Thread Closed
The Pioneer effect and Spacecraft flyby anomaly
Share Thread
Feb28-13, 10:49 AM   #1
Does general relativity explain the Pioneer effect and the spacecraft flyby anomaly? I have seen several papers on those two topics but no GR explanation.
PhysOrg.com science news on PhysOrg.com
>> Leading 3-D printer firms to merge in $403M deal (Update)
>> LA to give every student an iPad; $30M order
>> CIA faulted for choosing Amazon over IBM on cloud contract
Feb28-13, 11:02 AM   #2
Mentor
There appears to be no mystery with these space crafts. Did you miss this news?
http://physicsworld.com/cws/article/...maly-ruled-out
Zz.
Feb28-13, 11:45 AM   #3
I will access the link, read, and come back to you.
Meanwhile, have you read whether GRT explains either or both? Please be specific; will appreciate it.
Feb28-13, 12:33 PM   #4
Recognitions:
SinghRP, I have read the link, and it gives a full explanation. Suggest you do too!
Feb28-13, 12:40 PM   #5
Recognitions:
Gold Membership Gold Member
Quote by SinghRP View Post
Quote by Bill_K View Post
I don't think the linked article/paper explains the Flyby anomaly, or does it?
AFAIK, the flyby is still an open anomaly (e.g. http://ntrs.nasa.gov/archive/nasa/ca...2009009651.pdf and http://arxiv.org/abs/1210.7333)
Feb28-13, 01:38 PM   #6
Recognitions:
Yep, you're right. Sorry.
Feb28-13, 02:13 PM   #7
This is what I know so far.
1. The Pioneer anomaly is due to thermal (kinetic) effect. Probably heat is from the spacecraft itself.
2. I believe only the NEAR spacecraft to an asteroid showed some significant flyby effect around Earth. At present they have fitted a curve with the data. They have accounted for Earth's varying gravitational filed. Etc., etc.
GRT needs to explain it. It has not; I wonder why not. This could be a crucial test for GRT!
A physicist friend thinks it is special-relativistic effect. But I can't say anymore here due to the Forum's rules. I will come back here after his paper is published.
Thanks muchly.
Feb28-13, 11:13 PM   #8
Astro/Cosmo 2012
Recognitions:
Retired Staff Staff Emeritus
The Pioneer anomaly was completely bogus:
Iorio, "Does the Neptunian system of satellites challenge a gravitational origin for the Pioneer anomaly?," http://arxiv.org/abs/0912.2947
F. Francisco, O. Bertolami, P. J. S. Gil, J. Páramos, "Modelling the reflective thermal contribution to the acceleration of the Pioneer spacecraft," http://arxiv.org/abs/1103.5222
Turyshev, Toth, et al. http://arxiv.org/abs/1204.2507
The flyby anomaly is not as well understood, but Toth thinks it's just a data analysis artifact due to switching between solar-system barycentric coords and geocentric coords. Anderson had an empirical formula for the anomaly, but the formula predicted an anomaly for Rosetta, and in fact no anomaly was observed for Rosetta.
Mar1-13, 08:52 AM   #9
Thank you all for your responses. I agree with bcrowell.
1. Has someone investigated the effect of variations in the Earth's gravitational field or in the classical gravitational constant on the Pioneer effect and/or the Earth spacecraft-flyby effect?
2. Can someone get me in contact with one at NASA who could provide me with related flyby data, particularly how the osculating orbit was determined?
Mar6-13, 12:02 PM   #10
Recognitions:
Quote by ZapperZ View Post
Zz.
It is interesting to look at the actual data for the anomalous acceleration. it is available at:
arXiv: gr-qc/0104064v5
What one sees is three distinct signatures;
(1) The effect gradually appears over a distance of about 5 AU or so reaching a maximum of about 10*10^-8 cm/sec^2 at 20 AU and staying more or less constant after that out to at least 70AU.
(2) There is a definite yearly small variation in the magnitude at a certain position related to the earth's rotation around the sun in its orbit
(3) There is a much larger (order of 100*10^-8 cm/sec^2) term with a period equal to the earth's period of rotation (24 hours)
IN view of these facts, the thermal explanation does not seem valid: It should appear much sooner than 5 AU, more or less all the time; it does not address either the small annual term or the diurnal large term. I don't believe the thermal explanation.
davidf32.
Mar6-13, 12:19 PM   #11
Mentor
Quote by davidf32 View Post
davidf32.
Then I look forward to reading your response in PRL to their paper.
Zz.
Mar7-13, 07:24 AM   #12
mfb
Mentor
The error bars below 15 AU are so large, I would not trust those values.
Quote by Paper
The annual and diurnal terms are very likely different
manifestations of the same modeling problem. The magnitude
of the Pioneer 10 post-fit weighted RMS residuals
of ≈ 0.1 mm/s, implies that the spacecraft angular position
on the sky is known to ≤ 1.0 milliarcseconds (mas).
(Pioneer 11, with ≈ 0.18 mm/s, yields the result ≈ 1.75
mas.) At their great distances, the trajectories of the
Pioneers are not gravitationally affected by the Earth.
(The round-trip light time is now ∼ 24 hours for Pioneer
10.) This suggests that the sources of the annual and
diurnal terms are both Earth related.
Such a modeling problem arises when there are errors
in any of the parameters of the spacecraft orientation
with respect to the chosen reference frame. Because
of these errors, the system of equations that describes
the spacecraft’s motion in this reference frame
is under-determined and its solution requires non-linear
estimation techniques. In addition, the whole estimation
process is subject to Kalman filtering and smoothing
methods. Therefore, if there are modeling errors in
the Earth’s ephemeris, the orientation of the Earth’s spin
axis (precession and nutation), or in the station coordinates
(polar motion and length of day variations), the
least-squares process (which determines best-fit values of
the three direction cosines) will leave small diurnal and
annual components in the Doppler residuals, like those
seen in Figures 17-18.
In short: If you don't know the exact position of the spacecraft, you get some wiggles due to the motion of earth. This does not influence the average, however.
Mar7-13, 08:40 AM   #13
Thanks for your responses. I agree with those who pointed out that the Pioneer effect and the spacecraft flybys “mystery” are not clearly understood. They can’t be with our current knowledge of gravitation. I tried to explain the two effects with GRT – no success.
I would not trust observations claiming accelerations as small as 10**-10 m/s/s. Also -- this is the acceleration they claim that the galaxies in the universe are accelerating at!
Thanks to davidf32, who pointed out that the effects were gradual! I DID NOT KNOW THAT. Applying my physicist’s intuition, I think the effects could be due to variations in the classical gravitation constant G. Dirac said that a long, long time ago that G was not constant. Now, why and how G would be varying, I don’t know.
How can I get the Pioneer and flyby data from NASA? So far, I have not succeeded.
Mar7-13, 11:19 AM   #14
Mentor
When you have published your idea in a mainstream physics journal then it can be discussed here. Until then it is unfounded and unsubstantiated speculation.
Thread closed.
Thread Closed
Similar discussions for: The Pioneer effect and Spacecraft flyby anomaly
Thread Forum Replies
Looking for someone who can do calculations on flyby anomaly. Astrophysics 9
Will GR ever explain the flyby anomaly? Special & General Relativity 17
With the Pioneer anomaly out of the way, could GOCE measurements account for flyby? Astrophysics 2
Flyby Anomaly General Astronomy 7
Flyby anomaly trajectories Astrophysics 1
