| New Reply |
Relativistic RMS Speed |
Share Thread | Thread Tools |
| Jan3-13, 03:05 PM | #1 |
How can we restrict the RMS speed of molecules to comply with relativity?
They obviously can't go at or faster than the speed of light. If you are dealing with particles inside of very hot stars for example you may get very high erroneous speeds. [itex]v = \sqrt{\frac{3KT}{m}}[/itex] How could we manipulate this equation? |
| Jan3-13, 03:12 PM | #2 |
Recognitions:
I am not familiar with the equation you gave. However, increasing energy (heating particles up) close to relativistic speeds leads to increase in m rather than v.
| Jan3-13, 03:23 PM | #3 |
Yes that may have been a more appropriate question for me to ask in hopes of connecting relativity and kinetic gas theory
| Jan3-13, 03:29 PM | #4 |
Mentor
Relativistic RMS Speed![]() Instead, we start from scratch and re-derive the Maxwell speed distribution using relativistic kinetic energy instead of non-relativistic kinetic energy. This appears to have what you are looking for: The Maxwell Speed Distribution for Relativistic Speeds (PDF) See equation 21 on page 4. |
| Jan3-13, 03:41 PM | #5 |
| Jan3-13, 03:48 PM | #6 |
| Jan3-13, 03:53 PM | #7 |
| Jan3-13, 04:58 PM | #8 |
The correct approach is to use a uniform density in momentum space. For nonrelativity it doesn't matter since p = mv is linear, but it does matter in our case. In momentum space there is no cutoff, one integrates over all p out to infinity. |
| Jan4-13, 04:00 PM | #9 |
Recognitions:
| Jan4-13, 04:10 PM | #10 |
The reason I discourage calling it a mass is the temptation for those learning SR to substitute it into Newtonian formulas. There is only one common formula (momentum) for which this works. F = m[itex]\gamma[/itex]a anyone? KE = (1/2)m[itex]\gamma[/itex]v^2 anyone? Another observation is that [itex]\gamma[/itex] is really part of the normalization of 4-velocity to be a unit 4-vector. The correct 4-force equation for constant mass particle is simply m * 4-acceleration. |
| Jan5-13, 02:20 PM | #11 |
Recognitions:
| Jan5-13, 03:09 PM | #12 |
[edit: Thinking more, I see the main reason for the shift is the wide adoption of 4-vectors for SR. In this scheme you have mU. for 4-momentum; m is rest mass, U is 4 velocity. No mγ in sight (it is internal to the 4-velocity). Then, 4-force is naturally mA, using 4-acceleration; no nonsensical transverse and longitudinal relativistic mass as seen in some ancient relativity books.] |
| Jan7-13, 04:08 PM | #13 |
Recognitions:
| Jan9-13, 04:36 AM | #14 |
| New Reply |
| Thread Tools | |
Similar Threads for: Relativistic RMS Speed
| Thread | Forum | Replies | ||
| Speed of a Relativistic Particle? | Introductory Physics Homework | 1 | ||
| Ender's Relativistic Speed | Special & General Relativity | 11 | ||
| Speed of Pi Meson - Relativistic question | Introductory Physics Homework | 5 | ||
| What happens after you travel at a relativistic speed | Special & General Relativity | 15 | ||
| relativistic speed | Advanced Physics Homework | 4 | ||
