ensemble for the double slit experiment).
Do you actually know what electronic engineers have to study ? How on Earth could you explain the band diagram of a MOSFET if one does not have some basic knowledge of QM (like the concept of superposition that we are talking about here).
marlon
Marlon:” I don't exactly know what you mean but if you are implying that Reilly and myself are saying the opposite, you are wrong.”
Sorry for misinterpretation. I took your words literally.
Marlon:” Do you actually know what electronic engineers have to study ?”
No. I spent several years working with electronic engineers which produce amazingly complicated and amazingly successful projects using pretty funny understanding of basic physics. In addition, guys, what do you have against jokes?
But that is my point. Ofcourse you should take my words literally and i still don't get where you see a contradiction. Reilly is NOT saying that the behaviour of particles denoted by self interference does NOT exist.
Indeed, in college these guys are always introduced to the basics of QM to say the least.
LOL
Nothing, but we just need to be certain we are not talking "next to each other", that's all.
Greets marlon
Zbyszek:” You see, attacking somebody's work without justification is one of the lowest things a scientist can do. I am being accussed of doing just that.”
I did not accussed you in any crime. I consider your post #111 under the wave packet description only misreading and misiterpretation:
Zbyszek:”You list the postulates of QM. All of them, but last, after Ballentine. The last one is the "measurement" postulate Eq.(14). Right after that you claim that everybody agrees with the list.”
“If you read Ballentains work more cerfully you would see that your last postulate is certainly not a part of the statistical approach to QM.”
S.L. Adler wrote:”Let us begin with a review of the postulates of QM, in the arena of a complex Hilbert space, following for the larger part the presentation of Ballentine.”
S.L. Adler wrote:”While everyone agrees that the above postulates provide a practical set of rules for making predictions in quantum mechanics, and that these predictions to date have always agreed with experiment…”
Zbyszek:”In your work, you give wrong description of Ballentine's paper (section 1.2), you logic is questionable in the Recapitulation (section 1.6) when it comes to the two alternatives A and B (you conveniently forget that neither A or B captures the results from Ballentine's work). Namely, there is also C: QM is exact, no need for any reinterpretation, remove the postulate you have added to the Ballentine's list.”
S.L. Adler wrote:”According to this interpretation (Ballentine), (14) corresponds to the preparation of a new ensemble by the measurement. There may be, or there may not be , hidden variables that specify a complete, nonstatistical interpretation of individual systems: the statistical interpretation is agnostic with respect to this issue.”
In addition, Adler’s work devoted to the completely different issue.
S.L. Adler wrote:”This survey focuses particularly on the issue of whether probabilities in quantum mechanics are postulated or emergent.”
Compare with E. Schrödinger, Ann. Physik,82,186 (1927).
I find it helps to think of it this way:
Imagine lightning. You know how, before the visible lighting bolt strikes, the phenomenon first finds the path of least resistance; and once that path has been carved out in the atmosphere between the two charges, the bolt slams down that path.
So now imagine that a photon has been created, and before it starts to travel you stop time. With time stopped, all of the photon's possible paths are carved out in front of it. Imagine each of these paths as if they were independent photons. Now some of these paths are going to interfere with each other.
Now start up time again. The photon is going to travel down one of these paths. If it's one of the paths that interfered with another potential path, it's going to look as if the photon interfered with itself. Not because it actually did, but because the potential path it followed had already interfered with another potential path.
I'm not saying this is really what happens, I'm just saying it's an analogy that helps me understand the outcome.
This is pretty close to Bohmian Mechanics (maybe you didn't realize this...)
Great post; I have read a seminar of Anthony zee once where he uses almost the very same formulation.
Again, here it is very clear that the interference (between paths) is a property inherent to one single particle, giving rise to the superposition of paths or even the entire path integral basis (ie summation over all possible paths to acquire the action etc etc).
greets
marlon
I've seen this question come up a lot, and I think the problem is that people still want to stick to their classical pictures of "waves and particles" that we can understand from our personal experiences. "Quantum particles" have properties of both classical waves and classical particles, but don't they also have properties which neither have (the statistical interperation, uncertainy principle, etc)? I tend to not try and think about "quantum particles" with classical ideas, and simply call them "wavicles" that have their own properties, some of which classical waves and particles have. I feel like people just really need to stop thinking of "wave-particle duality" with a classical viewpoint, since quantum particles have properties which neither common to classical waves or particles. Is there anything wrong with what I'm saying?
  • #31
Marlon:” But that is my point. Of course you should take my words literally and i still don't get where you see a contradiction.”
Compare with Reilly under the wave packet description:
“Here's a simple fact: in this real world of ours we can't predict anything with certainty. Measurement error is a fact of Nature. Thus everything is uncertain, to a greater or lesser degree. Brownian motion occurs in 'classical systems'. That means, of course, that there is no theory of certain events.
That's why we use in experiments the largest sample possible so as to get info about the distribution of measurements with as much accuracy as possible”.
“So, if that's so, why do you single out QM for having a problem that is virtually a universal one?”
“After spending time moving lead bricks around for shielding for electron scattering experiments, and working extensively with data from such experiments, I'll claim that the measurements don't know from quantum or classical. It's all in the eye of the beholder. Perhaps it's not quite a mantra, but "experiments are experiments", and "propagation of errors is propagation of errors." There's nothing quite like computing or measuring the 5th decimal place; tends to make one practical.”
Here Reilly discuss three unrelated problems:
1.Whether statistics in quantum mechanics are emergent and how.
2.What is the purpose of the theoretical description ( For me if I know experimental result and perform computing to obtain it without additional information (understanding=modulation) , the information rate=0 and there is nothing to communicate).
3.Whether the classical physics is “theory of certain events”.
“I'll claim that the measurements don't know from quantum or classical. It's all in the eye of the beholder”.
Compare:” we look at QM through "classical eyes".
The macroscopic physics are the theory of certain events. Translation into the language of the functional analysis say: the classical physics are a dispersion free physical theory. W. Heisenberg UR demonstrate that QM is essentially not (field theory). You stated:” We need this duality because we look at QM through "classical eyes".” Here I see a contradiction between you and Reilly.
  • #32
Of course there is ! You may call it whatever you want it to, but if you say that electrons are wavicles, you still need to explain why we see them only as particles. Just as too many others who do not wish to bother themselves, you are doing nothing else but rephrasing the same question in a different way : QM splits the world in two, and the question is why we observe only one part of it given that we ourselves belong to both worlds. The only ``answers'' so far are simply declarations that it *is* so, that this leads to absurdities is then sold as a necessary consequence. :tongue2:
I agree that there is a single particle self interference, but that this needs to imply wave particle *duality* (as it stands now) is jumping to unnecessary conclusions (and actually there exist other models - which were mentioned already - which do accomplish this self interference).
  • #33
But where is the contradiction ? When did i say something that would imply that the content of these quotes is wrong ?
REILLY : “I'll claim that the measurements don't know from quantum or classical. It's all in the eye of the beholder”.
The macroscopic physics is the theory of certain events. Translation into the language of the functional analysis say: the classical physics is a dispersion free physical theory. W. Heisenberg UR demonstrate that QM is essentially not (field theory). You stated:” We need this duality because we look at QM through "classical eyes".” Here I see a contradiction between you and Reilly.
Again, what contradiction ? Do you think i mean that QM is also "a dispersion free theory" (whatever that may be ?). NOT AT ALL.
There is no contradiction because i am not talking about QM nor its formalism. I think you did not get my point. All i wanted to say is that we, as human beings are more familiar with the concepts of classical physics. For us, it is easy to distinguish between a particle and a wave. Ofcourse, QM does not care about that distinction, that's what the QM formalism proves us in the doubble slit experiment. Now, this "strange" behaviour of particles behaving like waves and the other way around is something we cannot understand easily. THAT is why we call this behaviour wave/particle duality.
Again, there is no contradiction between reilly and myself and there never has been. Even Reilly stated several times that we are saying THE SAME THINGS HERE. You claim to see two contradictions, the first one i still don't get and the second one is incorrect because what i mean with "looking at QM through classical eyes" is just the same as Reilly saying "it is in the eyes of the beholder". Again, if we would look at QM through QM glasses, we would not be spending so much time discussing about the strangeness of this socalled "duality between particles and waves".
Greets
marlon
  • #34
Greets
marlon
Sure, and if we would look at crimes through the glasses of a criminal, we might not need justice at all. :rolleyes:
  • #35
Well that's true but that just normal human behaviour and we cannot do anything to change that. Even YOU wants to hold on to what you know about particles and waves and that fact that there is a distinction between the two. I just want to say that we can hold on to our classical principles and still cope with the strangeness of QM. But, THAT IS EXACTLY WHY THIS DUALITY EXISTS.
It's like this : quantum particles have indeed properties of both classical waves and particles but the way they behave with each other (and themselves !) is totally different.
But didn't you just write that quantum particles have classical wave/particle properties ? Actually, the duality is a classical idea in itself.
Again, think of WHY this duality exists and what kind of terms are used in it's definition. They are ALL classical. Two classical terms are a fundamental part of the definition of this duality. Besides, here's the 64.000 dollae question : why do you think we call it duality ?
marlon
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
