Get 800MHz Local Oscillator Input for LT5521 Upconverting Mixer
  • Thread starter awaiting
In summary, an upconverting mixer (LT5521) requires a local oscillator input of 800 MHz. A chip called the Si570 can be programmed to produce an 800 MHz output. There are other possibilities for getting the local oscillator input, but they require specialist equipment and experience.
awaiting
24
Hello everyone,i am using an upconverting mixer(LT5521) which converts a 100MHz signal to 900MHz.it requires a 800MHz of local oscillator input.can anyone suggest an IC or a circuit that can be used to get the local oscillator input.
Thank you
Thank you
Are you familiar with MiniCircuits?
http://www.minicircuits.com/sitemap.html
Thank you
you are going to have to build a Local Osc LO
as berkeman hinted, visit minicircuits, they have a wonderful range of VCO's (voltage controlled oscillators) One of those will be the heart of your LO. you will then have to decide if you want to have it free running or PLL'ed (phase locked looped) for stability
The stability you require will be dependant on what you transmitter/receiver is for, the bandwidth used wideband/narrowband, voice/data etc
cheers
Dave
VK2TDN
You could buy one of these:
Ebay item no 260634345068
They are 100 MHz crystal oscillators selling at $2 for two. (3 volts though.)
You could then follow it with a doubler (frequency multiplier) to 200 MHz.
Then another to 400 MHz.
Then another doubler to 800 MHz.
Unfortunately, you would need some specialised measuring equipment and experience to do this. Mainly the problem is that you need to know that the 200 MHz tuned circuit is resonant at 200 MHz and not 100 or 300 MHz. And so on for the other circuits.
There is another possibility. A company called Silicon Labs produces a chip called a Si570 which can be programmed for you at 800 MHz. It would then produce just 800 MHz output.
Their website does not seem to give prices for this service.
They have another family of devices:
Silicon Labs' Si5322, Si5325, Si5365 and Si5367 family of low jitter programmable clock multiplier ICs provides flexible integer clock multiplication.
They take inputs and multiply them by some integer value to produce a higher frequency:
Flexible integer clock multiplier from 10 to 945 MHz and select frequencies to 1.4 GHz from an input frequency of 10 to 710 MHz
So, apparently, you could take a stable oscillator on some low frequency like 100 MHz and multiply it to 800 MHz in one chip.
Maybe you could send them a query to find out what they can offer and at what price.
I don't really have a whole lot of RF communications experience, but based on a quick perusal of the datasheet, are you sure that your mixer doesn't actually require 900 MHz local oscillator input as a carrier for your 100 MHz signal? My recollection is that frequencies don't add quite like that (unless my terminology is off).
No, they do add up like that.
100 MHz signal PLUS 800 MHz local oscillator gives a 900 MHz signal out.
There will also be a 700 MHz difference signal which has to be filtered out, as this is 800 MHz MINUS the 100 MHz signal.
Ah, there I go:
http://en.wikipedia.org/wiki/Frequency_mixer#Mathematical_description
Even supposed learned folks learn new things here every day!
i think the minicircuits site is nice source,i did get the required VCO's.
Thank you everyone for your replies!
awaiting said:
i think the minicircuits site is nice source, i did get the required VCO's.
Yes they are :) I use a lot of their products in various projects.
let us know how your project progresses
Dave
VK2TDN
What is the purpose of a local oscillator input for an upconverting mixer?
The local oscillator input is used to mix the incoming RF signal with a local oscillator signal in order to upconvert the frequency of the signal. This allows for the signal to be shifted to a higher frequency for further processing or transmission.
What is the frequency range for the local oscillator input on the LT5521 upconverting mixer?
The frequency range for the local oscillator input on the LT5521 upconverting mixer is 800 MHz. This means that the local oscillator signal should be set to a frequency within this range for optimal performance.
How is the local oscillator signal generated for the LT5521 upconverting mixer?
The local oscillator signal can be generated using various methods, such as using a crystal oscillator or a frequency synthesizer. The specific method used will depend on the application and the desired frequency range.
Why is it important to have a stable and accurate local oscillator signal for the upconverting mixer?
A stable and accurate local oscillator signal is important because any fluctuations or inaccuracies in the signal can result in distortion and interference in the upconverted signal. This can affect the overall performance and reliability of the upconverting mixer and the system it is being used in.
Are there any recommended techniques for optimizing the local oscillator input for the LT5521 upconverting mixer?
Yes, there are several techniques that can be used to optimize the local oscillator input for the LT5521 upconverting mixer. These include using a low phase noise oscillator, proper impedance matching, and minimizing signal reflections. It is important to consult the LT5521 datasheet and application notes for specific guidelines and recommendations.
  • Electrical Engineering
