| New Reply |
where does the magnetic field in spin-orbit coupling come from? |
Share Thread | Thread Tools |
| Dec24-12, 02:59 PM | #1 |
the proton is stationary, and we're assuming there is no magnetic field in the rest frame of the proton. I know if we move to the rest frame of the electron there will be a magnetic field.
but shouldn't we be able to analyze it in the rest frame of the proton? |
| Dec24-12, 03:44 PM | #2 |
Mentor
It easier in the frame of the electron. Even in the frame of the proton, the easiest description would be "the electric field, if we would transfer it to the electron frame, has a magnetic component". In the proton rest frame, you have to consider electron spin, electron velocity and electric field at the same time.
| Dec24-12, 04:19 PM | #3 |
The standard derivation of spin-orbit coupling is total horseradish.
For a classical particle one can talk about its orbit, its centripetal acceleration, and the relativistic Thomas precession that will act on the spin. None of these classical concepts apply to the quantum mechanical Dirac wavefunction for a bound state. Quantum mechanics can only be done in a nonaccelerating frame.Unfortunately, most books satisfy themselves with a one-line handwaving derivation, and even more unfortunately, most students fall for it. A legitimate calculation can be found, for example, in the old but excellent QM book by Schiff. His approach involves taking the nonrelativistic limit, in which the Dirac spinor can be replaced by a two-component Pauli spinor, assuming a central potential, and simplifying the resulting Hamiltonian. One can also write down the exact solution for the bound states of a Dirac particle in a Coulomb potential and extract the spin-orbit term from that. |
| Dec25-12, 01:14 AM | #4 |
I don't remember it but a proton can be described by a localized current.and can be described by current j=∇×M,where M=mδ(x),m contains contribution from magnetic moment of proton.
this corresponds to vector potential A=∫j(x')/|x-x'| d3x',apart from some constant.Now one can evaluate B by B=∇×A. |
| Dec25-12, 01:35 PM | #5 |
Recognitions:
The Dirac equation (in the rest frame of the proton) gives spin orbit coupling for the electron.
| Dec26-12, 02:57 AM | #6 |
Recognitions:
The standard derivation in QM is via the Dirac equation, but it is somehow a "shut up and calculate" approach and the significance of the terms arising is usually done via comparison with the classically limiting expressions. |
| Dec26-12, 04:32 AM | #7 |
![]() When I see a term rxp·σ in the Hamiltonian I don't need to look at the classical limit to tell me that it represents spin-orbit coupling.
| Dec26-12, 09:08 AM | #8 |
Recognitions:
'paradoxes' caused by too much talk and too little calculation. |
| Dec26-12, 09:48 AM | #9 |
I guess its good to see both ways of doing it, with keeping in mind that its actually QM not a classical effect
| Dec26-12, 12:10 PM | #10 |
Recognitions:
Also, although the explanation using spinors might not take many lines, I think that for students who are just starting to learn quantum mechanics, it might be a bit too much all at once to go into spinors and other stuff. |
| New Reply |
| Thread Tools | |
Similar Threads for: where does the magnetic field in spin-orbit coupling come from?
| Thread | Forum | Replies | ||
| Spin-Orbit coupling. | Quantum Physics | 2 | ||
| hydrogen orbits, magnetic field, orbit-spin interaction | Advanced Physics Homework | 3 | ||
| Spin Orbit Coupling. | Advanced Physics Homework | 6 | ||
| spin orbit coupling | Advanced Physics Homework | 4 | ||
| spin-orbit coupling | Advanced Physics Homework | 5 | ||
