Percentage saving in weight of Hollow Shaft vs Solid Shaft
In summary, a user is seeking help in determining the dimensions of a hollow shaft to replace a solid shaft with a diameter ratio of 2. They are using relevant equations and trying to solve for the unknown dimensions, but have not been able to get the correct answer. They are also questioning if they are using the correct equations and if their tutor's provided answer is correct. Another user is offering guidance and suggesting that this type of design may not always be the best choice. Another user shares a similar problem they had in the past.
Drew112233
1. Hey everyone, I'm brand new to this site and am requiring some help and a push in the right direction. Here's my problem, I have a solid circular shaft of 200mm diameter, and it is to be replaced with a hollow shaft having a diameter ratio of 2. I need to determine the dimensions of the hollow shaft if the maximum stress is to be the same as for the solid shaft. I also need to know what the percentage saving in weight of the hollow shaft compared with the solid one.
2. I think the relevant equations are:
Tau(max) = T/J x r(max)
J = Pi(r^4)/2
J = Pi(ro^4 - ri^4)/2
3. I have used the above equations to establish tau of the solid shaft, but then do I use a the second J equation to find the inner radius given that I know the diameter ratio is 2 ( meaning 400mm diameter?? is this correct?). Do i also assume torque is the same for both the hollow and solid shaft?
Can anyone give me a gentle shove in the right direction?
The problem states, for the hollow versus solid shaft, hold torque constant, and set outside diameter of the hollow shaft equal to two times inside diameter of the hollow shaft. Your relevant equations are correct. See if you can figure it out now.
Thanks for your help nvn, but I am still stuck...
I have used the equations J(soild)/r(solid) = J(hollow)/r(hollow)
(I have canceled out the Torques and the stresses from the equations due to the fact they must remain constant to both shafts)
I have then transposed the J (Pi(ro^4 - ri^4)/2) to make ro the subject - redifining ri^4 in terms of ro given tha diameter ratio of 2 in order to be able to do it.
I end up with the answer of 159mm = ro
I know this is wrong because my tutor has attached the answer to work to and he says the answer should read as ri=102mm; ro=204mm; 22% saving in weight.
Any ideas what I'm doing wrong?
Drew112233: What do you mean by, you made "ro the subject"?
expanded and transposed so that the equation is ro=...
In mathematics, that is called an unknown, not a subject. You made ro the unknown. OK, so it sounds like you need to check your algebra and arithmetic. Keep trying.
So I know:
J(solid)
r(Solid)
J/r (solid) = 3.14x10^-3
Then by transforming J(hollow) into Pi(ro^4 - ri^4)/2 and letting that = r(hollow) x 3.14x10^-3, I can then transpose the equation to find ro.
Is this all correct?
I find the transposition to be 0.01256 x 2r(hollow) = Pi x ro^4(hollow)
So then...
ro^3 = 4x10^-3
and...
ro = (4x10^-3) cube rooted (not sure of keyboard notation for that one!)
All seem correct?
Your value for J/r (solid) is incorrect. Also, cube root can be written, e.g., x^0.33333.
Thanks!
I still can't get the answer... I feel so dumb!
I have used the equation to get the new J/r(solid) figure of 1.57x10^-3
Then I get the full transposition for the outer radius of the hollow shaft (to get 'ro') to be:
ro= (4x(1.57x10^-3)/Pi)^(0.33333)
When I apply this formula, it still doesn't seem to work out. Am I doing something fundamentally wrong with the transpostion?
Just to clarify, should I be using the a constant figure (eg 1) for the torque figure, or can I simply cancel it out from both sides of the equation as said above? likewise with the shear stress figure?
Yes, you can cancel out torque and shear stress; that's correct. Your equation in the second sentence of post 3 is correct. Therefore, just keep checking your algebra and arithmetic, and try it again.
I think I'm having trouble re-arranging the J(hollow) formula to find the unknown ro.
Is the answer which I was provided with by my tutor actually correct? 102mm id 204mm od?
the transposition I keep coming to is the post above is that correct?
Yes, the answer of your tutor is correct to three significant digits. Your current answer is incorrect. Starting from the equation in the second sentence of post 3, take a new sheet of scratch paper and very carefully rework the algebra, step by step, to solve for ro.
I'll get straight on it! Thanks again nvn!
I've tried to derive, re-derive and re-arrange the formula ll week and I'm still struggling. Just to be clear, the R (hollow) which I use for the main equation is the same as Radius Outer (Ro) isn't it?
I just can't seem to get it right, any more hints?
Drew112233: Yes, r (hollow) is an ambiguous name for ro. Show your work, so I can see your algebra and arithmetic, step by step, to find out where the mistake is occurring.
This problem offers an interesting note on "design optimization" or "light weight design" or whatever other term we might want to invoke. A simple solid shaft 200 mm in diameter is going to be replaces by a much more complex shaft almost 320 mm in diameter with a bore of 159 mm in order to save 22% on the weight. The cost of manufacturing this hollow shaft will be substantially more, as well as the fact that it will take a significantly larger space. It is important that we know how to make such designs, but it is also important that we know when they are worth making and when they are to be avoided! Only rarely and in special circumstances would this be a good engineering choice.
This is very similar to a problem I had in Sept 07. In this case, I needed the smallest hollow shaft required to transmit angular information down a shaft, from one end to the other, under torsional load, with a limit on angular displacement error. (And it scales as D^-4, yikes!) You're problem is a bit simpler.
I have a polar moment of inertia formula for a hollow round shaft given as
[tex]J = \left( \pi / 32 \right) \left( D^4 - d^4 \right) [/tex]
D, and d are the outside and inside diameters, respectively.
This differs from yours. Why?
There really is no difference. Drew stated his J expression in terms of radii, where as the second expression given by Phrak is in terms of diameters. The (1/2)^4 makes the 1/16 difference where they appear to disagree.
Thanks, DrD. Missed that. This is really become an algebra problem I see, and the factor scales-away anyway.
What you say about optimization is a good one. Almost invariably one runs into competing constraints, or competing optimizations, in space, strength, cost, etc.
The miniscule weight savings in this textbook problem is misleading. A scaling of radius by 50% represents a strength increase by a factor of 5. Weight, by comparison scales by a factor of 2.25.
The outside of a shaft takes most of the stress and transmits most of the torque. The inner 75% of a shaft is wasted material.
Anyway, strength per unit weight scales as the square of the diameter, as does rigidity per unit weight.
Ok, So my Steps were ar follows:
J(solid)/R(solid) = J(hollow)/R(hollow)
We know that...
J(solid)/R(solid) = ((Pi x 0.1^4)/2) / 0.1 = 1.57 x 10^-4
So then...
1.57 x 10^-4 = J(hollow)/R(hollow)
Move R(hollow) across
(1.57 x 10^-4) x Ro(hollow) = J(hollow)
We also know that...
J(hollow) = ((Pi x (ro^4 - ri^4))/2) AND ro = 2ri
so...
(1.57 x 10^-4) x 2ri(hollow) = ((Pi x (2ri^4 - ri^4))/2)
= only unknown is ri, so isolate the unknowns!
((Pi x (2ri^4 - ri^4))/2) = 1/2Pi x ri^4
Then..
(1.57 x 10^-4) / 1/2Pi = ri^4 / 2ri
So ...
1 = ri^2
ri = WRONG ANSWER :-(
?? I don't know what problem you are solving, Drew :confused:
Drew112233 said:
line 4: (1.57 x 10^-4) x ro(hollow) = J(hollow)
line 5: J(hollow) = ((Pi x (ro^4 - ri^4))/2) AND ro = 2ri
line 6: (1.57 x 10^-4) x 2ri(hollow) = ((Pi x (2ri^4 - ri^4))/2)
line 7: ((Pi x (2ri^4 - ri^4))/2) = 1/2Pi x ri^4
line 8: (1.57 x 10^-4) / 1/2Pi = ri^4 / 2ri
line 9: 1 = ri^2
Drew112233: Lines 4 and 5 are correct. Your first algebra mistake occurs in line 6; ro^4 = (2*ri)^4, not 2*ri^4. Another algebra mistake occurs in line 8. Therefore, try it again, starting from lines 4 and 5. And show your work again.
Also, generally always maintain four significant digits throughout all your intermediate calculations, then round only the final answer to three significant digits. Therefore, e.g., J (solid) = 1.571e-4 m^4.
line 6: (1.57 x 10^-4) x 2*ri(hollow) = ((Pi*((2ri)^4 - ri^4))/2)
line 7: 2*(1.57 x 10^-4) x 2*ri(hollow) =Pi*((2ri)^4 - ri^4
line 8: 2*(1.57 x 10^-4) x 2*ri(hollow) = (Pi*(2ri)^4) - (Pi*ri^4))
line 9: 2*(1.57 x 10^-4) x 2*ri(hollow) = Pi*ri^4
line 10: (2*(1.57 x 10^-4) x 2*ri(hollow)/pi = ri^4
line 11: (2*(1.57 x 10^-4) x 2*/pi = ri^4/ri(hollow)
line 12: (2*(1.57 x 10^-4) x 2*/pi)^0.333 = ri
but this doesn't work...
I just can't seem to graps this particular transformation. Beleiev it or not I'm not as dumb as this is making me out to be :)
Your first algebra (or arithmetic) mistake occurs in line 7; 2*2*ri = 4*ri, not 2*ri. Your second algebra mistake occurs in line 9. In line 9, you are basically pretending (a*x)^n + (b*x)^n is equal to (a + b)*x^n, which is false. Try it on paper, and on your calculator, with example numbers for a, b, x, and n, until you thoroughly convince yourself whether it is true or false. Also study laws of exponents, rules of exponents, or exponents in an algebra book, until you figure out the allowed rules of exponents. You can only perform operations with exponents that are allowed by the rules of exponents. Your third algebra mistake occurs in line 12, again violating the laws of exponents. Therefore, study the laws of exponents. Afterwards, repost your work starting with line 6.
1. What is the concept of percentage saving in weight of hollow shaft vs solid shaft?
The concept of percentage saving in weight of hollow shaft vs solid shaft refers to the difference in weight between a hollow shaft and a solid shaft of the same material and dimensions. The percentage saving is calculated by dividing the weight difference by the weight of the solid shaft and multiplying by 100. This percentage indicates how much lighter a hollow shaft is compared to a solid shaft.
2. How is the weight of a hollow shaft different from a solid shaft?
The weight of a hollow shaft is different from a solid shaft because of the difference in material distribution. A hollow shaft has a hollow core, which results in less material being used, making it lighter than a solid shaft, which has a solid core.
3. What are the factors that affect the percentage saving in weight of hollow shaft vs solid shaft?
The percentage saving in weight of hollow shaft vs solid shaft depends on several factors, including the material used, the dimensions of the shaft, and the intended use of the shaft. Generally, the larger the dimensions and the lighter the material, the greater the percentage saving will be.
4. How does the percentage saving in weight of hollow shaft vs solid shaft impact performance?
The percentage saving in weight of hollow shaft vs solid shaft can have a significant impact on performance, particularly in applications where weight is a critical factor. A lighter shaft can improve the efficiency, speed, and overall performance of a machine or equipment, as it requires less energy to rotate or move.
5. What are some common uses for hollow shafts vs solid shafts?
Hollow shafts are commonly used in applications where weight and efficiency are essential, such as in the aerospace, automotive, and sports equipment industries. Solid shafts are typically used in heavy-duty applications that require strength and durability, such as in construction, mining, and industrial machinery. However, both types of shafts have a wide range of uses depending on the specific needs of the application.
9K
17K
  • Mechanical Engineering
