Cold Blooded Animals: Metabolism & Efficiency
In summary, the conversation discusses the differences between cold blooded and warm blooded animals and the evolutionary trade offs between the two. Cold blooded animals do not produce body heat, allowing them to conserve energy and not constantly search for food. On the other hand, warm blooded animals can be more active and live in a wider range of climates, but they require more energy to maintain body heat. The conversation also mentions the differences in chemical production between the two types of animals. While warm blooded animals have a simpler mechanism, cold blooded animals have a more complicated task of producing chemicals at different temperatures. Finally, the conversation touches on the topic of energetic efficiency and how it relates to the speed and movement of animals.
at2341
Hi,
Cold blooded animals don't produce body heat to keep themselves warm. Why is this?
Is their metabolism more efficient (produce more ATP rather than heat)?
Biology news on Phys.org
It's an evolutionary trade off.
Cold blooded - you don't waste energy keeping warm so you don't have to run around chasing food all the time, but you pay for it in not being able to move as fast for as long.
Warm blooded - you can be much more active and are able to live in a wider range of climates - but you have to be active to chase food all the time!
Interestingly warm blooded animals can be simpler form a chemical/genome sense - since ou are always at one temperate you only need one mechanism for making each chemical you need, col blooded animals have a much more complicated task to mak the same chemical by many different pathways at diffeent temperatures.
This is one of those cases where a simpliication has evolved.
THanks for the reply
You say that cold blooded animals "can't move as fast" while warm blooded animals move faster.
I thought:
cold blooded = less heat = more ATP = more energy to move
warm = more heat = less ATP = less energy to move
Is what you said about cold blooded animals not moving as fast not related to energetic efficiency?
Generally slow blooded animals can't sustain movement for as long - crocodiles are pretty dangerous for the first minute but aren't going to win any marathons.
Sorry not an expert on their biochemistry.
Ever seen ants on a cool or cold day? They don't move fast.
Some plants also produce heat.
http://www.sciencenews.org/articles/20031213/bob9.asp
1. What are cold blooded animals?
Cold blooded animals, also known as ectotherms, are animals that rely on external sources of heat to regulate their body temperature. This means that they cannot generate their own body heat and their internal temperature is dependent on the temperature of their surroundings.
2. How does the metabolism of cold blooded animals differ from warm blooded animals?
Cold blooded animals have a lower metabolic rate compared to warm blooded animals. This is because they do not need to spend energy on maintaining a constant body temperature. Instead, they have a slower metabolism which allows them to conserve energy and survive in environments with limited food resources.
3. What is the efficiency of metabolism in cold blooded animals?
The efficiency of metabolism in cold blooded animals varies depending on the species and their environment. However, on average, cold blooded animals have a lower efficiency compared to warm blooded animals. This is because they have a slower metabolism and therefore require less energy to sustain themselves.
4. How do cold blooded animals adapt to different temperatures?
Cold blooded animals have various adaptations to help them survive in different temperatures. They can adjust their behavior, such as basking in the sun to increase their body temperature, or seeking shade to lower it. Some species also have physiological adaptations, such as changing their blood flow to different parts of their body, to regulate their temperature.
5. What are some examples of cold blooded animals?
Cold blooded animals include reptiles, amphibians, fish, and invertebrates such as insects and crustaceans. Some well-known examples include snakes, lizards, frogs, turtles, and fish like sharks and tuna.
  • Biology and Medical
