Copper wire and shove it into the positive terminal
In summary, the conversation discusses the potential danger of inserting a copper wire into an electrical outlet and connecting it to the earth, causing a short circuit and potentially starting a fire. This action is discouraged as it can result in harm to oneself and potentially damage to property.
MotoPayton
96
If I were to take a copper wire and shove it into the positive terminal of an electrical outlet and then stick the other side of the copper wire into the earth, will current flow??
Of course .. and lots for a brief time till the copper wired fused or the house circuit breaker tripped
Why would you want to do such a dopey thing ?
You are setting yourself to be a darwin Award contender
if you don't do and don't even consider such actions you will " Live Long And Prosper"
cheers
Dave
Electrical outlets don't have positive terminals, only hot, neutral and ground. If you meant the hot terminal, yes, current will flow, including through you if you aren't protected.
It's called a short circut (or line-to-ground fault). Hopefully a breaker would trip somewhere, otherwise one risks starting a fire if the circuit overheats. That is a dangerous activity that we discourage.
I must advise against this action as it can be extremely dangerous and potentially result in electrocution. Copper wire is a good conductor of electricity and inserting it into the positive terminal of an electrical outlet can create a direct path for current to flow. This can lead to a short circuit, damaging the outlet and potentially causing a fire. Additionally, inserting the other end of the wire into the earth can create a grounding effect, which can further increase the flow of current and pose a significant risk to personal safety. It is important to always follow proper safety precautions and avoid tampering with electrical outlets or wiring without proper knowledge and training.
What is the purpose of shoving copper wire into the positive terminal?
The purpose of shoving copper wire into the positive terminal is to create a conductive pathway for electricity to flow. Copper is a highly conductive material, making it a suitable choice for transferring electricity.
Can any type of wire be used for this task?
No, not all types of wire are suitable for this task. It is important to use a wire that is made of a conductive material, like copper, to ensure the flow of electricity. Other types of wire, such as plastic or rubber coated wire, may not be able to conduct electricity effectively.
Is there a risk of electrocution when shoving copper wire into the positive terminal?
Yes, there is a risk of electrocution when handling any type of electrical equipment. It is important to take proper safety precautions, such as wearing insulated gloves, when working with electricity.
Is it necessary to secure the copper wire in place once it is inserted into the positive terminal?
Yes, it is important to secure the copper wire in place to ensure a stable connection. If the wire is not secure, it may become loose and interrupt the flow of electricity.
Can copper wire be used in all types of electrical devices?
Copper wire can be used in many types of electrical devices, but it may not be suitable for all. It is always best to consult the manufacturer's instructions or a professional to determine the appropriate type of wire to use for a specific device.
  • Classical Physics
  • Electrical Engineering
