| Thread Closed |
Movement of glass of water... |
Share Thread |
| Aug5-12, 01:31 AM | #1 |
Hello!
I'm sorry if I'm posting this in the wrong section. I didn't know where else to put this. So here's the problem: Sometimes when I put a glass of water after drinking from it on my table (which also has a glass surface), the glass slides a little bit on its own. Sometimes it happens right after I have put it on there, and sometimes it stands still where I left it and slides after some time has elapsed, comes to a stop and slides a relatively smaller distance again later! I've also observed that this only happens when the glass is wet and while, this doesn't happen every time, it has happened enough times to convince me that I'm not hallucinating. So, it's just been bothering me what the real cause of the movement is. I'm sure as hell it's not magic. |
| Aug5-12, 06:12 AM | #2 |
I've noticed this too - but only for some glasses. I was wondering if it was something to do with the shape of the base of the glass? For example it has never happened to me with a wine glass, or a mug, but a tumbler does do it. I had previously thought there had been trapped air underneath the glass which had managed to escape, moving the glass, but I don't think this is right. Could it be a surface tension thing?
OK, going to go and experiment... |
| Aug5-12, 08:01 AM | #3 |
I've had this happen many times at a local diner. The glasses have a flat bottom and water from condensation builds up on the glass. Eventually enough has fallen down into a small puddle that when you set your glass down you are putting in on a layer of water that allows it to slide with virtually no friction. Combine that with a very slightly tilted table and you have a glass that moves on it's own.
| Aug5-12, 12:15 PM | #4 |
Is that all it is? I've not been able to replicate it at home today, but I have a feeling the glass moves in a non-consistent direction. Could the movement come from the fluid under the glass readjusting to a uniform thickness?
Time to go the the pub and try more experiments there. |
| Aug5-12, 03:17 PM | #5 |
| Aug6-12, 01:05 PM | #6 |
Yeah! My glass always slides toward the edge of the table too. I never thought that the table could be tilted, because... it doesn't appear to be, heh. :p
Thanks Drakkith. @Rooted: Let me know if you find something cool with your experiments. |
| Aug6-12, 08:31 PM | #7 |
| Aug7-12, 04:30 PM | #8 |
Yes, very reasonable.
Thanks Drakkith! :) |
| Aug11-12, 08:09 PM | #9 |
My guess is that you have an air bubble trapped under the bottom of the glass, maybe it expands slightly causing the glass to move?
| Aug11-12, 08:21 PM | #10 |
| Aug11-12, 09:27 PM | #11 |
| Aug11-12, 09:38 PM | #12 |
| Aug11-12, 09:55 PM | #13 |
| Aug12-12, 08:24 AM | #14 |
| Thread Closed |
Similar discussions for: Movement of glass of water...
| Thread | Forum | Replies | ||
| If an ice cube floating in a glass of water melts, won't the water level decrease? | Introductory Physics Homework | 3 | ||
| when ice melts in a full glass of water, will the water overflow | Classical Physics | 11 | ||
| What wavelengths of Infrared light are blocked by water, glass and {water and glass}? | Electrical Engineering | 0 | ||
| Using snell's law, observations thru a glass of water & glass of air | Introductory Physics Homework | 2 | ||
| Air - water - glass | Introductory Physics Homework | 5 | ||
