New Reply
Drag coefficient of a sphere (please help!)
Share Thread
Jan21-13, 03:30 AM   #1
While writing a physics report, I obtained a data that
for balls of rough surfaces, there is a higher drag force and thus
the ball can stay stable at a much smaller angle when put up in an airstream.
However, while analyzing this result, I found out that the drag coefficient is not always
bigger for rough spheres : it depends on the reynolds number of the flow.
I would really like to know whether the flow past a sphere
(in my experiment, styrofoam balls) is attached flow (Stokes flow) and steady separated flow, separated unsteady flow, separated unsteady flow with a laminar boundary layer at the upstream side, or post-critical separated flow, with a turbulent boundary layer.
Put simply, what is the reynolds number of the air coming out of an air supply?
For further information, the air supply used in our lab was SF-9216, PASCO.
PhysOrg.com physics news on PhysOrg.com
>> Kenneth Wilson, Nobel winner for physics, dies
>> Two collider research teams find evidence of new particle Zc(3900)
>> Scientists make first direct images of topological insulator's edge currents
Jan26-13, 11:48 AM   #2
After discussion with an intimate physics professor, we reached contradicting results:
like in the case of golf balls, the rough surface can make air pockets,
or when the air meets a certain condition (some sort of Reynolds number boundaries)
the drag coefficient is bigger for rougher spheres.
Also, we concluded that the air flow from the supply is turbulent.
Could you please help us out? Thank you!
Jan26-13, 12:42 PM   #3
Recognitions:
Homework Helper Homework Help
In the case of dimpled golf balls, the flow tends to stay attached longer producing less drag at speeds between 55 mph == 88 kph and 300 mph == 480 kph. Below 55 mph drag is about the same. Above 300 mph a smooth ball has less drag. Links to articles:
golf_ball_aerodynamics.aspx
wiki_golf_ball_aerodynamics.htm
Jan26-13, 01:27 PM   #4
cjl
The reynolds number is not determined by your air supply. It is based on the size of your object and the velocity of the air around it. Assuming that your supply gives a reasonably smooth flow (not always a guarantee), you can calculate the reynolds number using the equation Re = ρvL/μ, where ρ is the density of the fluid (air, in this case), v is the velocity of the fluid, L is a characteristic dimension of your object (for a sphere, this would be the diameter), and μ is the viscosity of the fluid. Density and viscosity can be calculated or looked up on a table based on the temperature and pressure of the air in your lab, and you should be able to measure your flow velocity directly (or if you do not have that capability, it may be specified in the manual of your air supply).
Once you know the reynolds number, then you will have a better idea of what kind of flow conditions your sphere will have around it, and that will determine the effect that dimples will have.
(Wiki even has a fairly nice image showing the relevant flow regimes: http://upload.wikimedia.org/wikipedi..._behaviors.png)
New Reply
Tags
bernoulli, levitation, reynolds number
Similar discussions for: Drag coefficient of a sphere (please help!)
Thread Forum Replies
Wind drag, drag coefficient Introductory Physics Homework 0
Drag Force / Drag Coefficient Introductory Physics Homework 5
Fluid Mechanics - Drag coefficient and Pressure coefficient Mechanical Engineering 1
Experimental work to prove that the Drag Coefficient of a sphere is 0.5 Mechanical Engineering 5
Coefficient of Drag General Physics 2
