Why do we take the no. of years to compound the interest as power?
In summary, when calculating compound interest, the number of periods and the interest rate per period are used to determine the total amount earned. Compounding interest means earning interest on the interest earned in previous periods. This can be calculated using the formula A(t) = A_0 \left(1 + \frac{r}{n}\right)^{nt}, where A(t) is the total amount earned after t years, A_0 is the initial amount, r is the annual interest rate, n is the number of periods in a year, and t is the number of years. This formula takes into account the fact that interest is earned on the interest earned in previous periods.
Juwane
87
Why do we take the "no. of years to compound the interest" as power?
Suppose interest is given at 12% annually, compounded once a year. At the end of the year we will have (A = starting amount):
[tex]A( 1 + 0.12 )[/tex]
But if it is compounded twice a year, then at the end of the year we will have:
[tex]2A \left( 1 + \frac{0.12}{2} \right)[/tex]
Why is the above wrong? Why it should be [tex]A \left( 1 + \frac{0.12}{2} \right)^2[/tex] instead of [tex]2A \left( 1 + \frac{0.12}{2} \right)?[/tex]
Why is the above wrong? We it should be [tex]A \left( 1 + \frac{0.12}{2} \right)^2[/tex] instead of [tex]2A \left( 1 + \frac{0.12}{2} \right)?[/tex]
The interest you earned for the first half year is now money upon which you earn more interest for the second half of the year. Take for example 20% interest on 100 dollars compounded twice a year. In the first half-year you earn 10% of $100 so you have $100+$10= $110.
For the second half-year you earn 10% on the $110 so you have $110 + $11 = $121.
That's what "compounded" means. You earn interest on the interest, and then interest on the interest on the interest, and so on.
It helps to forget "years" and work only with "periods". Say you earn interest per period at a rate of [tex] r_p[/tex]. For a given period if you start with an amount [tex]A[/tex] at the end of that period you have amount [tex]A + r_p A= A(1+r_p)[/tex].
Do this for [tex]k[/tex] periods and you have:
[tex]A=A_0(1+r_p)(1+r_p)\cdots(1+r_p) = A_0(1+r_p)^k[/tex]
Understand that formula first. Each compounding period effects a multiplication by 1 plus the rate. Repeated multiplications are expressed by a power.
Now we rescale to years. Given an annual rate of r and n periods in a year and t years.
[tex] r_p = r/n[/tex]
[tex] k = nt[/tex]
so
[tex] A(t) =A_0\left(1+r_p\right)^k= A_0 \left(1 + \frac{r}{n}\right)^{nt}[/tex]
(with [tex] A_0 = P[/tex] the initial amount is called the "principle" by accountants.)
1. Why do we take the number of years to compound the interest as power?
This is because compound interest is calculated based on the principle that the interest earned in each period is added to the principal amount and then the interest is calculated on the new total. The number of years represents the number of compounding periods, and raising it to a power allows for accurate calculation of the interest earned over multiple periods.
2. How does taking the number of years to compound as power affect the overall interest earned?
By taking the number of years to compound as power, the interest earned over multiple periods is accurately calculated and added to the initial principal amount. This results in a higher overall interest earned compared to simple interest, where the interest is only calculated on the initial principal amount.
3. Can the number of years to compound be any value?
Yes, the number of years to compound can be any positive real number. However, it is typically expressed as a whole number to simplify the calculation process.
4. Why do some investments have a different compounding period than others?
Different investments have different compounding periods because it allows for more flexibility in how the interest is earned and added to the principal amount. For example, some investments may compound interest annually, while others may compound monthly or even daily.
5. How does the compounding period affect the overall interest earned?
The compounding period can have a significant impact on the overall interest earned. The shorter the compounding period, the more frequently the interest is added to the principal amount. This means that the interest earned in each period is added to the principal amount more often, resulting in a higher overall interest earned.
