Gravitational Potential Energy Earth Question
In summary: When you're doing conservation of energy, you'll probably use both formulas, but in different circumstances. Just make sure to use the appropriate formula for each situation.
eurekameh
210
Gravitational Potential Energy (U) = -(GMm)/R
Also, U = mgy.
I need help making a connection between these two equations. For U = -(GMm)/R, it is saying that because R = radius of the Earth, an object on the surface of the Earth has a gravitational potential energy, correct?
U = mgy seems to be saying otherwise because y = 0.
Can anybody explain this to me?
What matters when talking about gravitational PE is the change in PE measured from some reference point.
Note that R stands for the distance between the two masses. This formula assumes that the zero PE point is at R = infinity, when the masses are infinitely far apart.
Also, U = mgy.
This formula is useful near the Earth's surface. It takes the zero PE point to be wherever you set y = 0.
Right. If you plug in R = Radius of Earth, it will give you the gravitational PE compared to when they were infinitely far away.
That formula uses y = 0 as a reference, so you can't directly compare those results.
But as I said up front, what really matters is the change in PE. For example, if you lift the mass m from y = 0 to y = h, what's the change in gravitational PE? Using the second equation, you'll get ΔU = mgΔy = mgh.
You could use the first equation to measure that change in PE. In that case you'd need to compare the PE when the masses moved from R = Radius of Earth (Re) to R = Re + h. Like so:
ΔU = [-(GMm)/(Re + h)] - [-(GMm)/(Re)]
For values of h near the Earth's surface where h << Re, you can work it out and find that
ΔU = (GMm)/(Re)2*h = mgh
You get the same answer either way. (If h is too big, then the value of g will vary too much, making the mgy version unusable.)
Thanks so much for the answer. It makes sense now. =)
Something just came up again. What if I wanted to conserve mechanical energy? Do I use U=mgh or U=-(GMm)/R? I've noticed that I use U=mgh for objects close to the Earth and is falling to the surface of the Earth and U=-(GMm)/R for objects really far away from Earth. Can someone clarify this for me?
U = mgh only applies when the object is near the surface of the Earth, where g is relatively constant. When the object is far enough from the surface that variation in g matters, you'll need the other formula.
1. What is gravitational potential energy?
Gravitational potential energy is the energy an object possesses due to its position in a gravitational field. It is the potential to do work on an object by virtue of its position in the Earth's gravitational field.
2. How is gravitational potential energy calculated?
Gravitational potential energy is calculated by multiplying an object's mass by the acceleration due to gravity (9.8 m/s²) and its height above the ground.
3. What affects the amount of gravitational potential energy an object has?
The amount of gravitational potential energy an object has is affected by its mass, the strength of the gravitational field, and its distance from the center of mass of the object creating the gravitational field.
4. How does gravitational potential energy change as an object moves?
As an object moves, its gravitational potential energy changes depending on its position in the gravitational field. The higher an object is located, the greater its gravitational potential energy, and as it moves closer to the ground, its gravitational potential energy decreases.
5. Can gravitational potential energy be converted into other forms of energy?
Yes, gravitational potential energy can be converted into other forms of energy, such as kinetic energy, when an object is in motion. This is demonstrated by an object falling from a height and gaining kinetic energy as it accelerates towards the ground.
11K
