Finding the minimum speed of a loop the loop and finding the height of the hill
In summary, a roller coaster cart needs a minimum speed of 9.8 m/s to stay on the track. It gains 0.85 PE for every m it travels beyond the radius of the loop. If the cart has a speed of 9.89 m/s at the bottom of the loop, it has a KE of 9.89 m/s^2 at the top of the loop. When it reaches the top, it has an acceleration of 9.78 m/s^2 and a net force of 9.78 Newtons.
SherBear
81
I have a hill with a roller coaster cart on it and it goes down and around a loop-the-loop
the radius of the loop is 10m
Diameter=20m
What is the minimum speed the cart needs to go to keep it on the track?
There is no friction, what is the height of the hill?
Vtop=sqrt rg
to get the minimum speed the cart needs to go to keep it on the track is
Vtop= sqrt rg
=sqrt 10m(9.8 m/s^2)
Vtop=9.89 m/s ---------is this correct?
I don't know what to do for this problem
I forgot to add the third part, there is a rider on the bottom of the loop in a cart, what is N?
I have Ar=v^2 / r
9.89^2 m/s / 10m = 9.78 m/s
Then F=N-mg=ma
N=mg+ma
N= m (g+a)
N= 60 kg (9.8 m/s^2 + 9.78 m/s) =
N= 1,174.8 is that m/s or N as in Newtons?---------is this correct?
The velocity you calculated gives it enough energy to reach the height of the top of the loop, but that doesn't necessarily mean it stays on the track. If that were the speed at the bottom of the loop, how much KE would it have left at the top? What speed do you think it needs to have at the top to stay on the track?
No idea Haruspex?
If the cart has speed u at the bottom of the loop, how much KE does it have?
How much PE does it gain in reaching the top of the loop?
How much KE then does it have left (as a function of m, r, g and u)?
What forces act on it when it is at the top of the loop?
What is its acceleration if it is still staying on the track at speed v?
What net force is required to achieve that acceleration?
These are the steps you need to go through.
Ok, thank you. Any idea about the height of the hill ?
Once you know the KE it needs at the bottom of the loop, it's easy to work out the PE it needs at the top of the hill.
How can I go through those steps if it only gives me the diameter?
Is it 2R - 1/2 R ?
20-5 = 15m ?
Do you have any answers for the steps I listed? Answer what you can and we can take it from there.
1. How do you calculate the minimum speed needed for a loop the loop?
The minimum speed needed for a loop the loop can be calculated using the formula v = √(gr), where v is the minimum speed, g is the acceleration due to gravity, and r is the radius of the loop.
2. What factors affect the minimum speed of a loop the loop?
The minimum speed of a loop the loop is affected by the radius of the loop, the mass of the object, and the force of gravity. A larger radius or lighter object will require a lower minimum speed, while a smaller radius or heavier object will require a higher minimum speed.
3. How do you find the height of the hill for a loop the loop?
The height of the hill for a loop the loop can be calculated using the formula h = r(1-cosθ), where h is the height of the hill, r is the radius of the loop, and θ is the angle of the loop (usually 360 degrees).
4. Can you use the same formula to find the minimum speed and height of the hill for any loop the loop?
Yes, the same formula (v = √(gr) and h = r(1-cosθ)) can be used to find the minimum speed and height of the hill for any loop the loop, as long as the loop is a perfect circle and the object is traveling along the inside of the loop.
5. What happens if the minimum speed is not reached in a loop the loop?
If the minimum speed is not reached in a loop the loop, the object will not have enough centripetal force to complete the loop and will fall off the track. It is important to always ensure that the minimum speed is reached for safety and to prevent accidents.
11K
