How do I Calculate the Ksp of Ag2CrO4 Using Experimental Data?
  • Thread starter Ritzycat
  • Tags
    Ksp
In summary: I think so, I'm not sure though.In summary, the chromate ion concentration was 1.24x10-3 and the silver ion concentration was .
Ritzycat
171
I have to calculate the KSP of Ag2CRo4. I did this lab several days ago and I'm completely stumped. If anyone could help me out here, at the least guide me in the right direction so I can get this done as I am getting very frustrated :P
Here is the data I have derived thus far.
2.5x10-5 = concentration of AgNO3
1.5x10-5 = concentration of K2CrO4
Using a concentration / absorbance chart, we found the conc. of the CrO4-2 ion, 1.24x10-3.
My teacher says that the concentration of the Ag+ ion can be found stiochiometrically by using the CrO4-2 ion, then we can calculate KSP from that. I have no idea of how to get to the concentration of the Ag+ ion though.
The instructions say this:
1.
"Determine the value of Q for your original mixture of 5.0 mL of 0.0050 M AgNO3 mixed with 5.0 mL 0.0030 M K2CrO4. Keeping in mind that a precipitate forms from this mixture, is the actual Ksp for Ag2CrO4 greater or less than this value?"
the diluted concentrations of those molecules are listed above.
2.
Perform necessary calculations in order to determine the Ksp for Ag2CrO4.
This would include:
a. calculation of chromate ion concentration using the equation of your line from day 1.
b. Calculation of the silver ion concentration.
c. Calculation of Ksp for Ag2CrO4."
The chromate ion concentration is 1.24x10-3.
AgNO3 + K2CRO4 <-> Ag2CrO4 + KNO3
Ag2CrO4 <-> 2Ag+ + CrO4-2
Ksp = [Ag+][CrO4-2]
All are aqueous, except Ag2CrO4 is solid.
I don't really have an "attempted solution" for this exact calculation because I really don't know what to do next. I've been able to calculate all of the necessary ingredients up until now. Thanks in advance for anyone who is willing to give me some guidance / show some calculations.
Hint: how much CrO42- disappeared from the solution? Where is it now? What does it tell you about Ag+?
am I supposed to make an ICE thing ?
In a way. ICE is just a nice method of following stoichiometry.
If I were to set it up though I'd have two unknown variables since I don't know either Ksp or KNO concentration...
Have you tried to answer my question about CrO42-?
Yes but I am not sure how. The only info I have so far about the chromate ion is its concentration as a result of mixing the 5 mL of compounds together.
No, you know how much was there initially, and you know - from the spectroscopy - how much was left.
How do I know how much there was initially, do I use stoichiometry using the moles of my reactants
A correction to the OP since I seem unable to edit it:
2.5x10-5 = mols of AgNO3
1.5x10-5 = mols of K2CrO4
NOT the concentrations, at least so I think.
(5 mL) X (1 L/1000 mL) x (.0050 mol / 1 L) = 2.5x10-5 mols.
The concentrations of silver nitrate and potassium chromate are .0050 and .0030M respectively
Hang on, I think you are right. On the graph that we calcualted on the spectrometer the original concentration of the chromate ion was 2.2x10-4
Also, the Solubility-Product constant of the Chromate ion is .44, I think.
I guess I could use that to find the concentration of the Ag ion with this, right?
.44 = [1.24x10-3][Ag+]2
Then the AG concentration would be 18.3. That seems unusually high.
Some other useful datas.
trial | volume of .003 M K2CrO4 | Total Volume | [CrO4] | Absorbance (430 nm)
1. | 5 mL | 2.2x10^-4 | 100 mL | .06
2. | 10 mL | 2.7x10^-4 | 100 mL | .10
3. | 15 mL | 4.7x10^-4 | 100 mL | .17
4. | 18 mL | 5.3x10^-4 | 100 mL | .19
How much chromate have you put into sample? You prepared the solution, didn't you? And to do so, you measured some volume of chromate? Can't you use this information to calculate how much chromate was initially present?
What is the final volume of the solution? What is the measured concentration? How many moles of chromate does it mean?
Please try to answer these questions, I am trying to guide you to an answer, but you are taking every possible tangential road which is why you don't move ahead.
We did not directly measure/prepare the chromate itself. We first created a Concentration vs. Absorbance graph, since chromates are yellowish we prepared 4 different concentrations of K2CrO4, then put it in the spectrometer to measure the absorbance vs. the concentrations at 430 nm.
Then we put 5.0 mL .0050M AgNO3 and 5.0 mL .0030M K2CrO4 into two test tubes each. We shook the tubes, put them in the centrifuge for 2 minutes, dumped it out in the sink, added 3mL water, and repeated that process. After three rounds we then decanted it into the cuvette to be measured in the spectrometer. We took the value for the absorbance (.44) and plugged it into the formula we made for our graph.
.44 = 350.3x + .003878
So the concentration of it would be 1.2x10^-3
Sorry I am not able to directly answer your questions. I am completely stumped though as to what I need to do to get the concentration of the Ag+ ions using all of my information.
How much chromate is that?
(5 mL) x (1 L/1000 mL) x (.0030 mol / 1 L) = 1.5x10-5 mol K2CrO4
K2CrO4 <-> 2K+ + CrO42-
1.5x10-5 mol K2CrO4 = 1.5x10-5 mol CrO42-
1.5x10-5 mol CrO42- X (115.996g/1 mol) = 1.7x10-3 g CrO4
Does this all look right to you?
I think I need the initial concentration though, how should I go about getting that from this?
Sigh. In you opening post you omitted whole procedure, and what you wrote suggested something completely different than what you really did. Next time post EVERYTHING at once to not waste everyone's time (including yours).
From your description - which is still not necessarily clear - you measured concentration of CrO42- in the saturated solution over precipitate. Do I understand the procedure correctly?
Sorry. I haven't been sure what exactly is important to solving the problem so I have not been sure what info to give.
Yes we measured the concentration of chromate ion after the solution was very dilute.
Solution was very dilute, or it was a SATURATED solution in contact with the precipitate? What it was that you were throwing away after centrifuging - solid, or just the liquid above?
We only threw away the liquid above
So the solution was always in contact with the solid, and we can safely assume it was saturated. If so, it is pretty easy. Write reaction equation of dissolution. How many moles of Ag+ produced per each mole of CrO42-?
2 moles Ag+ for every 1 mole of CrO4-2
Ag2CrO4-2 <-> 2Ag+ + CrO4-2
So what is concentration of Ag+?
What can I do to find that out without having directly measured it?
Look at the reaction equation, stoichiometry of the dissolution tells you how much silver got in the solution together with chromate ion.
How many moles of Ag+ are dissolved with each mole of CrO42-? Let's say the volume at the moment of the measurement was 10 mL. How many moles of chromate were dissolved> How many moles of silver were dissolved? What was the Ag+ concentration?
Would the concentration of the Ag+ simply be double the CrO4 -2? In this case, if the CrO4 concentration was 1.2x10^-3 then the Ag+ concentration would be 2.4x10^-3.
Also, part of the write-up for this lab includes writing calculations for finding the Q of silver chromate. I'd assume this would be the following.
Q = [1.2x10^-3][2.4x10^-3] = 2.9x10^-6
Since in the main reaction equation a precipitate formed, K > Q (moved right).
Oops I did that Q thing wrong.
Q = [1.2x10^-3][2.4x10^-3]^2 = 7x10^-9
That's really small, either way K > Q.
Wasn't that hard :wink:
If the precipitate formed Q=Ksp, that's how Ksp works.
Isn't that the Q value of just the sodium chromate? I have to find the Q value of "the original mixture of 5.0 mL .0050 M AgNO3" mixed with 5 mL .0030 M K2CrO4"
Q is not for a mixture, it is for a reaction.
You can calculate it using initial concentrations of silver and chromate, if it will be greater than Ksp, it will mean solid has to precipitate.
I think the reaction it was talking about was
AgNO3 + K2CrO4 <-> AgCrO4 + KNO3
I have to find Q of this mixture, but I only have the concentrations of silver nitrate and potassium chromate. Silver chromate is omitted from this because it is a solid, and I have no idea what the concentration of KNO3 is.
What is the formula for calculating the Ksp of Ag2CrO4?
The formula for calculating the Ksp of Ag2CrO4 using experimental data is Ksp = [Ag+]^2[CrO4^-]
What experimental data is needed to calculate the Ksp of Ag2CrO4?
The experimental data needed to calculate the Ksp of Ag2CrO4 includes the initial concentrations of Ag+ and CrO4^- ions, the molar solubility of Ag2CrO4, and the balanced chemical equation for the dissociation of Ag2CrO4.
How do I determine the molar solubility of Ag2CrO4?
The molar solubility of Ag2CrO4 can be determined by dividing the number of moles of Ag2CrO4 that dissolve by the volume of the solution in liters. This can be calculated using the initial concentrations of Ag+ and CrO4^- ions and the balanced chemical equation for the dissociation of Ag2CrO4.
What are the units for the Ksp of Ag2CrO4?
The units for the Ksp of Ag2CrO4 are mol^2/L^2.
How does temperature affect the Ksp of Ag2CrO4?
The Ksp of Ag2CrO4 is dependent on temperature, with higher temperatures generally resulting in a higher Ksp value. This is because an increase in temperature can increase the solubility of the compound, leading to a higher concentration of dissolved ions and a higher Ksp value.
10K
22K
