What is the difference between conservative and nonconservative force?
In summary, non-conservative forces do not take into consideration the degree of freedom of the objects involved.
Outrageous
374
Conservative force like gravitational force has direction.
Non conservative force like frictional force has no direction.
so non conservative force doesn't take degree of freedom into the consideration.
Is that the meaning? please help.
Thank you
What makes you say a non-conservative force has no direction? All forces have direction. A conservative force is one for which there exists an associated potential function.
sorry , actually I want to say frictional force is the force that its direction can be changing all the time.
For gravity , i know we have gravitational potential energy ,this is because we define some place be zero potential and then compare potential energy of a object relative to that zero potential.
We can't do the same to the frictional force because the frictional force do not have fixed direction? how to say frictional force is not potential function?
No it has nothing to do with direction. The direction of gravity can easily change: for example a radial gravitational field has a different direction as you turn around. The point is that for conservative forces, the work done in moving from one point to another is independent of the path taken so we can construct a well-defined potential function. For friction on the other hand, the work done depends on the path so we cannot create a meaningful potential function for friction.
So besides look at it as a potential function , can I say that every time if the work done depends on the path then there is a non conservative force act ?
Can you please give me another example of conservative force , please.
Yes you can. Another example of a conservative force is the electrostatic force.
Thank you so much
Conservative forces are those that do not dissipate energy and are path independent, meaning that the work done by the force is only dependent on the initial and final positions of an object. Examples include gravitational and elastic forces. Nonconservative forces are those that dissipate energy and are path dependent, meaning that the work done by the force is dependent on the path taken by an object. Examples include friction and air resistance.
How do conservative and nonconservative forces affect an object's potential and kinetic energy?
Conservative forces do not change an object's total mechanical energy, as they only transfer energy between potential and kinetic forms. Nonconservative forces, on the other hand, decrease an object's total mechanical energy as they dissipate energy in the form of heat or sound.
Can conservative forces do work on an object?
Yes, conservative forces can do work on an object by changing its potential energy into kinetic energy, or vice versa. However, the work done by conservative forces does not result in a net change in an object's total mechanical energy.
What factors determine whether a force is conservative or nonconservative?
The path independence of work done and the conservation of mechanical energy are the main factors that determine whether a force is conservative or nonconservative. If a force follows the principle of conservation of energy, it is considered a conservative force.
How can you tell if a force is conservative or nonconservative?
To determine if a force is conservative or nonconservative, you can calculate the work done by the force on an object along different paths. If the work done is the same for all paths, the force is conservative. If the work done varies depending on the path taken, the force is nonconservative.
  • Other Physics Topics
  • Classical Physics
  • Mechanics
  • Classical Physics
