Register to reply
He2 molecule
by khanhhung2512
Tags: molecule
Share this thread:
khanhhung2512
#1
Jul17-14, 07:40 AM
P: 15
This is a question in "Chemical Principles, 6th Edition, Steven Zumdahl":
Bond energy has been defined in the text as the amount of energy required to break a chemical bond, so we have come to think of the addition of energy as breaking bonds. However, in some cases the addition of energy can cause the formation of bonds. For example, in a sample of helium gas subjected to a high-energy source, some He2 molecules exist momentarily and then dissociate. Use MO theory (and diagrams) to explain why He2 molecules can come to exist and why they dissociate.
And this is from the solutions manual:
The ground state MO electron configuration for He2 is (σ1s)2(σ1s*)2 giving a bond order of 0.
Therefore, He2 molecules are not predicted to be stable (and are not stable) in the lowest energy
ground state. However, in a high-energy environment, electron(s) from the antibonding orbitals in
He2 can be promoted into higher-energy bonding orbitals, thus giving a nonzero bond order and
a “reason” to form. For example, a possible excited-state MO electron configuration for He2 would
be (σ1s)2(σ1s*)1(σ2s)1, giving a bond order of (3 – 1)/2 = 1. Thus excited He2 molecules can
form, but they spontaneously break apart as the electron(s) fall back to the ground state, where
the bond order equals zero.
What do you think about the solution? I think it's incorrect.
Phys.Org News Partner Chemistry news on Phys.org
Marine pest provides advances in maritime anti-fouling and biomedicine
Nature inspires a greener way to make colorful plastics
New catalyst converts carbon dioxide to fuel
Greg Bernhardt
#2
Jul22-14, 10:48 PM
Admin
Greg Bernhardt's Avatar
P: 9,334
I'm sorry you are not finding help at the moment. Is there any additional information you can share with us?
Borek
#3
Jul28-14, 04:15 AM
Admin
Borek's Avatar
P: 23,395
Quote Quote by khanhhung2512 View Post
Why do you think so?
khanhhung2512
#4
Jul29-14, 12:38 AM
P: 15
He2 molecule
Quote Quote by Borek View Post
Because with this explanation, excited-state configuration (σ1s)2(σ1s*)1(σ2s)1 with bond order 1 seems stabler than ground-state configuration (σ1s)2(σ1s*)2 with bond order 0, while it's not the case.
Borek
#5
Jul29-14, 01:59 AM
Admin
Borek's Avatar
P: 23,395
with this explanation, excited-state configuration (...) seems stabler than ground-state configuration (...) while it's not the case.
Question starts telling you it IS the experimental fact, doesn't it?
khanhhung2512
#6
Jul29-14, 05:16 AM
P: 15
I think the question didn't tell us anything about the configuration of the He2 molecule in high-energy environment.
Borek
#7
Jul29-14, 06:27 AM
Admin
Borek's Avatar
P: 23,395
Well, it doesn't say anything about configuration, but it tells us the molecule exist. And the explanation given is quite plausible to me.
You have stated
but you never explained WHY it is not the case.
khanhhung2512
#8
Jul29-14, 10:17 AM
P: 15
You have stated
Because the ground state is lower in energy, and thus is stabler than the excited state, whatever bond orders they have.
My explanation for this He2 question is as followed: In high-energy environments, some He atoms will exist in the excited state. Two He atoms might then form a He2 molecule with configuration (σ1s)2(σ1s*)2 which is stabler than the two excited He atoms. After that, this He2 molecule will decompose to ground-state He atoms.
Borek
#9
Jul29-14, 11:14 AM
Admin
Borek's Avatar
P: 23,395
That's where you are wrong. For a "standard" molecule - one that doesn't have filled antibonding orbital - that would be true. But we are talking about molecule that is not a standard one - it has a filled antibonding oribtal, which makes is completely unstable in the ground state. However, antibonding effect of the excited antibonding orbital is weaker than the antibonding effect of the antibonding orbital in the ground state - so once the antibonding orbital gets excited, its overall effect on the molecule stability gets lower and the molecule becomes stable.
Two excited atoms would not create a molecule in the ground state.
khanhhung2512
#10
Jul29-14, 12:00 PM
P: 15
Suppose you're correct, then why would stabler excited He2 molecules spontaneously break apart as the electron(s) fall back to the ground state?
Borek
#11
Jul29-14, 01:35 PM
Admin
Borek's Avatar
P: 23,395
Because in the ground state the antibonding effect of the antibonding orbitals gets higher than in the excited molecule - and it gets high enough for the molecule to become unstable
Think about is this way: at the end of the excited states of the molecule there is an ion, He2+ - and it is perfectly stable even in the ground state, as single electron on the antibonding orbital is not able to counteract two electrons on the bonding orbital. When you ad an electron and neutralize He2+ to He2 - but leave the molecule excited - it is still stable. It will get unstable once the electron drops to the ground state.
khanhhung2512
#12
Jul29-14, 09:13 PM
P: 15
I mean, what's the reason the stable, low-energy excited state would spontaneously drop electron to transform to the unstable, high-energy ground state?
Borek
#13
Y, 02:51 AM
Admin
Borek's Avatar
P: 23,395
Excited state doesn't have lower energy! It has a higher energy, which is what makes the antibonding effect weaker.
When the bonding orbital gets excited, bonding effect is lower.
When the antibonding orbital gets excited, antibonding effect is lower.
Molecules stability reflects the difference between bonding effect and antibonding effect.
khanhhung2512
#14
Y, 04:08 AM
P: 15
I still haven't understood all of what you're saying, but it's making sense to me now. Thank you very much. One more question, please. What kind of book do I need to read or study to have such a good knowledge of physical chemistry as yours, or at least to be able to fully comprehend this He2 problem?
Thanks again.
Borek
#15
Y, 05:57 AM
Admin
Borek's Avatar
P: 23,395
I am afraid I won't be of much help when it comes to books - the ones I can suggest will be in Polish, so of no use for you.
Register to reply
Related Discussions
Polarity in water molecule and electronegativity of oxygen in that molecule. Chemistry 7
Fat molecule, protein molecule Chemistry 1
How is the energy of an excited electron in one molecule sent to another molecule? Biology, Chemistry & Other Homework 4
Is h_2 consider a molecule? Biology, Chemistry & Other Homework 2
Gas Molecule Introductory Physics Homework 2
