Calculating Approximate Atomic Mass of Lead | Isotopes of Pb and Percent by Mass
In summary: If you use 204 for atomic mass of the ^{122}_{82}Pb your result will be off for obvious reason - atomic mass of ^{122}_{82}Pb is NOT 204. But if you will use 203.973 your result will be as correct as possible, the only remaining reason for lack of accuracy being fact that you have no idea what isotopes constitute remaining 0.01% of the lead.
tigerwoods99
99
1. The Table below lists the isotopes of Pb and their percent by mass:
Isotope
% Mass
82p, 122n 1.37%
82p, 124n 26.25%
82p, 125n 20.82%
82p, 126n 51.55%(a) Using these data, calculate the approximate atomic mass of lead;
(b) Why is this number in (a) only approximate?
Show all work!
Look below, i was able to solve A, however I am wondering why this number is only an approximate? Thanks!
82p, 122n --> 204 mass number (.1370)
82p, 124n --> 206 mass number (.2625)
82p, 125n --> 207 mass number (.2082)
82p, 126n --> 208 mass number (.5155)
(204*.1370) + (206*.2625) + (207*.2082) + (208*.5155) = approximate atomic mass of lead
(27.95) + (54.08) + (43.10) + (107.2) = approximate atomic mass of lead
(a) 232.3 amu = approximate atomic mass of lead
100.00%?
No need for crying, we can read standard font no problems.
Borek said:
100.00%?
Im just trying to figure out the answer to the part that says like why is the average weight using the % natural occurrence only an approximate.
And I have gave you a hint. Do you know 100.00% composition of the mixture?
im not sure, not really understanding what you are talking about
Somewhere this is wrong, If you have all the individual masses in the range 204-208, how can the average be 232?
As to why it's approximate, what is the relative atomic mass of 204Pb?
You have assumed that fractions given sum to 100%, but have you checked it?
What if I will tell you that lead contains 26.25% of [itex]^{124}_{82}Pb[/itex] and 20.82% [itex]^{125}_{82}Pb[/itex]? Will you be able to calculate average atoms mass?
Edit: sjb is right, I missed something important :blushing:
Ok yea i found my error, I converted 1.37% to .1370 instead of .0137. So the approximate atomic mass of lead would be 207.1912.
I'm still confused on why this number is an approximate.
That sounds better, yes. What is the relative atomic mass of 204Pb?
sjb-2812 said:
that sounds better, yes. What is the relative atomic mass of 204pb?
204?
No. Less than that.
I'm not sure... it says 204.
http://www.wolframalpha.com/entities/isotopes/lead_204/2y/re/x8/
No. Read again. You are not looking for a mass number.
82 ?
What are you calculating?
is it 204*0.0137? = 2.7948 ?? I'm not really sure what you asking me to do.
You are calculating AVERAGE ATOMIC MASS, so to get correct result you should use ATOMIC MASSES, not mass numbers.
Ok, So i got that 207.1912 is the approximate atomic mass of lead. Now i just need to figure out why this number is only an approximate.
Previous one was approximate, this one (assuming you took atomic masses for all isotopes) should be correct. That is, you have no idea what is 0.01% of the mixture, so there is still some error in calculations.
Ok so this was my starting data
82p, 122n 1.37%
82p, 124n 26.25%
82p, 125n 20.82%
82p, 126n 51.55%
So the reason this calculation is an approximate is because the atomic mass did not take into consideration the electrons, is that correct? Or why is it an approximate, even with the atomic masses. B/c i know atomic mass = protons + neutrons but the electrons are very minute
No, I think the RAM takes into account electrons. What does the Wolfram page you have quoted say is the atomic mass of lead-204?
Alright, but I am still not sure where I am headed with this. I got the right number correct? It's just a matter of explaining why this number is only an approximate.
Thanks everyone
Question is confusing, that's not your fault.
If you use 204 for atomic mass of the [itex]^{122}_{82}Pb[/itex] your result will be off for obvious reason - atomic mass of [itex]^{122}_{82}Pb[/itex] is NOT 204. But if you will use 203.973 your result will be as correct as possible, the only remaining reason for lack of accuracy being fact that you have no idea what isotopes constitute remaining 0.01% of the lead.
Yea that makes sense. How did you get the 203.9... I got it being something around 207.
According to wolfram page you linked to earlier, 203.9... is a correct atomic mass of [itex]^{122}_{82}Pb[/itex].
Ok so here is what I have right now:
82p, 122n --> 204 mass number (.0137) %
82p, 124n --> 206 mass number (.2625) %
82p, 125n --> 207 mass number (.2082) %
82p, 126n --> 208 mass number (.5155) %
(204*.0137) + (206*.2625) + (207*.2082) + (208*.5155) = approximate atomic mass of lead
(2.795) + (54.08) + (43.10) + (107.2) = approximate atomic mass of lead
(a) 207.2 amu = approximate atomic mass of lead
This is what the directions say (a) Using these data, calculate the approximate atomic mass of lead; (b) Why is this number in (a) only approximate?
I'm still not sure why the number in (a) is only approximate of the atomic mass of lead. Is it because like someone said before, that we don't know what the .01% of the isotope is?
I'm really not sure
Mass number and atomic mass of the isotope are DIFFERENT. You have calculated average using MASS NUMBERS which are incorrect, so your result must be incorrect.
Oh. How do I do it using atomic mass?
Exactly the same way, but using atomic mass instead of mass number.
1. What is the atomic mass of lead?
The atomic mass of lead is approximately 207.2 atomic mass units (amu).
2. How is the atomic mass of lead calculated?
The atomic mass of lead is calculated by taking the weighted average of the masses of all naturally occurring isotopes of lead, which takes into account their abundance in nature.
3. What are the isotopes of lead?
The three most abundant isotopes of lead are lead-208, lead-207, and lead-206. Other less abundant isotopes include lead-204, lead-205, and lead-202.
4. How do you calculate the percent by mass of each isotope in lead?
The percent by mass of each isotope in lead is calculated by dividing the mass of each isotope by the total mass of lead and multiplying by 100%. For example, the percent by mass of lead-208 would be (208 amu / 207.2 amu) x 100% = 100.2%.
5. Why is it important to calculate the approximate atomic mass of lead?
Calculating the approximate atomic mass of lead is important because it helps us understand the composition of this element and its isotopes. It also allows us to accurately predict the properties and behavior of lead in various chemical reactions and processes.
