Capacitor having equal charges on plates connected to a battery
In summary, the inner surface of a capacitor will have equal and opposite charges when connected to a battery, regardless of whether the plates are initially charged.
Vibhor
971
40
Hello
I am having a doubt regarding capacitors .I know that when two neutral plates of an uncharged capacitor of capacitance C are connected to a battery of V volts then charges present on the inner surface of the plates are equal and opposite i.e +Q and -Q,where Q=CV .
But what will happen when both plates are initially having a positive charge +q and then a battery of V Volts is applied across the plates ?
My doubts are
1)In general a battery supplies equal and opposite charges.Does the battery supply equal and opposite charges in this case too ,where the plates are already having +q on them ?
2) If the inner surfaces of plates of the capacitors have equal and opposite charges after the battery is connected ,then in this case the outer surfaces will carry unequal charges . Is it so ?
Please clarify my doubts ...Thanks
That will not happen in a significant way in electronics. Usually, all parts are so close to neutral that you can neglect net charges. In addition, that charge would be on the outside, not on the inner side of the capacitor.
Your charges would be distributed over the whole setup, in addition to the +Q, -Q on the inner sides of the capacitor.
A 'typical' capacitor could well have a high capacitance (1μF) between its plates but its capacitance to ground will be no more than a few pF. You would need to charge the whole capacitor up to a voltage almost one million times higher than the volts between the plates for the total (unbalanced) charge to be the same as the (balanced) charge difference 'inside' it.
The formula Q = CV applies in both cases.
In RF circuits, where small values of capacitor (only a few pF) are often used, the total charge on a capacitor may well be on the same order as the charge stored (during an RF cycle) between the plates.
Does a battery always supply equal and opposite charges to plates of a capacitor irrespective to whether the plates are neutral or they may have charge on them initially (say +q charge on both plates initially before the battery was connected )?
If the battery is in series - directly - with the two sides of the Capacitor then, of course, the same charges must flow in and out of the terminals of the capacitor.
But it is quite possible for a capacitor to have an excess +charge on both of its terminals. Just stick a series capacitor / battery circuit on top of a Van der Graaff generator globe, if you want an extreme example. There will be a net charge all over that circuit with the C 'charged up' by the battery PD.
Hello sophiecentaur!
Thanks for the response...Sorry for responding late ...
Does that mean that the inner surface of the capacitor will have equal and opposite charges and the outer surface of the plates will carry unequal positive charges ( since both the plates are initially having a positive charge +q before the battery of V Volts is applied across the plates ) ?
I would guess that, as the spacing between the capacitor plates is so small that the field would be high enough to dominate and that what you suggest is probably right. But imagine taking the model to an extreme, consisting of two charged objects (which were, 'preciously', the capacitor plates) separated by a significant distance and above a 'ground'. Then give the two objects different charges by giving them, independently, a different Potential wrt ground. The distribution of the charges around the objects would depend both upon their actual separation and their distance from the Ground - they wouldn't all rush to the nearest points on the two objects, would they?
The other extreme could be two capacitors connected in series and the end of one is connected to ground. One is charged (with a floating supply) and then the other. . . . . . .?
Thanks a lot ...
1. What is a capacitor?
A capacitor is an electronic component that is used to store electrical energy. It consists of two conductive plates separated by a dielectric material.
2. How does a capacitor get charged?
A capacitor gets charged when it is connected to a power source, such as a battery. The positive plate of the capacitor gets charged with positive charges and the negative plate gets charged with negative charges.
3. How does a capacitor with equal charges on plates connected to a battery behave?
A capacitor with equal charges on plates connected to a battery behaves as an open circuit. This means that the capacitor does not allow any current to flow through it.
4. Can a capacitor with equal charges on plates connected to a battery hold its charge indefinitely?
No, a capacitor with equal charges on plates connected to a battery cannot hold its charge indefinitely. Over time, the charges on the plates will dissipate due to leakage through the dielectric material.
5. How can a capacitor with equal charges on plates connected to a battery be discharged?
A capacitor with equal charges on plates connected to a battery can be discharged by connecting a resistor in parallel with the capacitor. This creates a path for the charges to flow through, allowing the capacitor to discharge.
  • Electromagnetism
  • Electromagnetism
