Which derivative rule is this?
  • Thread starter Xtensity
  • Tags
    Derivative
In summary: The "u" in the bolded step above went away because the derivative is taking the derivative with respect to y instead of u.
Xtensity
104
in that picture is a practice problem from a site I am using. I have highlighted the part of it that is confusing me.
In the picture, if f(u) = 2^u , then how does f ' (u) = (2^u)*ln(2) ?
I understand the chain rule aspect of the problem, but I have no clue where that "ln" came from or what rule that is. I understand ln is a natural log, which is Log Base e... though I have no idea why it was introduced into the problem as part of the deriavtive
I have been searching online for the past hour and can not figure this out.(I would be posting a question as simple as this on YahooAnswers, but YahooAnswers has stopped working for some reason =\)
I am not sure if there is name for it, but here is how it worked.
y=2u⇒lny=ln2u⇒lny=uln2
Differentiating both sides w.r.t. u
(1/y)dy/du=ln2 ⇒ dy/du= yln2. But y=2u.
In the end, we have
dy/du=2uln2.
Is that Ln interchangeable with Log? I used this other site for "Step by Step derivatives"
http://library.wolfram.com/webMathematica/Education/WalkD.jsp
It gave me
[PLAIN]http://library.wolfram.com/Explore/MSP/MSP019c0981if4bd1ch300006adhih2g0hfi65ed?MSPStoreType=image/gif&s=2
The only difference between that and the other site is Log vs Ln, which give 2 very different answers.
log is sometimes used to mean logarithm base 10 and sometimes used to mean natural logarithm. Basically, once you get to a certain point in math you decide that you never actually use log base 10 so you just use log to mean natural logarithm. In this case, wolfram uses log to mean natural logarithm
Er... would that not produce 2 totally different answers when graphed? I don't see how or why they would be used interchangeably. Log = Log base 10, and Ln = log base e?
No they aren't interchangeable functions, it's just that people use the term "Log" and "ln" interchangeably. Mathematica (what wolfram alpha is based off of) uses Log to mean natural log. If you really meant base-10 log, you'd specify it.
So if I were to use it in a graphing calculator, which one would I use Log or Ln? Since the calculator does not use Log or Ln interchangeably, on the calculator the defined functions are specific.
The calculator would use Log as log-10. If you ever actually see both options, then they're trying to distinguish between the two.
I know that... but I asked which one would I use for the correct derivative.
If I have 2^u and I want to plot the correct derivative, do I use (2^u)(ln(2)) or (2^u)(log(2))... because those 2 would result in 2 different graphs... and whichever one is used, why is it used over the other?
The correct one is ln(2). wolfram (and many mathematicians) uses the notation 'log' to denote 'ln' because logarithm base 10 is not commonly used.
Log=log base 10 on your graphing calculator, but it's not uncommon to find people using log to be log base e. Of course this is a different function from log base 10, but it's just something you'll have to watch out for
Ok I understand we use Ln... though I'm having issues with this earlier post:
In the end, we have
dy/du=2uln2.
What happen to the "u" in the bolded step above? I understand that d/dx ln(y) = 1/y... but on the other side, where did the u disappear to?
What is d/du u?
l'Hôpital said:
What is d/du u?
Is it? I only started teaching myself calculus 1-2 weeks ago so I'm not entirely sure on the rules of the d/dx operators, etc... Do they operate as fractions or? If anyone could provide a link to the rules on those operators that would be great.
Allow me to rephrase the question. What is the derivative of u with respect to u?
1... but if the derivative of u was taken, then why was the derivative of ln(2) not taken? Wouldn't the derivative of ln(2) = 1/2? Is there a rule for why that derivative isn't taken?
ln 2 is a constant. : )
So derivatives of constants aren't taken? If so, this is a rule I have never ran into :P
They are taken, it's just that they are zero. Generally, if
[tex]
f(x) = c
[/tex]
For some constant c, then
[tex]
f'(x) = 0
[/tex]
Surely you have run into this rule before! How would you derive things like 2u, 3u, 4u, etc.?
Ah yes that idea just dawned on me in my head, that they go to 0.
So why doesn't u*ln(2) turn into 1*0?
Because that's not how the product rule works.
Try the real product rule on c*f(x) and you'll see that you get the standard rule of pulling the constant out of the derivative
Ah I forgot about that... you know for some reason, the last 3 times I refreshed this thread, while the thread was loading the idea which I had forgotten just got posted :P
I think I have a better grasp of this, if I need any extra help I will post.
1. What is a derivative rule?
A derivative rule is a mathematical formula or algorithm that is used to calculate the derivative of a function. The derivative of a function represents the rate of change of that function at a specific point.
2. How do I know which derivative rule to use?
The specific derivative rule to use depends on the type of function you are trying to differentiate. Common derivative rules include the power rule, product rule, quotient rule, chain rule, and trigonometric rules.
3. What is the power rule for derivatives?
The power rule states that the derivative of a function raised to a constant power is equal to the constant multiplied by the original function raised to the power decreased by one. In other words, if f(x) = x^n, then f'(x) = nx^(n-1).
4. What is the chain rule for derivatives?
The chain rule is used to differentiate composite functions, which are functions that are made up of multiple functions. It states that the derivative of a composite function is equal to the derivative of the outer function multiplied by the derivative of the inner function.
5. Can I use more than one derivative rule in a single problem?
Yes, in fact, most problems will require the use of multiple derivative rules in order to find the final answer. It is important to carefully identify the different components of the function and apply the appropriate derivative rule to each component.
  • Calculus
  • Calculus
