Second Order Linear Homogeneous differential equations
In summary, Shadow is having trouble with the first two problems set. He is looking for help with solving them. He is unsure of what to do once he has solved the second order equation for dv/dt. He is told that in the case of a root that is the same, you just do C1e^m1x+C2e^m2x=0. He is also told that the general solution is 0 when Equating the general solution to 0.
shad0w0f3vil
70
hey I am having a little trouble with this topic. Here are the questions I was set.
a) Find the general solution of d^2y/dt^2 - 2(dy/dt) + y = 0. Verify your answer.
b) Solve the initial value problem y'' + 4y' + 5y = 0; y(0)= -3, y'(0) = 0
c) Find a DE that has the given functions as solutions: y1 = e^5x , y2 = e^-2x
Any help would be greatly appreciated.
Let's look at the first two problems. How can you take a second order linear differential equation and turn it into a system of first order equations? Hint: Let dy/dt = v.
would you turn it into v^2 + v + 1 = 0 then solve for the roots?
Not quite. We're looking for 2 first order equations derived from the second order equation. If we let dy/dt = v, that's one equation of the system. Note that:
[tex] \frac{d^2y}{dt^2} = \frac{d}{dt} \frac{dy}{dt} = \frac{dv}{dt} [/tex]
Now solve the given second order equation for dv/dt, and you'll have your first order system.
i'm not sure that I follow. I can understand how you get dv/dt, but I don't know what to do next
Half of your first order system is already known, that is, dy/dt = v.
Now let's look at the equation that you were given. We have a d^2y/dt^2 term in the given second order equation. As shown above, this equates to dv/dt. You want to solve for dv/dt. We also have a dy/dt term in the second order equation, but we've already decided that this equates to "v." Once you plug in these terms, you'll have an equation for dv/dt. Combining this with dy/dt = v, you'll have a partially decoupled system of first order linear equations. Can you show me what the second order equation will look like once you solve for dv/dt?
Make a guess that y = e^(rx) for some r. Then solve for r by solving the resulting quadratic polynomial to get two values for r (two different solutions). Since it's a linear diff eq any constant times the solution is a solution, and the sum of two solutions is a solution, the general solution is just the span of the two different solutions you've found. Use the initial conditions to find the exact solution you're looking for.
ok I am really confused sorry. I might just spend a few days on this myself, its very confusing for me.
It doesn't sound like he's in a guessing kind of mood.
Shadow, try to look through the textbook examples that show how to construct a first order linear system from a second order equation. If we let dy/dt = v, we'll end up with a system of 2 first order equations; one for dy/dt, and one for dv/dt. After you set up the system, you can use eigenvaules to solve for y(t).
Setting up that second equation is just a matter of plugging in the right terms and solving algebraically for dv/dt. Just post if you need help or further clarification.
Actually I don't think we need to introduce the concept of converting a 2nd order linear ODE into a first order one. He may not even have learned that yet. When I did an intro DE course, I learned how to solve 2nd order linear ODE without knowing how to convert it into a system of 2 linear 1st order ODE. I did that without having to explicitly use the concept of eigenvalues, even though the theory underlying the method indeed made use of such.
Now, you have the equation y'' - 2y' + y = 0. Start by asking yourself, given that this is a homogenous equation, what is the characteristic equation of this DE? Once you have equation, solve for [tex]\lambda[/tex]. Note the values of lambda. Are they both real and distinct, repeated roots or complex? What should you do if they fall into each of the three preceding categories?
ummm i read somewhere that for a root that's the same, as it is in this case, you simply do
C1e^m1x+C2e^32x=0
excuse my lack of code knowledge
Ok, you're right that the characteristic equation has 1 repeated root. I don't understand your answer for the general solution in that case. Where did '32' come from? I assume that 'm1' is the value of lambda which you have found by solving the roots of the characteristic equation. Your answer is only partly correct. The other half is incorrect.
oh sorry it should be C1e^m1x+C2e^m2x=0
That's not quite correct. That is the general solution in the case by which you get real and distinct roots. And why did you equate the general solution to 0?
i'm not sure, that's just what i read on the internet. this topic isn't covered in our textbook.
so what do i do?
Since the ODE is second order, you need two linearly independent solutions to form your general solution. If your characteristic equation has a repeated root, then the usual second solution is of the form,
[tex]y = Cxe^{\lambda x}[/tex]
Such that your overall general solution is of the form,
[tex]y = C_0e^{\lambda x} + C_1xe^{\lambda x}[/tex]
Since we have just 'plucked' this solution out of the air, one would need to verify it before it would be accepted as a solution. I haven't got time to present the theory behind the second linearly independent solution now, but if I get time later I will. Alternatively, I'm sure that there are plenty resources on the Internet that would detail the theory behind it.
ok, for part a i got an answer of
y=e^t - 2e^t
is this correct? if so how would I verify it.
and what about parts b/c
and for part c i got an answer of
y'' - 3y' - 10y = 0
y=e^t - 2e^t
No, unfortunately it is not correct. Remember that you are looking for the general solution (since you are given no boundary conditions) and therefore you should have some undetermined constants.
Since this thread has gone nowhere I think this would be a good point to ascertain your level ov knowledge. What do you actually know about ODE's? How much have you studied them?
none, this is a research assignment. So I am trying to get some help off you guys
If this is a research assignment you would be much better served with a textbook. It is very difficult to learn new concepts using a Internet forum.
ok well we have no textbooks available to us so I'm afraid I'm stuck with this
Try http://www.stewartcalculus.com/data/CALCULUS%20Concepts%20and%20Contexts/upfiles/3c3-2ndOrderLinearEqns_Stu.pdf"
hotcommodity, you seem stuck on one particular method- which does not appear to be a method shadowOf3vil has learned! It is very simple to find and solve the characteristic equation for each of these- that was what shadowOf3vil suggested in his first response.
ShadowOf3vil, this is one reason why we insist that people show what they have already tried. There are always many different ways of solving such problems. We can't help if we don't have some idea what methods you have learned.
ok thanks HallsofIvy, when I get a minute or two today I will post my steps so far.
I learned how to do it the hard way first, then I learned how to solve it the easy way. I suppose that's why I went the route of the first order system. Didn't mean to cause any confusion! :)
Changing to a system of first order equations- and then to a vector equation- is an excellent way of handling really hard problems. But it is a little "overkill" for simple problems like these.
ok... no problem guys. I do appreciate the help. Here's my plan of attack, I will spend a couple of days researching this topic thoroughly before presenting what I have learnt.
ok for part a i got
e^t(C1+C2t), which i then validated.
for part b i got
e^-2t [-3cost - 6sint]
y'' - 3y' -10y=0
do these sound right?
Yeah, I got the same answers.
1. What is a second order linear homogeneous differential equation?
A second order linear homogeneous differential equation is a mathematical equation that involves a function, its first derivative, and its second derivative. It is considered linear because the function and its derivatives are raised to the power of one, and homogeneous because all terms involve the same function.
2. What is the general form of a second order linear homogeneous differential equation?
The general form of a second order linear homogeneous differential equation is y'' + p(x)y' + q(x)y = 0, where p(x) and q(x) are functions of x and y' and y'' represent the first and second derivatives of the function y, respectively.
3. How do you solve a second order linear homogeneous differential equation?
There are several methods for solving a second order linear homogeneous differential equation, including using the characteristic equation, the method of undetermined coefficients, and the method of variation of parameters. These methods involve finding a particular solution that satisfies the given equation and its initial conditions.
4. What are the applications of second order linear homogeneous differential equations?
Second order linear homogeneous differential equations have many applications in physics, engineering, and other fields. They can be used to model motion, oscillations, and other physical phenomena. They are also useful in solving problems related to circuits, heat transfer, and population dynamics.
5. How are second order linear homogeneous differential equations related to eigenvalues and eigenvectors?
Second order linear homogeneous differential equations can be solved by finding the eigenvalues and eigenvectors of the corresponding matrix. The eigenvalues and eigenvectors represent the solutions to the equation and can be used to determine the behavior of the system over time. This relationship is particularly useful in solving systems of differential equations.
