Non conservative forces: work + coefficient of static friction
In summary, the problem involves a 20 kg sled starting up a 30 degree incline with a speed of 2.4 m/s. The coefficient of kinetic friction is 0.25. Part A asks for the distance traveled up the incline, which can be found by calculating the net work. Part B asks for the condition that must be met to prevent the sled from getting stuck at the point determined in part A. The correct answer is Mu(s) > 0.577. For part C, the initial velocity is known and can be used to calculate the final kinetic energy by subtracting the frictional work from the initial kinetic energy. The potential energy can be disregarded in this case.
Return
[SOLVED] Non conservative forces: work + coefficient of static friction
hey guys, I've been having a little trouble with some parts of this problem, hope someone can point me in the right direction
A 20[kg] sled starts up a 30 degrees incline with a speed of 2.4[m/s] the coefficient of kinetic friction is 0.25.
A) How far up the incline does the sled travel?
B) What condition must you put on the static coefficient if the sled is not to get suck at the point determined in part a?
C) If the sled slides back down what is its speed when it returns to its starting point?
Know: m = 20 [kg]
theta = 30 degrees
v (initial) = 2.4 [m/s]
Mu(k) = 0.25
Ok, so I did part A): I found the net work and how far the sled went up the incline.
Part B) threw me off a little bit. By condition I assume I have to find an angle? Or maybe a range for the coefficient?
What I did was carry out tan(theta) = Mu(s) plugged in 30 degrees for theta and got
Mu(s) = .577 and then said that the condition was that M(s) < .577 is that right?
Part C) Here I wasnt sure if I should use kinematics or conservation of energy equations. There's a friction force which is nonconservative, but I'm not sure how to incorporate this. Any help would be appreciated
Good job so far! Don't you want to say Mu(s)>.577? For part c) it starts with some KE. The PE cancels up and down. So you should be able to just subtract the frictional work from the initial KE to get the final KE, right? Frictional work is just frictional force times total distance travelled, also right?
ok, sounds good, but how do I know the initial velocity to plug into my KE(i) equation?
2.4m/sec. Weren't you given that??
Hi Dick,
I think the original answer of [itex]\mu_s < 0.577[/itex] is correct for this problem.
alphysicist said:
Hi Dick,
Oh, right. It's says "not to get stuck", not "stuck". Thanks for the sharp eye, alphysicist!
oh ok, i think what I'm getting confused about is this: the sled goes up the ramp and then it comes down, can you assume the initial veloctiy coming down is 2.4 [m/s]? that was it's initial velocity when it was going up.Also can you also really disregard P.E.? because it goes up the ramp, stops, then starts going down the ramp. At the point it stops doesn't it have PE and not KE?
I was talking about considering the whole trip. Start at 2.4m/s. Go up. Stop. Come back down. In the round trip PE cancels. Guess I didn't make that very clear. You can also do what you suggest. Assume 0 KE at the top, compute the PE and subtract the frictional work to get the final KE.
What are non-conservative forces?
Non-conservative forces are forces that cause a change in the total mechanical energy of a system. They do not follow the principle of conservation of energy, meaning that the work done by these forces is not equal to the change in potential and kinetic energy of the system.
How do non-conservative forces affect work?
Non-conservative forces do work on a system, but this work is not stored as potential energy. It is instead converted into heat or other forms of energy, causing a decrease in the total mechanical energy of the system.
What is the coefficient of static friction?
The coefficient of static friction is a dimensionless value that represents the amount of force needed to overcome the static friction between two surfaces. It is dependent on the materials, surface conditions, and the normal force between the two surfaces.
How does the coefficient of static friction affect work?
The coefficient of static friction affects the work done by non-conservative forces, as it determines the amount of force needed to overcome the friction between two surfaces. The higher the coefficient, the more work is required to move an object along the surface.
Can non-conservative forces do positive work?
Yes, non-conservative forces can do positive work. However, this work does not result in an increase in the mechanical energy of the system. It is converted into other forms of energy, such as heat or sound, which leads to a decrease in the total mechanical energy of the system.
