Doppler Effect inconsistent in terms of relative velocities
In summary: The two situations are not the same. In one, the sound source is moving relative to the air. In the other, the observer is moving relative to the air.
memoguy
29
Hi all!
Let me use an example to make this clear. There is a car traveling directly toward a man at 10m/s. The car is pressing down its horn, producing a frequency of 100hz. The speed of sound is 330 m/s. What frequency does the man hear?
Ok, so we can use the equation:
f_observer=( (v+v_o)/(v-v_s ) ) * f_source
Where v=330, v_o=0 & v_s = 10
Thus f_observer = 103.125
But, if the car was still and the observer moved toward the car at 10m/s we could say:
Where v=330, v_o=10, v_s =0
thus f_observer = 103.0303...
103.0303 does not equal 103.125.
Why is there a difference, surely these two things could be the same.
To see the difference, think about extreme situations, like
(1) the source is moving towards the observer at twice the speed of sound (660 m/s)
(2) the observer is moving towards the source at 660 m/s
No, they are not the same. Sound moves through air so all speeds are measured relative to air which gives us an absolute reference frame. Motion is not relative here. Compare that with the relativistic Doppler effect for electromagnetic waves (light).
[tex]f_o=f_s \sqrt \frac{c+v_{rel}}{c-v_{rel}},[/tex]
where [itex]v_{rel}[/itex] is the relative speed between source and observer. Here there is no medium and the speed of the source is measured relative to the observer. Motion is relative here.
memoguy said:
Hi all!
Sound waves, travel with constant speed in the medium (when pressure, temperature, humidity.. are constant). So when the source is moving it emits a wave, travel some distance and emits again (time between emissions is time period of the wave.)
So the source gets closer to the observer and the second wave has shorter distance to go and it arrives sooner than if the source was stationary.
The speed of the wave relative to observer is the same as this with stationary source(wave can not move in the medium slower or faster ) => speed of sound in the medium.
When the source is stationary and observer is moving, the speed of wave relative to him is the sum of his speed and waves speed (they are traveling against each other and wave travels with the speed of sound in the medium)
http://hyperphysics.phy-astr.gsu.edu/hbase/sound/dopp.html
What is the Doppler Effect?
The Doppler Effect is a phenomenon where the frequency of a wave appears to change when the source of the wave is in motion relative to the observer.
How does the Doppler Effect work?
The Doppler Effect works by compressing the wavelength of a wave when the source is moving towards the observer, and stretching the wavelength when the source is moving away. This results in a change in frequency, which is perceived as a change in pitch for sound waves or a change in color for light waves.
Why is the Doppler Effect inconsistent in terms of relative velocities?
The Doppler Effect is inconsistent in terms of relative velocities because it depends on the relative motion of the source and observer. If the source is moving faster than the observer, the effect will be more pronounced, but if the source is moving slower, the effect will be minimal.
Does the Doppler Effect only apply to sound waves?
No, the Doppler Effect can also be observed in other types of waves, such as light waves. This is known as the Doppler Shift and is used in astronomy to measure the velocity of stars and galaxies.
How is the Doppler Effect used in everyday life?
The Doppler Effect has many practical applications in everyday life. It is used in radar and sonar technology to determine the speed and location of objects, in weather forecasting to track the movement of storms, and in medical imaging to detect and diagnose abnormalities in the body.
  • Other Physics Topics
