Unbounded operators in non-relativistic QM of one spin-0 particle
In summary: Omega \subset H \subset \Omega^*_1Note that a vector v\in H is also a linear functional, so youcan think of H as being a subspace of its dual, and thenthe RHS relation becomes\Omega \subset H \subset H^*,where H^* is the topological dual, and is generated by the"bra" vectors, \langle \psi |. Also note thatthe RHS relation is the same as saying that \Omega is the"topological dual" of H.From this general starting point, you can then move on toformalisms that use all sorts of unbounded operators asobservables, with domain issues and all
  • #36
strangerep said:
Note that each of these norms defines a subspace. I.e., the sequence of norms defines
a sequence of spaces, each densely nested in the previous (larger) one. So "continuity"
applies in the context of the norm topology on each subspace. The tempered distribution
case applies to the (dual of) the "inductive limit" of this sequence of spaces (afaiu).
Ah, that's actually very helpful. I just re-read a few statements from the part of Streater & Wightman where they define tempered distributions, keeping in mind what you just said, and suddenly what they're saying makes a lot more sense. :smile: Unfortunately I have to go to bed now, but I'll continue tomorrow.
  • #37
The answer to my concerns in #34-35 (or at least a partial answer) is probably that there's nothing weird or unexpected about the fact that the concept of continuity depends on what topology you define on the set you're working with. The space of distributions isn't the dual space of the test functions. It's a dual space of the test functions. Or to be more accurate, the topological dual space of a set isn't defined. Only the topological dual space of a topological vector space is defined, so we have to choose a topology first, and then we get a dual space.
It still makes me wonder why their version of continuity is more desirable. It probably has something to do with the idea that derivatives of distributions should always exist, but I haven't thought that idea through yet.
Edit: I'm satisfied that I understand the definition of distributions and tempered distributions now, so we don't have to discuss them unless someone else wants to. I'm not saying that I understand every detail perfectly, but my understanding is good enough.
By they way, a thought occurred to me when I was replying to another thread. Isn't it weird to start the formulation of the simplest meaningful quantum theory (the non-relativistic QM of one spin-0 particle) by postulating that the states are rays in [itex]L^2(\mathbb R^3)[/itex] when the next postulate says that the time evolution is given by the Schrödinger equation? The Schrödinger equation only makes sense if the partial derivatives exist, and that implies continuity, but [itex]L^2(\mathbb R)[/itex] contains ridiculous functions like the one Hurkyl thought of in another thread to disprove a claim I made there:
Hurkyl said:
Consider the function:
[tex]
\psi(x) =
\begin{cases}
0 & x < 1 \\
1 & x \in [n, n + n^{-2}) \\
0 & x \in [n + n^{-2}, n+1)
\end{cases}
[/tex]
where n ranges over all positive integers. [itex]\psi(x)[/itex] does not converge to zero at [itex]+\infty[/itex]. However,
[tex]
\int_{-\infty}^{+\infty} |\psi(x)|^2 \, dx
= \sum_{n = 1}^{+\infty} \int_{n}^{n + n^{-2}} 1 \, dx
= \sum_{n = 1}^{+\infty} n^{-2} = \pi^2 / 6[/tex]
  • #38
Fredrik said:
Maybe these two options are actually equivalent, but I would expect that they're not, mostly because I think option 1 is more natural and intuitive. I don't see why these authors would all go for option 2 if they are equivalent.
First, you can probably separate out the differentiability stuff from the topological
continuity stuff.
I think (in the absence of precise definitions of those two cases) that both notions
of convergence are equivalent. The first is just saying that you can construct a
Cauchy sequence and the second is saying that a sequence converges.
(Topologically, a sequence "converges to a point z" if, given an arbitrary open
set O containing z, all points of the sequence are eventually "in" O -- after some
integer n in the sequence.
The thing about restricting to infinitely differentiable functions is so that you
can do integral calculus, i.e., solve a DE given an initial condition, in such
a way that as to be compatible with the (rigged) Hilbert space structure.
Yes. This is a crucial point to understand in order to work with other
topologies (weak, weak*, and others). Generally speaking, convergence
is easier in weaker (coarser) topologies, but more theorems can be
proven with stronger (finer) topologies. Bit of a tradeoff depending on
exactly what one is trying to achieve.
  • #39
I think I'm going to have to study some more functional analysis before I post a bunch of new questions. I'll read some more of Conway first, and maybe I'll read Maurin's lecture notes. Strangerep and Jostpuur, thanks for the answers so far. George, feel free to bump the thread when you're less busy. I'm interested in what you have to say about all of this.
  • #40
Brilliant discussion on a very interesting topic, I must say. I was wondering, how would I build the RHS for the hydrogen atom ? The hamiltonian for the H atom has a mixed spectrum and I've never seen an application of the RHS formalism for an operator with mixed spectrum.
  • #41
Fredrik said:
OK, let's focus on "distributions" first, not "tempered distributions". We define the test function space (I'll call it [itex]\mathcal D[/itex]) as the set of [itex]C^\infty[/itex] functions from [itex]\mathbb R^n[/itex] into [itex]\mathbb C[/itex] that have compact support. I would like to define a "distribution" as a member of the dual space [itex]\mathcal D^*[/itex], defined as the set of continuous linear functions [itex]T:\mathcal D\rightarrow\mathbb C[/itex]. But to do that, we need to define what "continuous" means. There are at least two ways to do that.
Option 1: Define the usual inner product. The inner product gives us a norm, and the norm gives us a metric. Now we can use the definition of continuity that applies to all metric spaces.
Equipping the [itex]\mathcal{D}[/itex] with a norm
[tex]
\|\psi\|^2 = \int\limits_{\mathbb{R}^n} dx\; |\psi(x)|^2
[/tex]
and defining [itex]\mathcal{D}^*[/itex] as a topological dual
[tex]
\mathcal{D}^* = \big\{ \phi^*\in \mathbb{C}^{\mathcal{D}} \;|\; \phi^*\;\textrm{is linear},\; \sup_{\|\psi\|\leq 1} |\phi^*(\psi)| < \infty\big\}
[/tex]
is probably not what anyone wants, because for example this collection of linear forms doesn't contain delta-functions [itex]\delta_x:\mathcal{D}\to\mathbb{C}[/itex], [itex]\delta_x(\psi)=\psi(x)[/itex].
Was that what you meant by your option 1?
Fredrik said:
Option 2: This is the option that every text on the subject seems to prefer, and I don't see why. We define what it means for a sequence in [itex]\mathcal D[/itex] to be convergent by saying that [itex]\phi_n\rightarrow\phi[/itex] if there's a compact set K in [itex]\mathbb R^n[/itex] that contains the supports of all the [itex]\phi_n[/itex], and [itex]D^\alpha \phi_n[/itex] converges uniformly on K to [itex]D^\alpha\phi[/itex], for all [itex]\alpha[/itex].
Now we define "continuous" by saying that [itex]T:\mathcal D\rightarrow\mathbb C[/itex] is continuous at [itex]\phi\in\mathcal D[/itex] if
[tex]\lim_{n\rightarrow\infty}T(\phi_n)=T(\phi)[/tex]
for every sequence [itex]\{\phi_n\}[/itex] that converges to [itex]\phi[/itex]. Maybe these two options are actually equivalent, but I would expect that they're not, mostly because I think option 1 is more natural and intuitive. I don't see why these authors would all go for option 2 if they are equivalent.
I'm not 100% sure of this, but I've heard that it is possible prove the existence of such topology in [itex]\mathcal{D}[/itex], that the convergence [itex]\psi_n\to\psi[/itex] in that topology is equivalent with this definition that you described here. When [itex]\mathcal{D}[/itex] is equipped with such topology, then the standard collection of distributions [itex]\mathcal{D}^*[/itex] can be defined according to the definition of topological dual.
  • #42
meopemuk said:
In my understanding, the reason why standard Hilbert space formalism is not suitable for QM is rather simple. Let's say I want to define an eigenfunction of the momentum operator. In the position space such an eigenfunction has the form (I work in 1D for simplicity)
[tex]\psi(x) = N \exp(ipx)[/tex]
where [tex]N [/tex] is a normalization factor. This wavefunction must be normalized to unity, which gives
[tex] 1 =\int \limits_V |\psi(x)|^2 dx = N^2V[/tex]
where [tex]V[/tex] is the "volume of space", which is, of course, infinite. This means that the normalization factor is virtually zero
[tex] N = 1/\sqrt{V}[/tex]
While I have understood this problem, it has not yet become clear to me how this problem is supposed to be solved in a more sophisticated formalism. The only solution that I have understood so far is this:
jostpuur said:
If we ask a question that what is the probability for a momentum to be in an interval [itex][p_0-\Delta, p_0+\Delta][/itex], we get the answer from the expression
[tex]
\frac{1}{2\pi\hbar} \int\limits_{p_0-\Delta}^{p_0+\Delta} |\hat{\psi}(p)|^2 dp.
[/tex]
I'm not convinced that it is useful to insist on being able to deal with probabilities of precise eigenstates. Experimentalists cannot measure such probabilities either.
Avodyne said:
I don't see why it's necessary to go beyond Hilbert space. Rather than defining a position operator, we could define projection operators with eigenvalue 1 if the particle is in some particular volume V, and 0 otherwise; heuristically, these would be
[tex]P_{x\in V} \equiv \int_V d^3\!x\,|x\rangle\langle x|[/tex]
Similarly for a volume in momentum space. Then, instead of defining a hamiltonian whose action could take a state out of the Hilbert space, we could define a unitary time evolution operator.
I'm not convinced that the distributions are very useful. The distributions are usually defined by using rather strange topologies or norms. The Swartz norm seems to be totally different from the original idea of a Hilbert space norm. However, the Hilbert space norm is highly relevant for the probability interpretation. How are we supposed to deal with quantum mechanical probabilities if the Hilbert space norm has been replaced with some of these distribution norms?
  • #43
Ahh, excellent point. Yes, that's what I meant. I get it now. (I didn't until I read your post). Delta functions wouldn't be bounded (and therefore not continous) linear functionals if we go for option 1. For delta to be bounded, there must exist M>0 such that
[tex]|\delta f|\leq M\|f\|[/tex]
for all test functions f, but the inequality is equivalent to
[tex]\frac{|f(0)|}{\|f\|}\leq M[/tex]
and we don't have to look hard to find an f that violates this. Even some constant functions will do. For example, define fr(x)=1 when |x|<r, and fr(x)=0 outside that region. Now shrink that region (i.e. choose a smaller r) until the norm of fr gets small enough to violate the inequality.
  • #44
I don't think the construction of such a topology is very difficult. It would be harder to prove that the result is equivalent to what we already have, but even that looks doable. (I'm not sure I care enough to give it a try though :smile:).
We can e.g. define a subset of [itex]\mathcal D[/itex] to be open if it can be expressed as [itex]T^{-1}(U)[/itex] where U is an open subset of the complex numbers, and T is continuous in the sense defined above.
Alternatively, I think we can define a subset E of [itex]\mathcal D[/itex] to be open if for every sequence in [itex]\mathcal D[/itex] that converges to a a point in E (in the sense defined above), E contains all but a finite number of members of the sequence.
I'm guessing that these definitions are adequate (in the sense that they both define a topology on [itex]\mathcal D[/itex]), and equivalent (in the sense that those topologies are the same), but I haven't made any attempt to prove it or disprove it.
  • #45
Yes, that defines the "T-weak" topology on [itex]\mathcal D[/itex]. (Weak topologies are
defined implicitly/indirectly by a demand that a certain set of functions be continuous
under it.)
I don't follow this. If you haven't yet specifed a topology on [itex]\mathcal D[/itex]
then there's no meaning in the statement that a sequence of elements of
[itex]\mathcal D[/itex] "converges". But maybe I misunderstood and you
meant something else?
  • #46
The discrete part of the spectrum doesn't pose the same difficulties as encountered
with the continuous part. One has a resolution of unity as usual, consisting of an
integral over the continuous part, plus a sum over the discrete part. Rigged Hilbert
space and the nuclear spectral theorem give meaning to the continuous part.
(Not sure whether that's what you were asking, though.)
BTW, for anyone who's still a bit perplexed about the role of all this
rigged Hilbert space stuff, I noticed this pedagogical introductory paper:
Rafael de la Madrid,
"The role of the rigged Hilbert space in Quantum Mechanics",
Available as: quant-ph/0502053
It's written in a very physicist-friendly way, using the example of a rectangular
potential barrier to make everything concrete. It also explains the connections
between the bras and kets of rigged Hilbert space theory and distributions
quite clearly (while minimzing the heavy pure math that probably turns some
people off).
  • #47
You understood me right. We define convergence of sequences first, and use that to define the topology. Convergence is defined as in post #35. I got that definition and the idea that it defines a topology on the test function space from the Wikipedia article on distributions. This is a direct link to the relevant section. Note in particular the sentence "It can be given a topology by defining the limit of a sequence of elements of D(U)." Unfortunately, Wikipedia doesn't say how the definition of convergence defines a topology. That's why I came up with those two guesses about how it can be done.
  • #48
Thanks. I have read the first 9 pages now, and I'm very pleased with it so far. I'm definitely going to read the rest later.
  • #49
I found a review of Maurin's books, and the reviewer is complaining a lot about how careless Maurin's presentations are. Link. I'm guessing it would be better to try to find the original articles than to read his books.
  • #50
Fredrik said:
strangerep said:
For QFT in infinite-dimensions, even the rigged Hilbert space is not big enough.
The singular behaviours arising from the interaction terms in the Hamiltonian
become far more pathological than mere delta distributions.
Interesting...and strange. The strange part is that we can actually make predictions in spite of all of this.
I thought I'd add a bit to this since it's very interesting.
As you know the Hilbert Space for 1 particle spin-0 QM is [itex]L^2(\mathbb R^3, dx)[/itex]. Where dx is the Lesbesgue measure.
[itex]\mathbb R^3[/tex] coming from the fact that a particle can occupy any point in three dimensional space. So the set of all points [itex]\mathbb R^3[/tex] is the classical configuration space.
For Quantum Field Theory the classical configurations are the set of all possible field configurations. This set turns out to be [tex]\mathcal{D}^*(\mathbb R^3)[/tex], the space of distributions. So the Hilbert space of QFT is:
[itex]L^2(\mathcal{D}^*(\mathbb R^3), d\nu)[/itex], the space of square integrable functions over the space of distributions with respect to some measure [itex]d\nu[/itex]. A free QFT and an interacting QFT differ by their choice of [itex]d\nu[/itex].
Quantum Fields [itex]\phi(x)[/itex] are then objects that when integrated against a function [itex]f(x)[/itex] give an object [itex]\int{\phi(x)f(x)}dx = \phi(f)[/itex], which is an unbounded operator on [itex]L^2(\mathcal{D}^*(\mathbb R^3), d\nu)[/itex].
Who said rigorous QFT was hard?
  • #51
OK, thanks. I think I get it now.
The key item is the use of uniform convergence. E.g., given two functions f,g it's
sensible to ask how "close" they are to each other, as follows: If we can say that
[itex]|f(x) - g(x)| < \epsilon[/itex] for all x, then [itex]\epsilon[/itex] is an expression
of the closeness of f and g (independently of x).
So one could define open sets in a manner reminiscent of open balls in a metric
topology: pick a function f and a "radius" r and then say that one particular
open set centered on f, of radius r, is all the other functions g s.t. [itex]|f(x) - g(x)| < r[/itex]
for all x. Then take unions, etc, to get a full topology.
Uniform convergence just extends this idea to sequences, the crucial bit
being how it's independent of x.
The fact that it's expressed in terms of arbitrary derivatives is just because we
want to deal with infinitely-differentiable functions only, and is a bit a red-herring
when one is focusing just on topological matters.
  • #52
Hmmm, that reviewer uses rather savage language, but I have to say I agree with
his remarks about lack of care. I noticed the same thing as soon as I started to
try and follow Maurin's proof of the nuclear spectral theorem. I had to keep flipping
backwards tediously to double-check notations, often finding things that I felt
sure were typos. Worse, even though the book came with an errata list at the
back, I had trouble matching it with what was in the text(!) (sigh).
Look's like I'll have to try harder to obtain a copy of Gelfand & Vilenkin and
see whether their presentations is any better.
TBH, I'm quite surprised and disappointed that I couldn't find a clear pedagogical
proof in a more modern text, given it's importance in modern quantum theory.
to read his books.
Dunno. Original papers tend to be written for people with a greater level
of knowledge. Books are supposed to be for lesser mortals.
  • #53
DarMM said:
I thought I'd add a bit [...]
Hmmm, thanks for joining this thread. You just made me think about
a couple of things from a direction I hadn't explored adequately...
I guess this gets into the problematic area of "multiplication of distributions"?
I hope you can say a bit more about that.
Let me see... in the simpler case of rigged Hilbert space, translating into
Dirac bra-ket notation, we have
[tex]
\phi(f) ~=~ \int{\phi(x)f(x)}dx ~=~ \langle\phi| \int{|x\rangle\langle x|}dx ~ |f\rangle
~=~ \langle \phi | f\rangle
[/tex]
with
[tex]
\langle x|x'\rangle ~=~ \delta(x - x') ~,~~~\mbox{etc.}
[/tex]
So in the more general case we're dealing with functions over distributions (which
involving products of distributions in general), and then trying to figure out
how to construct (higher-order?) functionals over these functions?
  • #54
Yes, in fact it's one of the big issues in rigorous QFT. Your question below will naturally lead to it.
Let me give a simple example of a function over distributions.
As you know a distribution [itex]T(x)[/itex] is a continuous linear functional over the space of test functions [itex]\mathcal{D}[/itex]. However one can reverse this and consider a test function [itex]f[/itex] as a function on distributions. A given test function [itex]f[/itex] maps any distribution [itex]T[/itex] to [itex]T(f)[/itex], resulting in a map over the whole space of distributions.
[itex]f:\mathcal{D}^*(\mathbb R^3) \rightarrow \mathbb R[/itex].
So one writes this function over distributions as [itex]f(T)[/itex]. One can then immediately arrive at more general functions for instance:
[itex]f(T)g(T)[/itex]
[itex]f(T)g(T)h(T)[/itex]
or [itex]e^{f(T)}[/itex]
Since one can choose a any test function, this results in an enormous space of functions over Distributions.
In the case of a free quantum field, the quantum field operator acts as a "multiplication operator". For example:
[itex]\phi(g) = \int{\phi(x)g(x)}dx[/itex]
Then,
[itex]\phi(g)f(T) = g(T)f(T)[/itex]
The conjuagate momentum field [tex]\pi(x)[/tex] acts like the momentum operator from regular QM by being a derivative. In rough language:
[itex]\pi(x)f(T) = -i\frac{\delta}{\delta T}f(T)[/itex]
The Hamiltonian is composed of [itex]\pi(x)[/itex] and [itex]\phi(x)[/itex] and so it acts in a natural way.
Like all quantum mechanical theories though, we don't allow just any functions, but only square integrable ones. So one requires a notion of integration for this functions, formally something like:
[itex]\int{f(T)}dT[/itex]. This can be done, although the details are a bit involved. For the purpose of the remainder of this post let's assume we have done this for the free theory. We have the correct measure [itex]dT_{free}[/itex], the Hilbert space of square integrable functions with respect to it and the Hamiltonian, field and conjugate momentum operators acting in the way I described above. This space is basically Fock space.
However when one comes to [itex]\phi(x)^4[/tex] theory for example, the Hamiltonian gains an additional term:
[itex]\int{\phi(x)^4}dx[/itex]
It is very difficult to know exactly how one should interpret this.
[itex](\int{\phi(x)^4}dx)f(T) = ?[/itex]
There are two problems here. [itex]\phi(x)[/itex] is a operator valued distribution. When integrated it gives operators on [itex]L^2(\mathcal{D}^*(\mathbb R^3), dT_{free})[/itex]. Due to its distributional nature no sense can be made of [tex]\phi(x)^4[/itex]. One could attempt to come up with some way of powering distributions, however this powering system must respect the fact that [itex](\int{\phi(x)^4}dx)[/itex] is meant to be a linear operator and respect certain commutation relations.
Let's approach this problem first in two dimensions then in three dimensions.
Two dimensions
It turned out (again avoiding details) that there was one unique notion of powering which respects the structure of [itex](\int{\phi(x)^4}dx)[/itex] as a quantum operator. This notion was actually already known to physicists as Wick ordering. So we replace:
[itex](\int{\phi(x)^4}dx)[/itex] with [itex](\int{:\phi(x)^4:}dx)[/itex].
One can then prove that the full Hamiltonian is self-adjoint and semi-bounded (stable, no negative energy), the time evolution operator is unitary, e.t.c. Everything one wants from a QFT basically. This was done by James Glimm and Arthur Jaffe in the period 1968-1973.
Three dimensions
Here things get significantly harder. Where as one can put the proof of the two dimensional case into a semester long graduate course, the proof of the three dimensional case is a monster. However let me paint a picture.
Basically we try what we did before and replace [itex](\int{\phi(x)^4}dx)[/itex] with [itex](\int{:\phi(x)^4:}dx)[/itex]. However one finds that this does not result in the full Hamiltonian being a self-adjoint operator. If you are very clever you can prove that this problem can not be overcome, unless you leave [itex]L^2(\mathcal{D}^*(\mathbb R^3), dT_{free})[/itex], that is leave Fock space and move to another space of square integrable functions over distributions. Let me call it:
[itex]L^2(\mathcal{D}^*(\mathbb R^3), dT_{Glimm})[/itex].
However finding this space is incredibly diffcult, so one uses the condition that on this correct space the physical mass of a particle should be finite. This condition show you how to get to this new space. Basically, cutoff the fields so that you do the analysis in a more clear cut way, then use the condition of finite mass. This condition tells you that you should add the term:
[itex]\delta m^2(\int{:\phi(x)^2:}dx)[/itex]
to the Hamiltonian. The [itex]\delta m^2[/itex] is a constant that will go infinite when the cutoff is removed, whose explicit form is given by the finite mass condition. As the cutoff is removed, this extra term does the job of "pushing" us into the correct space [itex]L^2(\mathcal{D}^*(\mathbb R^3), dT_{Glimm})[/itex], which is a lot easier than finding it abstractly. Physicists will know this procedure as mass renormalization.
We then take the remove the cutoff. James Glimm proved that this moves us into the correct space and that the full Hamiltonian is self-adjoint there. Glimm and Jaffe later proved that the Hamiltonian is also semibounded (in what is considered the most difficult paper in mathematical physics, lots of heavy analysis). Shortly after came all the the other properties one wants, Lorentz invariance, e.t.c.
Thus proving the rigorous existence of [itex]\phi^4[/itex] in three dimensions.
As you can imagine the four dimensional case is extremely difficult. For five dimensions and greater, Jürg Fröhlich has shown that there is no space where the [itex](\int{\phi(x)^4}dx)[/itex] term makes sense, unless you set the interaction to zero, that is make it free.
People have also shown the existence of Yukawa theories in two and three dimensions, as well as gauge and Higgs theories in two and three dimensions. Tadeusz Balaban has gotten pretty far although with Yang-Mills theory in two and three dimensions. He has even gotten some results for the four dimensional case.
One final thing I wish to emphasize is that renormalization is not the difficulty in rigorous quantum field theory. Renormalization is a necessary technique, as it has been known for a long time the most interacting theories simply cannot live in the same space as the free theory (Haag's theorem).
The actual difficulty is with standard analytic stuff, proving convergence and obtaining estimates which tell you something about a limit besides the fact that it exists.
I hope this helps.
  • #55
I'm really confused by this. I thought the Hilbert space of (say) Klein-Gordon theory was supposed to be the Fock space constructed from the Hilbert space H1 of one-particle states, which is defined as the subset of [itex]L^2(\mathbb R^3)[/itex] that consists of square-integrable positive-frequency solutions of the Klein-Gordon equation. Is this wrong, or just another way of saying the same thing? Note btw that a square-integrable solution of the field equation must be continuous, because its partial derivatives must exist, so this H1 isn't [tex]L^2(\mathbb R^3)[/tex]. It's just a "small" subset of it.
I don't understand why the space of distributions is the classical configuration space. Can you elaborate on that?
Also, if it's possible to explicitly write down the measure of the free theory and explain why it's the right one, I'd appreciate it.
Some moron probably :smile:
Seriously, I think it's hard just to find out where you can learn this stuff. I took three classes on quantum mechanics and two on quantum field theory at my university, and they didn't say anything about these things. (They mentioned the word "distribution" and said that you can use that concept to make sense of the delta function, but that's where they stopped).
I don't understand what you're saying about these "more general" functions. Isn't f(T)g(T) defined as (fg)(T) and exp(f(T)) as [itex]\exp\circ f(T)[/itex]? In that case, how are they more general? The product of two test functions is another test function. Same thing with compositions.
I'll stop here because it seems dumb to ask about advanced stuff when I'm still struggling with the "easy" stuff.
  • #56
It's just another way of saying the same thing. [itex]L^2(\mathcal{D}^*(\mathbb R^3), d\nu)[/itex] can be decomposed quite easily into direct sums of tensor products of square-integrable positive-frequency solutions of the Klein-Gordon equation. However in rigorous QFT this is sometimes avoided because for interacting theories the Hilbert space [itex]L^2(\mathcal{D}^*(\mathbb R^3), d\nu)[/itex] is not a Fock space over positive-frequency solutions.
Basically you know from QM that the Hilbert space is the square integrable functions over the classical configuration space. It is of course difficult to know what this space should be, when does a given function count as a sensible classical configuration. However it turns out that if you start with any set of functions, in order to define a measure on this space you'll have to make the space larger to the point where it encompesses distributions. If you choose a larger space of functions it turns out that a lot of the space has measure zero, except the subspace of distributions. So either way no matter how big or small a space you pick it has to be the space of distributions.
Fredrik said:
I don't understand what you're saying about these "more general" functions. Isn't [itex]f(T)g(T)[/itex] defined as [itex](fg)(T)[/itex] and [itex]exp(f(T))[/itex] as [itex]\exp\circ f(T)[/itex] In that case, how are they more general? The product of two test functions is another test function. Same thing with compositions.
I was unclear before, [itex]f(T)g(T) \neq (fg)(T)[/itex]. It's actually simpler, you just evaluate [itex]f(T)[/itex] and [itex]g(T)[/itex] and then multiply them.
By more general functions I just meant I can define more functions than only the linear ones.
Why it's the right one is easy. Basically instead of defining the free theory on continuous spacetime, put it on a lattice. On the lattice you can find the correct measure easily, since you're now back in a system of finite degrees of freedom. It's basically just [itex]L^2(\mathbb R^n)[/itex] with [itex]n[/itex] a very large number equal to the number of lattice points. If you take the limit as the lattice returns to a continuum you'll get the free theory measure I'm talking about.
You can also solve the Klien-Gordon equation to obtain the free field and work out the generating functional for the theory. If you have the generating functional then by a theorem called Minlos theorem, you know there exists a measure on the space of distributions which reproduces this generating functional and this the correct measure.
I'll define the measure in my next post, however you actually already know the measure and how to integrate with it.
  • #57
Thank you DarMM. This is good stuff, and very interesting. Maybe you can also tell me what I would have to read to learn this stuff?
  • #58
Strangerep, I skimmed the rest of the RHS article that you recommended. The interesting stuff was on the pages I had already read, so I didn't study the details of his specific example. One thing in particular that I had failed to understand before I read his paper is that the RHS definition of a ket is as an anti-linear functional on the nuclear space. (Is that the correct term for [itex]\Omega[/itex]?)
I liked his motivation for the definition of [itex]\Omega[/itex]. Short version: If we define a position operator [itex]Q:D(Q)\rightarrow H[/itex] by Qf(x)=xf(x) for all x, then its domain can't be all of H, because Qf is only square integrable if
[tex]\int|xf(x)|^2\ dx < \infty[/tex]
So the idea is to find a subspace of H on which the entire algebra of operators generated by Q,P and H (including operators of the form [itex]Q^iP^jH^k[/itex] where i,j,k are arbitrary positive integers) is well-defined.
One thing that still seems weird to me is that people keep claiming that you need the RHS approach specifically to motivate bra-ket notation. I mean, all the problems that the RHS stuff is supposed to solve are there even if you don't use bra-ket notation. The first QM book I studied didn't use bra-ket notation, and it still pretended that Q and P had eigenvectors. It just ignored the fact that plane waves aren't square integrable and that delta functions aren't even functions.
If you ignore those problems, the Riesz representation theorem is all you need to justify the notation. We can define a ket to be a member of H, and a bra to be a member of H*. The bra written as [itex]\langle f|[/itex] is the linear functional [itex]|g\rangle\mapsto(|f\rangle,|g\rangle)[/itex].
  • #59
Fredrik said:
[...] the RHS definition of a ket is as an anti-linear functional on
Yes, what I wrote earlier as [itex]\Omega[/itex] is a nuclear space. In the paper
quant-ph/0502053, the author denotes it as [itex]\Phi[/itex] instead.
Precisely. We want a representation of the enveloping algebra of observables,
and/or the full Lie group (not just the basic Lie algebra).
is supposed to solve are there even if you don't use bra-ket notation. [...]
Yes. It would be clearer to say "...motivate the use of Dirac's improper eigenvectors of
position and momentum...". I.e., to be able to write (eg)
[tex]
1 ~=~ \int\!\! dx ~ |x\rangle\langle x|
[/tex]
and have it actually mean something.
If you ignore those problems, the Riesz representation theorem is all you need to justify the notation. We can define a ket to be a member of H, and a bra to be a member of H*. [...]
Yes, up to a point, but note that H is self-dual, i.e., H is isomorphic to H*.
So we don't really see the problems until unbounded operators are in play.
P.S., I finally got hold of the books by Gelfand and Vilenkin: "Generalized Functions
vol 4 -- Applications of Harmonic Analysis." Also vol 5. After some cursory reading
it looks better than Maurin's book. (Possibly because the G-V book was originally
Russian and then translated by a technically competent person. I.e., more people
have been over it with a fine tooth comb.)
P.P.S., Looks like you started are really good thread. Several days later, I'm still
trying to relate the stuff DarMM said with what I already know about QFT. :-)
  • #60
Yes, this has been a good discussion. I have learned a lot from it. :smile:
I'm still confused though, and I'd like to go back to the simplest possible QM theory for a while. (See the thread title). How can we state its axioms in a way that makes sense? They are usually stated in a way that ignores all the complications. Something like this:1. The possible states of a physical system are represented by the unit rays of a separable Hilbert space over the complex numbers, on which there exists a self-adjoint operator H called the Hamiltonian.
2. The time evolution of an isolated system which is initially in state F is given by f(t)=exp(-iHt)f, where f is any vector in the ray F.
3. Measurable quantities are represented by self-adjoint operators. Self-adjoint operators are therefore called "observables". If a system is in state F when a measurement of an observable B is performed, the state of the system will change to state |b> (an eigenvector of B with eigenvalue b) with probability |<f|b>|2, where f is any vector in F. The result of a measurement of B that leaves the system in state |b> is b. This is actually a less sloppy formulation than the ones that were shown to me when I first studied QM, but there are many flaws here. These are some of my thoughts:
* If we're dealing with the QM of one spin-0 particle, we can be more specific in axiom 1 and say that the Hilbert space is L2(R3) rather than just some Hilbert space. On the other hand, since all separable infinite-dimensional Hilbert spaces are isomorphic to each other, it doesn't really matter. Maybe we should at least add the requirement that the Hilbert space is infinite-dimensional.
* Instead of postulating the existence of the Hamiltonian directly, we should be postulating that we're dealing with an irreducible representation of the covering group of the Galilei group. Actually, now that I think about it, once we start talking about representations, the axioms of non-relativistic QM of one spin-0 particle aren't significantly more complicated than the the axioms of special relativistic QM of one particle with arbitrary spin, so we might as well go for a slightly more general set of axioms (but stick with one-particle theories for now).
* Axiom 2 can be dropped from the list, since it's implicit in the definition of the Hamiltonian as the generator of translations in time. That doesn't mean that we delete axiom 2. We just reinterpret it as the definition of an "isolated system".
* Axiom 3 is still giving me a headache. It ignores several important issues, including: a) An observable can have several eigenvectors with the same eigenvalues, b) Position and momentum aren't even observables if we define them as self-adjoint operators on the Hilbert space, c) If we generalize the definition of observables to densely defined operators, some observables don't have eigenvectors, d) A generalized observable may have a continuous spectrum, a discrete spectrum, or a combination of both.
* The first of those issues seems easy enough to deal with. Axiom 3 above is equivalent to saying that a density operator ρ changes to ∑b Pb ρ Pb when we measure B. (Sorry, LaTeX doesn't work). Here Pb=|b><b|, but if we instead define Pb to be the projection operator onto the eigenspace of B corresponding to eigenvalue b, then (I think) the the same rule holds even when the spectrum of B is degenerate.
* The C*-algebra approach seems unnecessarily radical for the one-particle theories. You (Strangerep) suggested that we need this approach in those cases where we can't take all self-adjoint operators to be observables, and Mackey's book seems to be saying that this happens if and only if the theory includes a superselection rule (and one-particle theories don't). Hm, I guess that means that we should be using this approach when we get to SR QM of N non-interacting particles of arbitrary types.
* There probably is no real need for the RHS approach either, but I think I might prefer to use it anyway, mostly because it clearly states which subspace represent the physical states. But I'm not sure yet if using a RHS will make the axioms less awkward, or more awkward.
I'm going to post an improved version of the axioms, but I'll do that later (probably tomorrow). I still have to think some more about some of the details. If someone wants to suggest a better way to express axiom 3 in the meantime, feel free to do so. :smile: It's the only one that I'm still having problems with.
  • #61
Hm, I might as well post what I have right now, even though I still haven't solved all the problems. It should make it easier for others to suggest improvements.
1. The possible states of a physical system are represented by the unit rays of an infinite-dimensional separable Hilbert space H over the complex numbers.
2. Let O and O' be two inertial observers, and let S and S' be the inertial frames naturally associated with their motion. Let g be the Galilei transformation that represents a coordinate change from S to S'. If O describes an isolated system as being in state F, then O' must describe the system as being in the state that contains the vector f'=U(g)f, where f is any vector in F and U:G→GL(H) is an irreducible unitary representation of the covering group of the Galilei group.
3. The physical states are represented by the unit rays of the nuclear space N generated by the U(g) operators (i.e. the space N that's invariant under any product of a finite number of U(g) operators). Measurable quantities are represented by self-adjoint operators on N. These operators are therefore called "observables". If a system is in state F and a measurement of an observable B is performed, the state of the system will change according to ρ → ∑b Pb ρ Pb
Axiom 2 is a bit awkward, but at least it defines momentum and spin as well, in addition to the Hamiltionian. Maybe position too, but I still don't quite get that part. I also realize now that I don't quite understand the significance of using the covering group instead of the Galilei group itself. I said that g is a Gallilei transformation, so what do we make of the expression U(g)? I mean, there are two members of G corresponding to each g, so which one of them do we use? It probably doesn't matter, but something should be said about this in the axiom.
Axiom 3 still isn't able to deal with continuous spectra, so it needs to be changed.
  • #62
It's probably cleaner to start with the dynamical group as an axiom --
in your case Galilei. But when one tries to add a position operator, so
that one has a "Heisenberg-Galilei" group, one finds that the position
operator has to be a multiple of the Galilean boost operator. (See
Ballentine pp66-84). (The relativistic case is more problematic, of
course.)
But let's assume you start with the Heisenberg group, and require a
unitary irreducible representation thereof. A short proof then shows
that a finite-dimensional Hilbert space can't work, so you're forced to
inf-dim. That pretty much pushes you to L^2(R^3) (assuming you want 3
configuration degrees of freedom), or something that generalizes it. So
I don't think you need to postulate a specific Hilbert space. Simply
choosing a dynamical group and requiring unitary irreducible
representation(s) thereof is enough. Since some of the operators are
unbounded, that forces us to rigged Hilbert space (at least). I.e., we
want a rigged Hilbert space that carries a faithful irrep of a chosen
dynamical group.
Then, maths alone (spectral theorem) tells us that the space (and
indeed arbitrary operators on the space) can be decomposed in terms of
eigenspaces of a self-adjoint operator. Each such eigenspace
corresponds (via the associated eigenvalue) to a possible measurement
outcome. (This is why we chose self-adjoint operators: they have real
eigenvalues. We could have used more general operators if complex
eigenvalues were ok.) If we can find another (different) self-operator
that commutes with the first, we can further decompose each eigenspace.
And if we can find a *complete* set of commuting self-adjoint
operators, we can decompose right down to eigenvectors. All this pretty
much follows from having a (rigged) Hilbert space, hence need not be
explicit in the axioms.
So you don't really need axiom 3 in its current form (since the
spectral theorem also decomposes any operator in terms of projection
operators). You just need to say something about how states correspond
to density operators (and particular measurements to projection
operators).
Position is easy enough in Galilei. (Do you have a copy of
Ballentine yet? :-)
But I've never much liked the way position tends to be grafted
on as an afterthought.
More generally, one needs to start from a symplectic formulation (i.e.,
symplectic group on phase space), since that brings in non-trivial
dynamics, interactions, etc. But then one must use something like
Weyl-Wigner-Groenewold-Moyal quantization to establish a satisfactory
correspondence between phase space functions and quantum operators.
People continue to research this.
It helps you construct representations corresponding to
half-integral spin.
You could perhaps say that g is a member of covering Galilei.
  • #63
Thank you for another good answer. You've been more helpful to me already than my advisor for my M.Sc. thesis ever was. :smile:
I'm not sure what you mean. If you meant that I should use the Galilei group instead of its covering group, we wouldn't be able to let U be a representation. I'm sure you know about the annoying minus sign that we can't get rid of: U(g)U(h)=±U(gh).
If you meant that I should drop that stuff about coordinate systems, I don't think that's a good idea. The physical intepretation of the U(g) operators must be included in the axioms in one way or another, and it might as well be this way.
course.)
I guess I'm going to have to start reading Ballentine at Google Books. Amazon.com says "Shipped on April 22, 2009" and "Delivery estimate: May 19, 2009". Unbelievable. I'll probably start tomorrow.
operators).
Maybe I'm saying too much, but some version of the rule ρ → ∑b Pb ρ Pb must be included, and it should be a version of it that can handle both discrete and continuous spectra.
Unfortunately I don't know those spectral theorems. I still have a lot of functional analysis to read.
This something I've never heard of, but it sounds interesting.
half-integral spin.
Yes, I understand that part. I was referring to some of the finer details, in particular, if h and h' are the two members of the covering group that correspond to the Galilei transformation g, are U(h)f and U(h')f in the same ray? I'm guessing that the answer is yes, and that U(h')f=±U(h)f.
Yes, but I also have to say which member it is, or rather which two members it is. Something like this:
2. Let O and O' be two inertial observers, and let S and S' be the inertial frames naturally associated with their motion. Let g be the Galilei transformation that represents a coordinate change from S to S'. If O describes an isolated system as being in state F, then O' must describe the system as being in the state represented by the ray F' that contains the vector f'=U(h)f, where f is any vector in F, U:G→GL(H) is an irreducible unitary representation of the covering group of the Galilei group, and h is either of the two members of G that the covering homomorphism takes to g.
  • #64
Hmmm. Now I not sure what's actually bugging you about this (and also the related
stuff near the end of your post). You're talking about the double-valuedness that arises
from the presence of SO(3) inside Galilei, right? If so, then I don't think this is an issue
if you're restricting to spin-0. But maybe it's better to have a mega-space containing
all spins, and then restrict attention to spin-0. The sign ambiguity arising from 2\pi
rotations is then handled more cleanly: one just finds all unitary irreducible representations
of SO(3), then discovers superselection rules between states of integer and half-integer
spin. (But maybe I've misunderstood what's bugging you?)
Standard shipping, huh? Maybe it will arrive sooner.
operators).
That's part of what I meant by correspondence between measurements and
projection operators.
analysis to read.
The spectral theorem allows you to replace the sum by an
integral. The main content of the theorem is proving that a "projection-valued
Lebesgue measure" exists, making the integral mathematically meaningful.
For mixed spectra you have two terms, one with an integral plus one with
a sum.
About the rest of your post,... maybe we should wait until you have a copy
of Ballentine in front of you.
  • #65
Yes.
I realize now that I didn't make myself clear earlier. What I eventually decided to do was to try to write down the axioms of the non-relativistic quantum theory of one particle with arbitrary spin, in such a way that all we have to do to get the special relativistic theory later is to replace "Galilei" with "Poincaré".
It's just that if we have U(g)U(h)=±U(gh), then U isn't a representation. I'd rather talk about a "representation" than a "projective representation" in the axioms. That's why I picked the covering group instead of the group itself.
Expedited shipping actually. That's why it's so ridiculous.
Is that the spectral theorem that can only be found in two out of print books, one of which is badly written? :smile:
That's fine with me.
  • #66
OK, good idea. In that case, the eigenspaces of J^2 corresponding to different total spin
don't mix under the group action, so it's cleaner when talking about integer vs half-integer
spins. It's also an excellent way to show how superselection rules can arise from one's
original choice of group.
OK.
about a "representation" than a "projective representation" in the axioms. [...]
Ah, now wait a minute... that phase ambiguity which enters in a projective representation
is a distinct issue from the double-valuedness of half-integer spin reps. In a projective
unitary rep, we can have U(g)U(h) = e^{ia} U(gh). At the Lie algebra level, this is the
same as adding a multiple of the identity to the right hand side of all the commutation
relations. However, in some cases it can be shown that these multiples must be 0 (using
consistency arguments from the Jacobi identity, etc). In other cases, it can be shown that
the phase has no physical effect, so the multiple can be chosen as 0. For Galilei, however, it
turns out there's one case where it can't be removed in either of these ways. Comparison
with classical mechanics then shows that this remaining central element should be
interpreted as mass.
For Lorentz/Poincare, it turns out that the phase can always be set harmlessly to 1.
No. To get the idea, any respectable book on Functional Analysis should have it.
Look for a spectral theorem concerning (noncompact) bounded Hermitian-symmetric
operators on an (ordinary) inf-dim Hilbert space.
I'm halfway through writing a summary paper (originally intended for personal
use only) which states and proves all the spectral theorems, in increasing order
of difficulty. Now I'm thinking I should eventually post some version of it in the
tutorial forum. I wonder if I'll ever finish it sufficiently.
  • #67
strangerep said:
It's also an excellent way to show how superselection rules can arise from one's original choice of group.
I agree. (I assume that you're talking about using the Galilei group instead of its covering group, because as I understand it, the superselection rules have to be imposed as an axiom if we don't. Hm, that is a reason to use the Galilei group instead of the covering group).
I don't think so. But maybe I just don't understand what you mean by double-valuedness. This is what I'm thinking: SO(3) is isomorphic to SU(2)/Z2. SU(2) can be mapped continuously and bijectively onto S3 (a 3-sphere). So SU(2) can be interpreted as a 3-sphere, and SO(3) can be interpreted as a 3-sphere with opposite points identified, or equivalently, as the set of straight lines through the origin in R4. This means that SO(3) isn't simply connected, but SU(2) is.
Now Wigner's theorem about symmetries says that given a simply connected symmetry group G (i.e. a group of functions that map the set of rays of the Hilbert space H bijectively onto itself), we can find a map U:G→GL(H) such that U(g) is either linear and unitary for all g in G or antilinear and antiunitary for all g in G, and U(g)U(h)=U(gh) for all g,h in G.
As I understand it, when G=SO(3), there's no U:G→GL(H) with these properties, and it can be traced back to SO(3) not being simply connected. The best we can do is to find a set of operators that satisfy an identity that is sometimes written as U(g)U(h)=±U(gh), but even that is being really sloppy with the notation. The truth is more complicated:
I'll use the notation h→g to represent a continuous curve from h to g. The best we can do when G=SO(3) is to find a set
{U(h→g) in GL(H) | h,g in G}
such that each U(h→g) is linear and unitary and
U(h→gh)U(e→h)=(-1)f(e→h,h→gh,e→gh)U(e→gh)
where f(e→h,h→gh,e→gh)=0 when the curve constructed by joining the three curves e→h, h→gh and the "reverse" of e→gh to each other can be continuously deformed to a point, and f(e→h,h→gh,e→gh)=0 otherwise. (What I mean by the "reverse" of a curve C:[0,1]→G, is the curve B:[0,1]→G defined by B(t)=C(1-t) ).
My main concern here is that the notation "U(g)" is inappropriate when G=SO(3), because the domain of U isn't G. It's a set of curves in G.
So the bottom line is that if we take the symmetry group to include SU(2), we have to impose superselection rules manually, and if we take it to include SO(3), we have to use a very awkward notation, or be intentionally sloppy with the notation. Both of these things are undesirable, but the first is easier to deal with, I think.
I got this idea from Weinberg, who seems to have gotten it from Streater & Wightman, or maybe directly from Wigner.
strangerep said:
In a projective
I'm definitely going to learn this stuff, but I'm going to be a bit busy the next few days.
If you do, you could probably publish it in some sort of review journal. I'm sure it would be interesting to other people as well. I would definitely read it.
  • #68
Fredrik said:
[...] phase ambiguity which enters in a projective representation
I don't think so. ...
I'll try to clarify. (If you have a copy of Weinberg vol-1, this is in section 2.7 on
Projective Representations.) In fact, it's probably simpler if I just quote Weinberg (p83-84).
The phase of any representation U(T) of a given group can be chosen so that \phi=0 [...]
if two conditions are met:
(a) The generators of the group in this representation can be redefined [...] so as to
eliminate all central charges from the Lie algebra.
(b) The group is simply connected [...]
I was talking about the redefinition of generators (which can always be done in
Poincare, but not in Galilei), whereas you were talking about simple-connectedness
(which must be considered in both cases).
... but I'm going to be a bit busy the next few days.
Yeah, I should try and get some more actual work done too. :-)
  • #69
Thanks, I had completely forgotten about (a). (And yes, I have a copy of Weinberg, vol. 1).
  • #70
Thank FSM that Amazon sucks at estimates. I picked up my Ballentine at the post office today. I actually got it two days ago, but the slip ended up in the middle of a pile of mail that I didn't look at right away. I have started to read it, and I can already tell it was a good buy. Lots of good stuff in there.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
