E=mc2 is more complicated that I originally thought
  • Thread starter kjamha
  • Tags
    E=mc2
In summary: Mass is not additive.In summary, the conversation delved into the concept of mass and its relation to subatomic particles and nuclear forces. It was explained that mass is a fundamental property of matter and is affected by the binding energy of particles in the nucleus. The discussion also touched on the conversion of matter to energy in nuclear reactions and the non-additive nature of mass.
kjamha
98
I've been reading up on radiation and it appears to me that if you add up all of the protons, neutrons, and electrons in the universe, the number would never change (except for temporary positron borrowing). I guess this is no surprise considering conservation of matter. On the other hand, because E=mc2, I thought that matter was converted to energy - I see now that m has nothing to do with matter and everything to do with inertial mass. So I am hoping someone can help me out of my confusion - how is it that subatomic particles (at rest) change their mass? does it simply have to do with the strong nuclear force? Maybe my question should be what is mass?
I don't think that's true.
Suppose you have an atom of tritium. N=2, P=1, and E=1, so their sum is 4. It decays to 3He, with N=1, P=2 and E=2, which sums to 5.
Mass or Inertia simply exists. We cannot explain it in terms of something simpler. It is a fundamental property of matter. So if you are looking for an explanation of mass in terms of simpler concepts you will be disappointed.
Mass or inertia certainly has something to do with the strong nuclear force. We can think of matter as being made up of neutrons, protons and electrons. And for most purposes we can think of inertia or mass as being directly proportional to the number of neutrons and proton-electron pairs. But if you want to measure mass precisely, you have to take into account the binding energies of those neutrons and protons in the nucleus. You will see from the periodic table that atomic mass of an element is not the atomic number multiplied by the mass of a single proton/electron pair + the number of neutrons multiplied by the mass of a single neutron. It is a bit more than that. The extra mass is due to the binding energy of the protons and neutrons in the nucleus due to the strong nuclear force. This binding energy, E, adds mass m to the nucleus ie: m = E/c^2.
AM
Andrew Mason said:
[...]You will see from the periodic table that atomic mass of an element is not the atomic number multiplied by the mass of a single proton/electron pair + the number of neutrons multiplied by the mass of a single neutron. It is a bit more than that. The extra mass is due to the binding energy of the protons and neutrons in the nucleus due to the strong nuclear force. This binding energy, E, adds mass m to the nucleus ie: m = E/c^2.
Binding energy is negative. The mass of an atomic nucleus is less than the sum of the masses of the neutrons and protons in that nucleus.
One proton is about 1.00727 atomic mass units.
One neutron is about 1.00866 atomic mass units.
The nucleus of an atom of Carbon-12 has 6 protons and 6 neutrons for an unbound total of 12.09558 atomic mass units.
In fact, Carbon-12 has, by definition, a mass of 12 atomic mass units exactly. The deficit is the binding energy.
nope. Most have disappeared into black holes where the vast majority of information in our universe is 'hidden' to us. In addition nuclear reactions, fission and fusion, converts a tiney portion of matter to energy... maybe about 2% or so for fission, for example.
m c2 = sqrt [E2 −(pc)2]. The values of m and p are different in different frames, but they are always different in ways that make this equality hold in every frame.
The mass of an electron, for example, appears different in different confinements...say in a lattice, for example...One way of describing such changes is as Andrew Mason posted; another view is to say that the degrees of freedom in a structure affect it's energy and hence it's observed 'mass'. For example, a proton-electron system [an atom] as whole can absorb the photon whereas a single, free electron can't due to energy-momentum conservation. In order to absorb a photon there must be additional degrees of freedom that can be excited...
Naty1 said:
[...]In addition nuclear reactions, fission and fusion, converts a tiny portion of matter to energy... maybe about 2% or so for fission, for example.
More like 0.1%
If you consult the periodic chart, you'll see that when measured in atomic mass units, the actual mass of U-235, Ce-140, Zr-94 and a free neutron are all within about 0.1% of the number of nucleons in each.
Note that nuclear fission conserves baryon number. Even though the sum of the masses of the fission products is less than the mass of the U-235 that was fissioned, the total number of protons plus neutrons is unchanged.
Where did your 2nd electron come from in the He3?
Presumably from the [itex]n \Rightarrow p^+ + e^- + \overline{\nu}[/itex] process for neutron decay?
Ah ok. Thanks Nugatory.
Naty1 said:
nuclear reactions, fission and fusion, converts a tiney portion of matter to energy... .
Are you saying that matter is converted into energy as well as mass? If you are, is the equation E=mc2 the same for matter?
What is the difference between "matter" and "mass"?
Only true for elements lighter then iron. That is why elements lighter then iron release energy when fused and require energy to split but elements heavier then iron release energy when split but require energy to fuse.
I think nuclear binding energy is always negative. If you take Uranium and remove all of it's protons and neutrons, it will require energy. It's simply that the DIFFERENCE in binding energy between different elements can result in a release when you convert one to another via fusion or fission. I believe this is one of the main reasons that fission and other decays typically results in things like Alpha particles being emitted. Their binding energy per nucleon is much higher than anything else on that end of the periodic table so you don't have to expend as much energy to eject them as you would individual protons.
No, jbriggs had it right. The binding energy is always negative (otherwise, the nucleus wouldn't hold together at all). What's special about iron is that it sits at the minimum of the curve of binding energy per nucleon; this value is always negative, but it's more negative for iron than anything else.
Energy is conserved! Mass is not converted into energy:
"If a body gives off the energy L in the form of radiation, its mass diminishes by L/c².
[..] The mass of a body is a measure of its energy-content"
- http://www.fourmilab.ch/etexts/einstein/E_mc2/www/
In a closed system, matter can be converted to radiation. In contrast, the system's mass is conserved.
Correct me if I am off on this, but I think of matter as the particles that make up "stuff". And I think of Mass a little differently. For example, let's assume that electrons are massless and you had 100 protons and 120 neutrons - they would make up a certain amount of mass, say 1000 units. But if you combine these particles to make certain elements, some of the mass is converted to energy (strong nuclear force)and the mass would be less than 1000 units, even though you still have the same amount of matter (100 protons and 120 neutrons). When I hear someone say that matter is converted to energy, I'm thinking of particles converting into energy - so that was my question to Naty1. Did he mean particles were being converted to energy, and if so, does e=mc2 apply.
"Matter" is ill defined in science. Its best to leave the word out completely if you want to get technical. The words mass and energy should suffice.
That's right, particles can be converted into energy. For example, an electron and positron can collide, and turn into two photons. The photons are particles as well, but they don't have rest mass, so I think they would be equivalent to your definition of 'energy'.
and e=mc2 does apply. This equation could mean one of two things: 1) the 'm' corresponds to the rest mass of a particle, so e would be the energy of the particle when it is measured at rest relative to the lab. 2) 'm' could instead correspond to the relativistic mass, and so this shows that energy and relativistic mass are the same thing, simply measured in different units.
Back to the example of a positron and electron colliding to make 2 photons, the energy and momentum will be conserved. Also, the invariant mass will be conserved. But if you count up the rest masses of the particles, this is clearly not conserved. Since to begin with, you have the rest masses of electron and positron, then after collision, none of the particles have any rest mass.
Edit for clarity: when I say the electron and positron collide and turn into two photons, I mean that the electron and positron are 'used up' in the collision, so they don't exist after the collision.
kjamha said:
Correct me if I am off on this, but I think of matter as the particles that make up "stuff". And I think of Mass a little differently. For example,[..], some of the mass is converted to energy [...] I'm thinking of particles converting into energy [..]
Not exactly; energy is conserved. You can however convert matter in radiation, see post #15 (just before yours, so you may have missed it). :smile:
bruceW, are all the particles you mention massless? What about Protons or neutrons? Would they be able to convert into energy (either directly or indirectly)?
harrylin, can you clarify your post #15? I do not understand what you mean when you state that "mass is not converted into energy". I read the link you posted to Einstein's 1905 paper, which states "The mass of a body is a measure of its energy-content". Additionally, isn't the essence of the e=mc2 to state that mass can be converted to energy and visa-verse?
An anti-proton and a proton, if they meet, will convert directly to energy in the form of photons. Likewise for a neutron and an anti-neutron.
A single proton cannot be converted to energy, but that's not because there's anything wrong with mass-energy equivalence, it's because the process would violate various conservation laws.
Yes, what nugatory said.
Also, electrons have 'rest mass', as do protons and neutrons, but photons don't.
Sure! :smile: The essence of E=mc2 is not how you heard it but what I cited (using your symbols):
If a body gives off the energy ΔE in the form of radiation, its mass diminishes by ΔE/c²
In equation: Δm=ΔE/c²
A lot of people are sloppy and say "mass" when they really mean "matter", and "energy" when they really mean "radiation". That can be very confusing. Even Einstein became sloppy in later years, but he formulated it very precisely in his first paper on that topic. What happens is that matter can carry internal energy away by means of radiation, just as he explained.
His paper is based on conservation of energy; that means that the total amount of energy is constant. Thus an amount of energy equal to the radiation energy is now lacking in the atom. That reduced internal energy can be indirectly measured as a reduction in weight. If you could convert mass into energy, then you would end up with more energy than before. :wink:
I am happy to have understood the last 3 posts, but I am left with another question regarding the fact that mass is not converted into energy. For example, say U-235 was to take on an extra neutron and split into Lanthanum-146 + Bromine-87 + 3 neutrons. The atomic weight of U is more than the combined atomic weight of La + Br + 3 neutrons. I always thought the lost mass was converted into energy. But I think you are saying the lost matter is converted into radiation (gamma and x-ray?). If that is the case, what makes the boom in the nuclear bomb?
Radiation is a form of energy, so you don't want to spend a lot of time worrying about the distinction between mass being converted into energy and mass being converted into radiation; the latter is a more specific statement of the former.
As Harrylin says, just about all mass conversion processes release most of their energy in the form of radiation. However, it's not all radiation all the time. Fission (which was unknown when Einstein developed E=mc2) imparts a fair amount of kinetic energy to the daughter nuclei because they're both positively charged so fly away from each other at high speed. Alpha particles carry kinetic energy for the same reason, although much less.
So when a nuclear weapon is detonated, two things are released. One is a flood of fast-moving massive particles (alpha particles and fission daughter nuclei) which transfer their kinetic energy to everything nearby as heat. The other is a flood of high-energy gamma and X radiation, which also heats everything nearby as it is absorbed. Thus, a substantial fraction of the energy released by the weapon ends up as heat in the immediate neighborhood... And that produces the shock wave and blast effects.
Wow, it all makes sense! Thank you everyone. So the reason for the decrease in mass is not because it is being converted to energy, but because there is less matter. True? Also, what about the strong nuclear force, where does that energy come from? Does it also come form matter?
No, the amount of particles is the pretty much the same, so I wouldn't say you had less matter. The difference is that BINDING ENERGY has been released. Energy has mass, and when you release it, that mass goes with it.
Look at it this way. The total mass is the same before and after the reaction. The difference is that the reaction moves mass and energy around.
That is not energy, it is a force. Fundamental forces are the cause of energy, they do not result from it.
kjamha said:
Wow, it all makes sense! Thank you everyone. So the reason for the decrease in mass is not because it is being converted to energy, but because there is less matter. True? [..]
As Drakkith says, often the amount of particles doesn't change. In Einstein's calculation the atom keeps the same number of protons and neutrons. So in such cases one usually doesn't say that matter is converted in radiation but that its mass is reduced. However, such things can be done in particle accelerators: sub-atomic particles ("matter") can be completely converted into gamma radiation - and even the other way round!
- http://en.wikipedia.org/wiki/Mass–energy_equivalence
- http://en.wikipedia.org/wiki/Electron–positron_annihilation
1. What does E=mc2 stand for?
E=mc2 is an equation developed by Albert Einstein in his theory of special relativity. It stands for energy (E) equals mass (m) times the speed of light squared (c2).
2. Why is E=mc2 considered complicated?
E=mc2 is considered complicated because it involves concepts from advanced physics, such as energy, mass, and the speed of light, which can be difficult to understand and visualize. It also has significant implications for our understanding of the universe.
3. Is E=mc2 applicable in everyday life?
Yes, E=mc2 is applicable in everyday life, as it is a fundamental equation that explains the relationship between energy and mass. It is used in various fields, including nuclear energy, particle accelerators, and even in the technology we use every day, such as GPS systems.
4. How does E=mc2 impact our understanding of the universe?
E=mc2 has had a significant impact on our understanding of the universe, as it shows that mass and energy are interchangeable and that the speed of light is the maximum speed at which energy and information can travel. It also forms the basis of Einstein's famous equation, E=mc2, which explains the relationship between mass and energy.
5. Can E=mc2 be proven?
Yes, E=mc2 has been proven through various experiments and observations in physics. It has consistently been shown to accurately describe the relationship between mass and energy, and its predictions have been confirmed in numerous experiments, including nuclear reactions and particle accelerators.
  • Other Physics Topics
