How many bytes are in 256 terabytes?
  • Thread starter ToxicBug
  • Tags
    Calculator
In summary, the number of bytes in 256 terabytes is 281,474,976,710,656 bytes. This can be calculated by using the formula 2^X,Y where X is the units and Y is the exponent. In this case, 256 terabytes is equivalent to 2^48 bytes, which is equal to 281,474,976,710,656 bytes. The conversation also discussed different methods for calculating this number, such as using exponent notation and squaring and multiplying.
ToxicBug
84
Can you give the EXACT number of bytes there are in 256 terabytes? If you can, show how you did it.
10000000000 0000000000 0000000000 0000000000 00000000 (in binary) since it is 1024 x 1024 x 1024 x 1024 x 256
1TB=2^{40}B;256TB=2^{48}B=2^{51}b=2Pb
Daniel.
You have to give it in decimals, not in binary otherwise its too easy. Daniel your answer is wrong.
What do you mean:
256TB=2^{48}B=281474976710656B
Daniel.
This sounds sort of like a homework problem. "If you can, show how you did it," said ToxicBug.
To me,it sounds like something really stupid...I don't know why i even bothered to answer...:yuck:
Daniel.
I tried just counting up to that number on my fingers and toes, alas I maxed out at 1,048,575. Right now, I have the population of Anchorage, AK working on the problem.
Oh, please, please hurry before too many fingers and toes fall off from frost bite :frown:
I just wanted to see if people know the trick for it.
Its a lot easier than that.
You take 2^X,Y where X is the units, for example: 0 - bytes, 1 - kilobytes, 4 - terabytes, etc. Then for Y you find the exponent 2^Y for the number. 256 is 2^8, so the answer is 2^48.
And why wasn't my answer right...?BTW,on both posts it coincides with yours...:wink:
Daniel.
ToxicBug,
Exponent notation is not a trick, it's a very normal tool used by almost all mathematicians, engineers, and physicists.
- Warren
And how is this a decimal representation ?
Because its decimal numbers, not binary :rolleyes:
Good point...He probably meant the 15 digit number...BTW,it's called "BASE 10".
Daniel.
2^48 without a calculator?
Wow, i must of been gone way to long. :uhh:
Any one can do it,provided he/she has a piece of papaer and a pencil,so let's not exaggerate...
Daniel.
2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 x 2 ... that is a lot of twos. I should be doing something else more productive right about now.
You would square 1024, square the result, then multiply that by 128.
I second that.:)
1. What are some tips for doing math without a calculator?
One tip is to practice mental math regularly to improve your skills. Another is to break down complex calculations into smaller, more manageable parts. Additionally, using estimation and rounding techniques can make solving problems easier without a calculator.
2. How can I do long division without a calculator?
Long division can be done using the traditional method of writing out the problem and solving it step by step. Another technique is to use repeated subtraction to find the quotient. You can also use estimation to check your answer.
3. What are some common mental math strategies?
Some common mental math strategies include using shortcuts such as multiplying by 10 or dividing by 2, using the distributive property, and breaking down numbers into smaller factors. You can also use patterns and relationships between numbers to solve problems mentally.
4. How can I improve my mental math skills?
One way to improve mental math skills is to practice regularly. You can also challenge yourself with more difficult problems and try to solve them without a calculator. Additionally, learning different mental math strategies can help you approach problems in different ways.
5. Why is it important to be able to do math without a calculator?
Being able to do math without a calculator can improve critical thinking and problem-solving skills. It also allows for a deeper understanding of mathematical concepts and builds confidence in one's abilities. In real-world situations, having strong mental math skills can also save time and be more practical than relying on a calculator.
  • Computing and Technology
