How do UK levels compare to the EU levels I know ?
In summary: So if I were to go to university in the UK, and I wanted to do a physics degree, I would need to get an honours degree?No, a regular bachelor's degree will do. However, an honours degree is usually more prestigious and likely to lead to a better job.In summary, UCL offers a certificate of higher education in physics which is useful for those preparing for university physics. A level, AS, A2, Ax etc. all compare to a bachelor, but are not as useful outside of the UK. There are evening classes in physics in the UK, EU, or other places as long as they are in English
xrcr9709
Hello,
I currently have a bachelor in IT (evenig classes). I live in Belgium and the only grades I know are Bachelor/Master/PhD. Maybe I would like to find evening classes in physics, even if it's in another country (very hypothetical for now).
I'm currently looking for infos about the possibilities in the UK.
- How do the A level, AS, A2, Ax etc.compare to a bachelor ?
- Are they useful outside of the UK ?
- Any place you would recommand for this kind of studies ?
- Are there bachelor/master in phyics in evening classes somewhere (UK, EU or else as long as it's in English or French)
- I already know about the Open University. Could be an option, be as I understand it you study at home on your home. Is it righ ? And I not to enthousiast about that.Thank you
Hi there!
First of all A Levels are what we in UK take before going to university to do a bachelors. However, if you feel like you need some preparation before taking university physics I would recommend doing a certificate of higher education at somewhere like Birkbeck in London. Birkbeck specialises in evening classes. I know people who have done this and they seem to be better prepared than those with A levels.
In the event that you feel you're ready to start a bachelors in physics straight off, I know UCL at least used to do a part time evening degree in physics. So might be worth a look. At present with a bachelors in IT I think you'll struggle to get accepted in a physics masters program. Hope this helps
Thank you for your reply.
UCL London has this certificate (seems to be 1 evening/week for 2 years): http://www.ucl.ac.uk/phys/admissions/certificate/index/
But it sounds a little bit as a hobby, am I right ? I guess it doesn't allow to go further in the studies ?
The UCL astronomy certificate does look like a interest qualification. Whereas the one at birkbeck is preparation for BSc Physics. Also lots of universities have a foundation year for those with no maths or physics background.
After a quick search it looks like UCL has got rid of its evening bachelors degree, and it doesn't look like any uk universities do evening physics degrees (at least I can't find them). The open university is a quality institution and offers great flexibility. I would say though with OU degrees you need lots of self motivation.
Well, I thought the OU would have the advantage of being internationl, but it looks like most courses are only available to UK and Iralend.
Though according to this page http://www.openuniversity.edu/courses/approved-study-area?field_course_study_area_tid=47&field_course_level_value=All , some bachelors are available in my current country, but on this one http://www3.open.ac.uk/study/undergraduate/qualification/q64.htm , they aren't.
What exactly is a BSc (Honours) ? I guess BSc is a Bachelor in science, what does Honours mean in this context ?
Honours just means that you have passed all modules and you get a classified degree i.e. 1st (>70%), 2.1(60%-69%), 2.2 (50%-59%), 3rd (40%-49%).
If you fail some of the required elements of the honours degree, the university can award you an 'ordinary' degree, which doesn't have a classifications. In other words an honours degree is the only one worth getting.
If I get it it's as when in my IT bachelor I got "High honors" (>80%), but I could have succeeded with 50-79%. At least in this country's culture it doesn't add much value to the diploma.
So why would an honours degree be the only one worth getting ? Is it more important in this context ?
Graduating without honours is a pass/fail degree awarded at the discretion of the university. This is, I would have thought, is seen as worse than graduating with a third class honours degree. Most degrees in science in uk are honours degrees
I gather that when the European universities adopted the ECTS system as set by the Bologna process, they also adopted the "BSc-->MSc-->PhD" system. BUT...there are still some differences.
For instance, you would be hard pressed to find a 90 ECTS, one-year master's degree outside of the UK. In Germany, France, and Switzerland, most are 2-year, 120 ECTS master's! France, for example, calls its undergraduate degree the "Licence." Franco-Belgian universities call it the "Bachelier."
It would appear that the "bachelor's with honours" concept is mainly a UK one. Outside of the UK, it's just a bachelor's. In the past, I think a degree was awarded "with honours" if one took an alternative, more rigorous course sequence, obtained high grades in them, and wrote a bachelor's thesis. Actually, that's more or less how it is in the US now, with honors degrees.
In Australia (and possibly New Zealand), a degree with honors is simply the 4th year of a bachelor's degree. One can graduate after 3 years with a regular bachelor's, but if one wants to do a PhD, then one does the honour's year. I believe one can actually enroll in a master's program without an honour's bachelor's degree, but I have not checked in a long time.
The University of Delhi has also adopted a similar structure, where one can exit after 3 years with a regular B.A/B.Sc or 4 years, with the honours variant. Its entering class for this year will be the first to go through this new system. It would appear that the new system takes a lot from the American model as well, seeing as one can do majors, minors, and has general education requirements to fulfill. Further, one can also exit after 2 years with an associate's degree.
(this is only based on my observations; clearly, I have nothing better to do with my life...)
Thank you for all that info. Now it will makes anything I can read on a universty site even more unclear (since they define bachelors in different ways).
Just to complete your info, in Belgium we have some 60 ECTS masters. Mainly evening classes I think.
The latter URL directs you to the international prospectus, which is the former URL.
Note that the OU doesn't do a BSc Physics degree, but they have a BSc Natural Sciences... like Cambridge... you should consider that just as good. As with Cambridge, if you do all the physics options that is great preparation for MSc or PhD work in physics, which you can then do at any University in the UK, and probably most in Europe (?)
Other useful URLs:
http://www.open.ac.uk/science/physical-science/courses-and-qualifications/physics-strand
1. How do UK levels compare to the EU levels I know?
The comparison between UK levels and EU levels is complex and depends on the specific metrics and data being analyzed. Generally, the UK's levels tend to be similar to or slightly higher than the EU average in areas such as education, healthcare, and economy. However, there are also significant variations within the UK and EU countries, making it important to examine specific regions and indicators.
2. Are there any notable differences between UK and EU levels?
Yes, there are notable differences between UK and EU levels in certain areas. For example, the UK has a higher GDP per capita than the EU average, but also has a higher income inequality and poverty rate. Additionally, the UK has a higher rate of private healthcare spending compared to the EU, where healthcare is primarily publicly funded.
3. How does the UK's education level compare to the EU's?
The UK and EU have similar overall education levels, with the UK having a slightly higher percentage of individuals with tertiary education. However, there are also significant differences in educational attainment within the UK and EU countries, with some countries having higher rates of secondary and tertiary education than others.
4. Are there any significant economic differences between the UK and EU levels?
There are several economic differences between the UK and EU levels. For example, the UK has a higher GDP per capita and lower unemployment rate compared to the EU average. However, the UK also has a higher national debt and lower labor productivity than the EU average.
5. How do the healthcare systems in the UK and EU compare?
The healthcare systems in the UK and EU differ in many ways. The UK has a primarily publicly funded system, while many EU countries have a mix of public and private healthcare. The UK also has a higher rate of healthcare spending compared to the EU average, but this does not necessarily translate to better health outcomes. Additionally, there are differences in access to healthcare and health outcomes within the UK and EU countries.
  • STEM Academic Advising
  • STEM Career Guidance
