Sturm-Liouville Like Equation with Boundary Conditions on Second Derivative
In summary, the user is trying to solve a diffusion equation with a slightly exotic boundary condition, but has not been successful so far. They recommend using separation of variables to solve the equation.
Nikratio
Hello,
I am facing a diffusion equation..
[tex]\frac{du(x,t)}{dt} = D \frac{d^2u}{dx^2}[/tex]
.. with slightly exotic boundary conditions:
[tex]u(0,t) = 0[/tex]
[tex]\frac{d^2u(a,t)}{dx^2}+ \alpha \frac{du(a,t)}{dx} = 0[/tex]
I expected the solution to be relatively easy to find, since separation of variables quickly gives a Storm-Liouville equation. However, the different second boundary condition has so far trashed all of my efforts to find a solution.
Is someone able to give some advice on this? Can I rely on the existence of eigenfunctions at all or do I need to get at this from an entirely different direction?
What I would do is write that second boundary condition in a slightly different form.
We see that the u(x,t) satisfies the diffusion equation for all x (in its domain of course). Hence for x=a too. With this it seems to be fruitful if we write the boundary condition as:
[tex]
\left(\frac{d^2u(x,t)}{dx^2}+ \alpha \frac{du(x,t)}{dx}\right) \bigg |_{x=a} =
\left(\frac{1}{D}\frac{du(x,t)}{dt}+\alpha \frac{du(x,t)}{dx}\right) \bigg |_{x=a}=0
[/tex]
And so the boundary condition is only with first derivatives.
[tex]
[/tex]
Actually that is the original form of the boundary condition. I rewrote it in terms of the spatial derivative so that I could use separation of variables. Did I miss something obvious? To me this form seems even less tractable...
You can use separation of variables anyway.
Solve the diffusion equation in the usual manner with separation of variables, the time part as usual will have an exponential dependence then using the first boundary condition you can rule out one of the solutions to the spatial equation (the sine stays or the sinh), then apply the second boundary condition, and you shall get a transcendental equation something like k*tan(k) = ... this quantizes the constant you got when using the separation of variables, but you cannot solve this equation. From here you can superimpose the solution with the different quantas and you are done.
Hello,
Thank you for sharing your problem. The Sturm-Liouville equation is a well-known partial differential equation that arises in many physical and mathematical applications. It is a second-order, linear, homogeneous equation with variable coefficients and can be solved using separation of variables, as you have mentioned.
In your case, the boundary conditions on the second derivative are indeed non-standard and may require a different approach to finding a solution. One possibility is to use a transformation to convert the equation into a standard Sturm-Liouville equation, which may make it easier to solve. Another approach is to use numerical methods to approximate the solution.
In terms of the existence of eigenfunctions, it ultimately depends on the specific form of your equation and boundary conditions. It may be helpful to consult with a colleague or a specialist in Sturm-Liouville equations to get some insight on how to approach this problem. Good luck with finding a solution!
1. What is the Sturm-Liouville Like Equation with Boundary Conditions on Second Derivative?
The Sturm-Liouville Like Equation with Boundary Conditions on Second Derivative is a type of differential equation that involves a second derivative and is subject to specific boundary conditions. It is named after the mathematicians Jacques Charles François Sturm and Joseph Liouville, who first studied this type of equation in the 19th century.
2. What are the applications of the Sturm-Liouville Like Equation with Boundary Conditions on Second Derivative?
The Sturm-Liouville Like Equation with Boundary Conditions on Second Derivative has various applications in physics, engineering, and mathematics. It is commonly used to model physical processes such as heat conduction, electromagnetic waves, and quantum mechanics. It also has applications in signal processing, control theory, and numerical analysis.
3. What are the key features of the Sturm-Liouville Like Equation with Boundary Conditions on Second Derivative?
The Sturm-Liouville Like Equation with Boundary Conditions on Second Derivative has several important properties. It is a linear differential equation, meaning that the sum of any two solutions is also a solution. It also has a unique solution for a given set of boundary conditions, and its solutions form an orthogonal set. Additionally, the eigenvalues and eigenfunctions of the equation have physical significance and can be used to solve various problems.
4. How is the Sturm-Liouville Like Equation solved?
The Sturm-Liouville Like Equation with Boundary Conditions on Second Derivative is typically solved using separation of variables, where the solution is expressed as a product of two functions. The first function satisfies the boundary conditions, and the second function satisfies the differential equation. The resulting equation can then be solved using various methods, such as power series, Fourier series, or Laplace transforms.
5. What are some challenges in solving the Sturm-Liouville Like Equation with Boundary Conditions on Second Derivative?
One of the main challenges in solving the Sturm-Liouville Like Equation with Boundary Conditions on Second Derivative is finding appropriate boundary conditions that lead to a solvable equation. The equation can also be difficult to solve analytically for more complex boundary conditions, requiring the use of numerical methods. Additionally, determining the eigenvalues and eigenfunctions can be a lengthy and tedious process for certain equations.
  • Differential Equations
