F continuous at x[sub]0[/sub], prove g is continuous atx[sub]0[/sub]
  • Thread starter kathrynag
  • Tags
    Continuous
In summary, we are trying to prove that if f: E--> R is continuous at x0 and x0 is an element of F contained in E, then g:F--->R defined by g(x)=f(x) for all x elements of F is also continuous at x0. We use the definitions of continuity, |x-x0|<δ and |f(x)-f(x0)|<ε, to prove that |x-x0|<δ and |g(x)-g(x0)|<ε. However, the continuity of g at x0 does not necessarily imply the continuity of f at x0, as shown by a counterexample using step functions.
kathrynag
598
Suppose f: E--> R is cont at x0 and x0 is an element of F contained in E. Define g:F--->R by g(x)=f(x) for all x elemts of F. Prove g is continuous at x0. Show by example that the continuity of g at x0 need not imply the continuity of f at x0.
lx-x0l<delta
lf(x)-f(x0)l<epsilon
lx-x0l<delta
lg(x)-g(x0)l<epsilon
lf(x)-f(x0l<epsilon
Ok, then it's continuous because g(x)=f(x)?
Your proof isn't very convincing. Write it out in words.
Morphism's point is that "sketched" the proof but you need to say exactly why those statements prove the theorem.
Ok, but how would I do the part with showing by example f doesn't need to be continuous. Wouldn't it ahve to be continuous since g(x)=f(x)?
Do g and f have the same domain...?
No, so if f is in E, then g could still be continuous?
F is a subset of E, so we know f is continuous. Hence, for all e>0, there exists d>0 such that
|x-x0<d and x in E implies |f(x)-f(x0|<e
Hence
|x-x0<d and x in F implies |f(x)-f(x0|<e
But f(x)=g(x) and f(x0)=g(x0)
Hence |x-x0<d and x in F implies |g(x)-g(x0|<e
This is a much clearer way of writing the proof
For a counterexample, I would suggest looking at step functions
Thanks!
Ok, I'm confused on finding an example. Like what if I choose the function [x]?
1. What is the definition of continuity at a specific point?
The definition of continuity at a specific point x[sub]0[/sub] is that for a function f(x), the limit of f(x) as x approaches x[sub]0[/sub] is equal to the value of f(x[sub]0[/sub]). In other words, the function must have a smooth and unbroken graph at x[sub]0[/sub].
2. How is continuity at a point related to the limit of a function?
Continuity at a point x[sub]0[/sub] is directly related to the limit of a function at that point. If a function is continuous at x[sub]0[/sub], it means that the limit of the function at x[sub]0[/sub] exists and is equal to the value of the function at x[sub]0[/sub].
3. What is the epsilon-delta definition of continuity at a point?
The epsilon-delta definition of continuity at a point x[sub]0[/sub] is a precise mathematical way of stating that the limit of a function at x[sub]0[/sub] exists and is equal to the value of the function at x[sub]0[/sub]. It involves using the concepts of epsilon (ε) and delta (δ) to show that for any small positive value of ε, there exists a corresponding small positive value of δ such that if the distance between x and x[sub]0[/sub] is less than δ, then the distance between f(x) and f(x[sub]0[/sub]) is less than ε.
4. What is the relationship between continuity at a point and continuity of a function?
If a function f(x) is continuous at every point in its domain, then it is called a continuous function. This means that the function has a smooth and unbroken graph for all values of x. Continuity at a specific point x[sub]0[/sub] is a necessary condition for a function to be continuous, but it is not sufficient. A function can be continuous at a point but not continuous overall if it has a discontinuity at another point.
5. How can we prove that a function g(x) is continuous at a point x[sub]0[/sub] given that f(x) is continuous at x[sub]0[/sub]?
To prove that g(x) is continuous at x[sub]0[/sub], we can use the definition of continuity and the properties of limits. Since f(x) is continuous at x[sub]0[/sub], we know that the limit of f(x) as x approaches x[sub]0[/sub] is equal to the value of f(x[sub]0[/sub]). From there, we can use algebraic manipulation and the fact that the limit of a product of two functions is equal to the product of their individual limits to show that the limit of g(x) as x approaches x[sub]0[/sub] is also equal to the value of g(x[sub]0[/sub]). Therefore, g(x) is continuous at x[sub]0[/sub].
