A prime limit that seems to approach a constant
In summary, the conversation discusses a problem involving the first 100 results of a calculation using Wolfram. The participants then discuss the behavior of the results and how to prove whether they approach zero or a constant. The conversation also touches on the concept of an infinite product and its convergence to zero, as well as different approaches to proving this.
robnybod
Ok here's the problem:
Using wolfram the first 100 results are these
heres a plot of a couple points
As you can see it doesn't seem to be approaching exactly zero, even though its very similar to 1/x (exactly the same if you replace Pn with just n)
Is there any way to prove whether this does approach 0 or some constant, or is it possible to make a program to approximate it to some extremely large n, to see if its approaching zero or some constant.
Thanks in advance, and sorry if the answer is obvious
welcome to pf!
hi robnybod! welcome to pf! :wink:
it's decreasing and positive, so it must have a limit
to find the limit, use the usual trick of putting fn = fn-1 :smile:
Thank you!
so according to that it would go to zero, correct? because than f=f(1-1/P(n)) and f goes away, so you're left with -1/P(infinity)=0, which checks
correct! :smile:
(the reaoning isn't rigorous, but the result is ok)
Good morning,
Your infinite product ∏(1-pi-1), over all primes, does indeed converge to zero, but no fn=fn-1 trick is close to showing why.
The standard elementary proof here is to rewrite your limit as (Ʃ1/n)-1 over the positive integers realizing that your limit is an euler product (google, wiki).
Note btw that if you add an exponent s to all your primes, your limit equals ζ(s)-1, where ζ(s) is the Riemann zeta function, known to converge for all s>1 (and giving you non-zero limit in this case).
Another proof would be to think of function fk as being the probability to pick a natural number that has a factor among all the prime numbers except the first k prime numbers.
f0 = 1, the probability to pick a number that has a factor among all primes is 1
f1 = f0 - f0/p1, the probability to pick a number that has a factor among all prime numbers except the first prime is 1/2
at infinity this translates into
lim [itex]_{n->\infty}[/itex]fn = 0 because f[itex]\infty[/itex] is the same as asking what is the probability to pick a natural number that doesn't have a factor among all the prime numbers. Of course all natural numbers have a prime factor or are prime numbers therefore the answer is 0.
1. What is a prime limit?
A prime limit refers to the highest prime number that is used as a limit in a mathematical equation or problem. It can also refer to the limit of a sequence of numbers where each number is a prime number.
2. How does a prime limit approach a constant?
A prime limit can approach a constant in a few ways. One way is if the limit is the highest prime number in a sequence, and all subsequent numbers in the sequence are divisible by the limit. Another way is if the limit is the result of a mathematical equation, and as the inputs approach infinity, the result approaches a constant.
3. Why is a prime limit important in mathematics?
A prime limit is important in mathematics because it helps to determine the complexity and behavior of a mathematical equation or problem. It can also provide insights into the nature of prime numbers and their relationships with other numbers.
4. Is there a specific formula for finding a prime limit?
No, there is no specific formula for finding a prime limit. It depends on the context in which the limit is being used and the specific equation or problem at hand. However, there are various mathematical techniques and algorithms that can be used to find prime limits in different scenarios.
5. Can a prime limit ever be equal to a constant?
Yes, a prime limit can be equal to a constant in certain cases. For example, if the limit is the highest prime number in a sequence and all subsequent numbers in the sequence are divisible by the limit, then the limit would be equal to a constant. However, in most cases, a prime limit will approach a constant but never actually be equal to it.
  • Linear and Abstract Algebra
