Measuring how a star is formed
In summary: I'm not sure if this observation is highly questionable or if the Jeans limit needs tweaking, but it would be interesting to know for sure.In summary, a star with mass greater than 1.44 solar masses will collapse to form a neutron star.
shounakbhatta
288
Hello,
The general description that we give for forming a star i.e. through supernova explosion or through some stellar disturbances...etc.etc.
How do we know? I mean to say is there any way for knowing, visualizing, or calculating the way how a star is formed, how it dies?
Is there any standard model?
Thanks,
-- Shounak
Astronomy news on Phys.org
How a star is formed:
-Supernova Explosion (results in white dwarfs or neutron stars)​
-Gravitational collapse of nebulas​
How it dies:
-Lack of ability to sustain nuclear fusion and resulting gravitational collapse​
How we know:
-Observation.​
-We can figure out what a star is composed of by measuring the frequency of the radiation that it emits.​
-We know about fusion through experiments and, once we figure out what a star is composed of, we can apply fusion to the stars. In stars, hydrogen nuclei ram into each other and fuse to form helium nuclei. In the process of doing so, they release heat and light which in turn releases pressure and pushes the star outwards. Once there is no longer enough hydrogen to support the mass of the star, it collapses in on itself and, depending on how large the star was, could either become a white dwarf, neutron star, or black hole.​
There is a standard model, but not in the light you may have been referring to:
http://en.wikipedia.org/wiki/Standard_Model
The standard model of particle physics includes three fundamental forces, one of which is the weak nuclear force. The weak nuclear force deals with all forms of radioactive decay and it is responsible for hydrogen fusion in the stars.
Hello,
Thank you for the reply. Stars with huge mass when they collapse form black holes. But what about hydrogen and neutron star? How they are formed?
-- Shounak
shounakbhatta said:
Hello,
-- Shounak
Neutron star formation has to do with the size of the star that underwent the supernova explosion. There is a limit known as the Chandrasekhar limit that dictates the fate of a dying star. This limit is 1.44 solar masses. Any star whose mass is equal to or less than this will collapse to form a white dwarf. The Pauli exclusion principle states that no two identical fermions (electrons in this case) can be at the same place at the same time. When stars collapse, the atoms inside are pushed closer and closer together. In order to avoid breaking the Pauli Exclusion Principle, atoms add more energy levels to accommodate the "invasive" electrons and, in the process of doing so, release pressure. [Electron (Quantum in a more general sense) Degeneracy Pressure.]
If the star is greater than 1.44 solar masses, Electron Degeneracy Pressure will not be sufficient enough to overcome the gravitational collapse. At this point, electron capture occurs. During electron capture, the protons in the nuclei absorb the electrons and are converted into neutrons (and by doing so, release Neutron Degeneracy Pressure.) This process converts the majority of protons into neutrons, hence the name "neutron star." Neutron stars are incredibly small and incredibly dense. The neutron star is supported from further collapse by neutron degeneracy pressure as a result of the pauli exclusion principle.
For reference (more technical:)
Electron capture is a form of Beta Decay. The equation for electron capture is:
p + e- = n + ve
In word form, a proton absorbs an electron and converts into a neutron while simultaneously emitting an electron neutrino VIA Weak Nuclear Interaction.
http://en.wikipedia.org/wiki/Electron_capture
http://en.wikipedia.org/wiki/Neutron_star
http://en.wikipedia.org/wiki/Pauli_exclusion_principle
The initial size of a star formed from a collapsing gas cloud is limited by the Jeans mass. This is a diet plan for newly forming stars. If the gas cloud is too massive [the guess on limits in the current enviornment of the universe is around 200 solar], it will fragment. In the early universe this mass may have been much larger, possibly several hundred or more solar masses for pop III stars, when metallicity of the gas cloud was negligible.
Wolf-Rayet star R136a1 has mass ~255 solar:
Crowther, Paul A., et al, 2010 arXiv:1007.3284
Is this observation highly questionable or does the Jeans limit need tweaking? Maybe I am way off base here...
According to the wiki article on that star it is believed to have been formed by the merger of two supermassive stars after they were formed.
http://en.wikipedia.org/wiki/R136a1
Thanks for the link. In general, though Wikipedia is not a perfect source. The wiki article has citations; the one I could read looks reasonable validity-wise. ...I'm not a physicist.
...ok?
1. How do scientists measure the formation of a star?
Scientists use a variety of techniques to measure the formation of a star. These include observing the light emitted from the star, analyzing its chemical composition, and studying its movement and temperature.
2. What is the most common method for measuring a star's formation?
The most common method for measuring a star's formation is through spectroscopy, which involves analyzing the light spectrum emitted by the star. This can provide valuable information about the star's composition, temperature, and age.
3. How do scientists determine the age of a star?
Scientists can determine the age of a star by measuring its mass, luminosity, and chemical composition. They can also use techniques such as isochron dating, which compares the star's properties to theoretical models of stellar evolution.
4. Why is measuring a star's formation important?
Measuring a star's formation is important because it can help us understand the processes that lead to the formation of stars and planets. It also allows us to study the evolution of stars and the universe as a whole.
5. Can scientists measure the formation of all stars?
While scientists have been able to measure the formation of many stars, there are still some limitations. For example, extremely young stars that are still surrounded by dense clouds of gas and dust are more difficult to study. However, advances in technology and instrumentation are constantly improving our ability to measure the formation of stars.
  • Astronomy and Astrophysics
