Why such strange units of measure?
In summary: And since that temperature was in equilibrium, you see the microwave background radiation with the same temperature.
JArnold
Why do astronomers and cosmologists prefer to use the Distance Modulus instead of -- rather than in addition to -- Bly (billion light-years) or Mpc (mega parsecs)? Being a LOG10 it distorts relative distances. You can find Bly plotted on a graph (but not specified), and even in studies comparing z with distances according to standard candles, you won't find tables listing z alongside metric distances.
Why do astronomers and cosmologists prefer to use "temperature" rather than redshift when discussing CMB (cosmic microwave background radiation)? Why not either call it "cosmic temperature background" or specify the length of the microwave? Space being a vacuum, it seems unnecessarily weird to talk of temperature.
Space news on Phys.org
The fact that it's logarithmic is exactly why it's used; in astronomy, we are often talking about things on huge ranges of distance scales, so carrying around (or even saying) big units is ungainly. Also, from a technical standpoint, distance modulus doesn't always correspond to actual distance (in case we are discussing one that is uncorrected for extinction) and redshift doesn't always correspond to actual distance either (because strictly speaking, the distance inferred is based on how accurate our cosmological models are).
As for the CMB, the shape of the spectrum is that of blackbody radiation, and the spectrum for blackbody radiation is entirely dependent on the temperature of what's radiating.
http://en.wikipedia.org/wiki/Black-body_radiation#Planck.27s_law_of_black-body_radiation
I can understand using both, and that all extreme distant measures are more or less inaccurate. But to go from distance modulus to Mly is only to go from 2 digits to 4 or 5, and though a LOG10 might reduce relative inaccuracies (only because it's a LOG10 reduction), to telescope relative distances is itself to impose an inaccuracy. What's especially frustrating to me is that I've seen Hubble diagrams that plot z against Mpc, I've never found a corresponding table that speicifies the data points.
Regarding the CMB, isn't what's most significant about it not the temperature of the source but how long it's been traveling? Doesn't it invite confusion to use the term "microwave" but measure it as a temperature? Doesn't it suggest that what's being measured is energetic particles, as-if remnants of the original plasma?
You can calculate the distances in Mpc quite straightforwardly if you know the value of Hubble parameter. You need to remember though, that this is the luminosity distance, which is different from angular diameter distance, which is different from comoving distance.
Well, it's not the absolute temperature which is interesting, but the fluctuations. At least I recall seeing redshift given more often than the absolute temperature.
The point kind of is that what is being measured is exactly the remnants of the original plasma. As the plasma was tightly coupled with photons, you see exactly (modulo the changes happening while photons travel through the universe) the temperature of the original plasma.
There are a few reasons why astronomers and cosmologists prefer to use certain units of measure and terminology in their work. First, it is important to remember that the universe is a vast and complex place, and we often need to use unconventional units and terms in order to accurately describe and understand it.
One reason why astronomers and cosmologists use the Distance Modulus instead of Bly or Mpc is because it allows us to compare distances on a more manageable scale. The Distance Modulus is a logarithmic scale that compresses large distances into smaller numbers, making it easier to work with and understand. Additionally, the use of Bly or Mpc can be misleading, as they only refer to the distance light has traveled, not the actual size or age of the object being observed. The Distance Modulus takes into account the expansion of the universe, giving us a more accurate measure of distance.
Similarly, the use of "temperature" when discussing the CMB is also a practical choice. The CMB is essentially the remnant heat left over from the Big Bang, and it is measured in units of temperature because it is a form of thermal radiation. While it may seem strange to use temperature in a vacuum, it is a useful way to describe and understand this phenomenon. Additionally, using redshift to describe the CMB would not be as accurate, as it is only one aspect of the CMB and does not fully capture its complexity.
In short, the use of unconventional units and terminology in astronomy and cosmology is necessary in order to accurately describe and understand the vast and complex universe we live in. While it may seem strange or confusing at first, these units and terms have been carefully chosen for their practicality and accuracy in studying the cosmos.
1. Why do we use units like inches, feet, and miles instead of the metric system?
The use of non-metric units in the United States and other countries is largely due to historical and cultural reasons. The metric system was officially adopted as the international standard for measurement in 1960, but many countries, including the US, have not fully converted to using it.
2. What are the advantages of using units like meters and kilograms?
The metric system is based on a decimal system, making conversions between units much simpler than in non-metric systems. It also has a logical and consistent base unit for each type of measurement, such as meters for length and kilograms for mass.
3. How did these units of measure come to be?
Units of measure have evolved over time, with many originating from ancient civilizations. For example, the foot was based on the length of a human foot, and the inch was based on the width of a human thumb. These units were standardized over time, but variations still exist.
4. Are there any scientific reasons for using these units?
Some non-metric units, such as the pound and the gallon, have been defined in relation to scientific measurements. However, the metric system is considered more scientifically accurate and is used in most scientific research and data analysis.
5. Is there a push towards a global adoption of the metric system?
There have been efforts to promote the use of the metric system globally, but it ultimately depends on each country's decision to fully adopt it. Some industries, such as science and medicine, already use the metric system extensively, while others, like construction, still heavily rely on non-metric units.
11K
