Velocity of rotation at the edge of the Galaxies
In summary, there is an interesting explanation for the rotational speed of galaxies in section 7.1 of the linked website. However, some statements in the article may be disputable, such as the claim that the speed of light is reduced in a gravitational field. Additionally, the article suggests that the dark matter needed to explain the stability of rotating galaxies may actually be a stream of photons emitted by hot stars, but this claim lacks credible evidence and should not be linked to unreliable sources.
talksabcd
34
I found an interesting explanation for rotational speed of the galaxies in the below link at section 7.1
http://www.ag-physics.org/gravity/
Can anyone comment on this ?
Astronomy news on Phys.org
The first sentence of that link goes like this:
It is a well proven fact that the speed of light is reduced in a gravitational field.
This is wrong. I assume the rest relies on this so I didn't bother reading it.
That particular statement isn't completely wrong: it is common and reasonable to model the space-time curvature that way, treating the geometry as flat but assigning refractive index around mass. Kinda like the whole PPN approach.. But then it can be taken too literally..
there is no longer a need for the assumption of a curved space-time in order to explain the phenomena named above
No doubt it's easy to come up with (other) phenomena that do require curvature.. at least in order to be explained in a simple and consistant manner.
..just realized, my choice of the word "simple" may be disputable. :wink: Funny how differential geometry seems so difficult to those who haven't learned the math yet, and seems so elegant to those who've spent time using it.
What he meant was reduction in velocity of light is just relative not absolute.
Example:
Suppose we are doing two experiments to find the velocity of speed of light
on Earth and Moon then both will get the same value C but velocity of light on the Earth measured from moon will be lower due to gravitational length contraction and time dilation on Earth and vice-versa from the earth.
Further explanation:
As there would be gravitational time dilation and length contraction on earth
relative to moon, velocity of light should be reduced as time is running slow by
a factor of x and length is contracted by a factor x on Earth when observed from moon. So the apparent velocity of light on Earth observed from moon will
be C(changed) = Changed length/Changed time = d x^2/t. So apparent velocity of light on Earth when observed from moon would be reduced by a factor of x^2.
Just picking the low hanging fruit from the article:
"2. the basic model of matter. That means that elementary particles are built by sub-particles, which orbit each other at the speed of light c"
A surprising number of particle physicists would have issues with this assertion.
"And there is a lot of evidence that the "Dark Matter" which is assumed to be necessary to explain the stability of rotating galaxies is in fact the stream of photons emitted by every hot star."
What evidence? It is customary to provide credible, published, reference sources.
Please don't link to crank sites.
1. What is the velocity of rotation at the edge of galaxies?
The velocity of rotation at the edge of galaxies is known as the tangential velocity, and it is the speed at which stars or other objects at the edge of a galaxy are orbiting around its center.
2. How is the velocity of rotation at the edge of galaxies measured?
The velocity of rotation at the edge of galaxies is measured through spectroscopy, which is the study of light emitted or absorbed by objects. By analyzing the Doppler shift in the light from stars at the edge of a galaxy, scientists can determine their tangential velocity.
3. Why is the velocity of rotation at the edge of galaxies important?
The velocity of rotation at the edge of galaxies is important because it provides insights into the mass and distribution of matter within the galaxy. It can also help determine the presence of dark matter, which is believed to make up a significant portion of a galaxy's mass.
4. What factors can affect the velocity of rotation at the edge of galaxies?
Several factors can affect the velocity of rotation at the edge of galaxies, including the mass and distribution of matter within the galaxy, the presence of dark matter, and the influence of neighboring galaxies through tidal forces.
5. How does the velocity of rotation at the edge of galaxies change as you move further from the center?
The velocity of rotation at the edge of galaxies tends to decrease as you move further from the center. This is known as the rotation curve and is often used to study the distribution of matter within a galaxy and the presence of dark matter.
  • Astronomy and Astrophysics
