Process design of vapor-liquid separation drums
In summary, the conversation discusses the sizing and design of a vapor-liquid separator drum, or knock-out pot, used in the separation of a liquid and vapor mixture. The size of the drum is determined by the anticipated flow rate of vapor and liquid, and the design should include a vertical pressure vessel with a length-to-diameter ratio of 3 to 4, allowing for 5 minutes of liquid inventory between the normal liquid level and the bottom of the vessel. The maximum allowable vapor velocity can be calculated using the Souders-Brown equation, and the vessel should have a vapor outlet at the top, liquid outlet at the bottom, and feed inlet above the half-full level. The design should also include a de-entraining mesh
mbeychok
In Metric units:
A vapor-liquid separator drum is a vertical vessel into which a liquid and vapor mixture (or a flashing liquid) is fed and wherein the liquid is separated by gravity, falls to the bottom of the vessel, and is withdrawn. The vapor travels upward at a design velocity which minimizes the entrainment of any liquid droplets in the vapor as it exits the top of the vessel.
The size a vapor-liquid separator drum (or knock-out pot, or flash drum, or compressor suction drum) should be dictated by the anticipated flow rate of vapor and liquid from the drum. The following sizing methodology is based on the assumption that those flow rates are known.
Use a vertical pressure vessel with a length-to-diameter ratio of about 3 to 4, and size the vessel to provide about 5 minutes of liquid inventory between the normal liquid level and the bottom of the vessel (with the normal liquid level being at about the vessel's half-full level).
Calculate the vessel diameter by the Souders-Brown equation to determine the maximum allowable vapor velocity:
V = (k) [ (dL - dV) / dV ]^0.5
where:
V = maximum allowable vapor velocity, m/sec
dL = liquid density, kg/m3
dV = vapor density, kg/m3
k = 0.107 m/s (when the drum includes a de-entraining mesh pad)
Then A, the cross-sectional area of the drum:
in m2 = (vapor flow rate, in m3/s) / (vapor velocity V, in m/s)​
and D, the drum diameter:
in m = ( 4 A / 3.1416 )^ 0.5​
The GPSA Engineering Data Book recommends the following k values for vertical drums with horizontal mesh pads (at the denoted operating pressures):
0 barg: 0.107 m/s
7 barg: 0.107 m/s
21 barg: 0.101 m/s
42 barg: 0.092 m/s
63 barg: 0.083 m/s
105 barg: 0.065 m/s
GPSA Notes:
1. K = 0.107 at 7 barg; subtract 0.003 for every 7 bar above 7 barg
2. For glycol or amine solutions, multiply above K values by 0.6 – 0.8.
3. Typically use one-half of the above K values for approximate sizing of vertical separators without mesh pads.
4. For compressor suction scrubbers and expander inlet separators, multiply K by 0.7 – 0.8
The drum should have a vapor outlet at the top, liquid outlet at the bottom, and feed inlet at somewhat above the half-full level. At the vapor outlet, provide a de-entraining mesh pad within the drum such that the vapor must pass through that mesh before it can leave the drum. Depending upon how much liquid flow you expect, the liquid outlet line should probably have a level control valve.
As for the mechanical design of the drum (i.e., materials of construction, wall thickness, corrosion allowance, etc.), use the same methodology as for any pressure vessel.
In English units:
where:
V = maximum allowable vapor velocity, ft/sec
dL = liquid density, lb/ft3
dV = vapor density, lb/ft3
k = 0.35 ft/s (when the drum includes a de-entraining mesh pad)
in ft2 = (vapor flow rate, in ft3/s) / (vapor velocity V, in ft/s)​
in ft = ( 4 A / 3.1416 )^ 0.5​
0 psig: 0.35 ft/s
100 psig: 0.35 ft/s
300 psig: 0.33 ft/s
600 psig: 0.30 ft/s
900 psig: 0.27 ft/s
1500 psig: 0.21 ft/s
GPSA Notes:
1. K = 0.35 at 100 psig; subtract 0.01 for every 100 psi above 100 psig
Milt Beychok
(Visit me at http://www.air-dispersion.com" )
Thanks for sharing. Very informative.
This was a necro post from 2006. (The second by the same OP). It didn't ask any question, so it got no replies. But it does have 18K views from people who found it via Internet searches. It must be a really hot topic.
In 2019, we have PF Insights for articles in addition to threads for questions. Alas, I can't contact the OP. His email bounces. But I am bumping it in the Materials forum just to bring it to your attention.
1. What is the purpose of a vapor-liquid separation drum?
A vapor-liquid separation drum is used to separate a mixture of gas and liquid components that enter the drum from a process. It is typically used in industries such as oil and gas, chemical, and pharmaceutical where separation of vapor and liquid phases is necessary for efficient production processes.
2. How does a vapor-liquid separation drum work?
A vapor-liquid separation drum works by utilizing the difference in physical properties between the gas and liquid components. The mixture enters the drum and is slowed down, allowing the heavier liquid phase to settle at the bottom while the lighter vapor phase rises to the top. The two phases are then separated and discharged from the drum through different outlets.
3. What factors are considered in the process design of a vapor-liquid separation drum?
The process design of a vapor-liquid separation drum takes into account factors such as the flow rate and composition of the incoming mixture, the properties of the gas and liquid components, and the desired separation efficiency. Other important factors include the operating pressure and temperature, as well as the size and shape of the drum.
4. What are some common types of vapor-liquid separation drums?
Some common types of vapor-liquid separation drums include horizontal drums, vertical drums, and spherical drums. Horizontal drums are typically used for high liquid flow rates, while vertical drums are better suited for low liquid flow rates and smaller footprints. Spherical drums are used for high pressures and have the advantage of being self-supporting.
5. How is the performance of a vapor-liquid separation drum evaluated?
The performance of a vapor-liquid separation drum is evaluated based on its separation efficiency, which is the percentage of the gas and liquid components successfully separated. Other important factors to consider include the pressure drop across the drum, the residence time of the mixture in the drum, and the overall stability and reliability of the drum in operation.
  • Mechanics
  • Mechanical Engineering
  • General Engineering
10K
  • Aerospace Engineering
23K
