Can you reach absolute zero in complete empty space
In summary, the conversation discusses the concept of absolute zero temperature and the possibility of reaching it. It is mentioned that even in a vacuum with no particles, there is still a temperature due to radiation. It is also stated that the density of particles affects the meaning of temperature. Additionally, the conversation touches on the idea of dust clouds with high temperatures in a hard vacuum. However, it is clarified that these clouds still have some particles present and are not a perfect vacuum like man-made vacuum chambers. Overall, the discussion highlights the complexities and nuances of temperature and its measurement.
mcafej
Ok, so I know that the laws of physics say reaching absolute zero temperature is impossible, but suppose we took a box that was perfectly insulated in completely empy space, and I took all the particles out of it to create a vacuum. Now, since there are no particles in the box, then wouldn't the temperature inside the box be absolute zero (no heat energy = no temperature, right?)? If I am wrong, what would the temperature inside the box be? Since the average temperature of the universe is only 2.73 kelvin, then it seams like there would be areas in space that are like this...
Astronomy news on Phys.org
What does "temperature" measure?
The concept of temperature deals with systems where the number of particles is large enough to approximate the density of states as a continuous function of energy. If you get to small number of particles, then the discrete nature of states becomes important, and temperature ceases to have any meaning.
I suppose one may choose to attribute a characteristic temperature to the zero-point energy in a volume, by E=kT or whatever, but it is not clear what this would mean, hence the question in post #2.
Focussing on what temperature is should help.
micky_gta said:
How about colder than absolute zero?
Negative temperatures are hotter than every positive temperature.
The same as the temperature of the box, about 2.7K (there is no perfect heat isolation). You don't need matter to have a temperature, radiation is sufficient.
In addition to the answers above, there is another issue that you might find interesting in this context. Following up on Khashishi's statement "If you get to small number of particles, then the discrete nature of states becomes important, and temperature ceases to have any meaning" --- It is my understanding that there are dust clouds that have a "temperature" of millions of degrees and yet they are a hard vacuum compared to what we can get in a vacuum chamber on earth.
But there aren't a small number of particles in a giant dust cloud.
I didn't say there aren't any particles. Reread what I said. Do you think man-made vacuum chambers evacuate every single particle?
Yes, but so what?
What, in the "this" context of temperature vis-a-vis the limit of zero particle density in a fixed volume, is the interest?
Do you mean that temperature need not decrease with the particle density?
You've lost me phinds. I don't know what you are getting at.
I was just presenting a factoid that I though the OP might find interesting because he was talking about temperature and a hard vacuum. Let me restate it
Hm ... I don't see any way to restate it and make it any more clear that what I already said: It is my understanding that there are dust clouds that have a "temperature" of millions of degrees and yet they are a hard vacuum compared to what we can get in a vacuum chamber on earth.
Are you simply saying that a man made vacuum doesn't pump out all the gas? And that these clouds that are millions of degrees are more of a vacuum than what we can produce on Earth?
That is exactly what I am saying.
I thought you were getting at something with the temperature too. My mistake good sir.
1. Can absolute zero be reached in completely empty space?
Yes, according to the laws of physics, it is theoretically possible to reach absolute zero (0 Kelvin or -273.15 degrees Celsius) in completely empty space.
2. How is absolute zero defined?
Absolute zero is defined as the lowest possible temperature where all molecular motion ceases and no heat energy can be extracted from a system.
3. Is it possible to create a perfect vacuum in space?
No, it is not possible to create a perfect vacuum in space. There will always be some residual gas particles present, even in the emptiest regions of space.
4. Can absolute zero ever be reached in a laboratory setting?
While it is possible to get very close to absolute zero in laboratory settings, it is not possible to reach it exactly. This is due to the fact that it would require an infinite amount of time and energy to reach absolute zero.
5. What happens at absolute zero?
At absolute zero, all molecular motion stops and atoms are in their lowest energy state. This causes materials to become extremely brittle and lose their ability to conduct electricity.
  • Astronomy and Astrophysics
  • Thermodynamics
  • Quantum Interpretations and Foundations
  • Other Physics Topics
