Understanding bell's theorem: why hidden variables imply a linear relationship?
In summary: Bell's theorem does not hold. In summary, the proof/logic of Bell's theorem goes thus: with the measurements oriented at intermediate angles between these basic cases, the existence of local hidden variables would imply a linear variation in the correlation. However, according to quantum mechanical theory, the correlation varies as the cosine of the angle. Experimental results match the [cosine] curve predicted by quantum mechanics.
  • #351
Nugatory said:
Of course it does not necessarily apply. But it does apply if we make two additional assumptions, namely counterfactual definiteness and fair sampling within statistically representative sets. Which of these assumptions do you reject?
I partly agree and partly disagree. If we start talking about measurements of the predermined outcomes, then since we have 3 outcomes but only 2 identical photons, we can only measure a pair of properties, and the other two pairs are counterfactual. In other words, CFD is NOT an additional assumption, to derive Bell's inequality for a single pair.
For three different pairs, we can measure each correlation term from a different pair and CFD does not come in at all. It would not even make since to "assume CFD" in this case. What would that even mean?
There is however an additional assumption that can be made, which you may call "fair sampling" although it is more subtle than you describe. We may assume for the three separate photon pairs that a1=a2 and b1=b3 and c2=c3. Extending this to three separate sets of photon pairs, this means the 6 lists of outcomes from the separate sets can be reduced to 3 pairs of identical lists [a1:a2, b1:b3, c2:c3], in which not only the number of +1s and -1s must be the same in each pair, but also the pattern of switching between +1 and -1 in each list. Let me explain another way. If you place the six lists side by side, each row should obey a1=a2 and b1=b3 and c2=c3 OR it should be possible to sort them (while keeping pairs from a set together) so that the six lists obey a1=a2 and b1=b3 and c2=c3. Only then will the 3 photon pairs in each row obey Bell's inequality and consequently the correlations from the three sets will obey the inequality.
Obviously this is more subtle than the regular "fair sampling".
  • #352
lugita15 said:
I'm not sure what properties you're talking about.
You did not say if you understood the argument in #345 and #346. The properties are the correlations.
  • #353
lugita15 said:
Anyway, let me just ask you this. For each of the four sets p, q, r, and s, we can calculate the following relative frequencies:
1. The relative frequency of getting (1,-1) or (-1,1) for f(-30,0)
2. The relative frequency of getting (1,-1) or (-1,1) for f(0,30)
3. The relative frequency of getting (1,-1) or (-1,1) for f(-30,30)
Now you've already agreed that all of these relative frequencies are the same for p, q, and r. But you've disagreed that all of these relative frequencies are the same for p, q, r, and s.
I'm not sure you are getting all the subtleties yet, that is why I ask you to confirm if you understand the argument in #345 and #346. You started by saying p, q, and r are completely distinct sets, and s = (p + q + r). And then you go on to talk of measuring f(-30,0), f(0,30) and f(-30, 30) in s and the results of these measurements being the same as the results from completely distinct sets p, q and r.
The reason I disagree with this is because if you define "p" as the set of photons from "s" which
did not match for f(-30,0), and "q" as the set of photons in "s" which did not match for f(0,30), and "r" as the set of photons which did not match for f(-30,30), then it is impossible for "p", "q" and "r" to be completely distinct sets, contrary to our starting assumption. That is why the relationship between three measurements on a single set "s" is not the same relationship between three measurements from three "independent" sets "p", "q", and "r". If you are admitting that "p", "q", and "r" are not independent/distinct/separate sets, then we are not going anywhere towards answering the core issue.
  • #354
Yes, and I'm still saying that. (Although I'd use the union sign rather than the plus sign.)
I'm sorry if I was imprecise. By "getting" I didn't mean measuring. Let me rephrase:
1. The relative frequency of f(-30,0) being equal to (1,-1) or (-1,1)
2. The relative frequency of f(0,30) being equal to (1,-1) or (-1,1)
3. The relative frequency of f(-30,30) being equal to (1,-1) or (-1,1)
No, that's not how I'm defining them at all. I'm simply defining them to be a set of photon pairs measured at (-30,0), a set of photon pairs measured at (0,30), and a set of photon pairs measured at (-30,30), respectively.
No, p, q, and r are definitely three completely separate sets, and s is their union.
  • #355
Please confirm that you understand and/or agree with the argument in #345 and #346. AFTER you've done that, I will explain using a similar argument why your inequality based on set "s" does not necessarily apply to terms from three distinct sets p, q and r.
  • #356
I apologize, but I'm not that familiar with Bell's original proof, so I can't really comment much on the validity of what you're saying in these posts. So if you don't mind, rather than making analogies with another Bell's theorem proof, can we just stick to the line of reasoning that I've been presenting to you?
Can you please just present your argument directly, without relying on posts #345 and #346? And before you get to why the inequality doesn't apply, can you back up and answer my question about whether the relative frequency of something can be the same in three disjoint sets and yet different for their union?
  • #357
The argument is self contained. You do not need any information outside of those posts to understand the argument. If you do not understand that argument, you very likely won't understand the core issue.
  • #358
billschnieder said:
However if we calculate the "ab" term from the first photon pair, the "ac" term from the second photon pair and "bc" from the third pair (ie, a1b1, a2c2, b3c3), is it reasonable to expect the inequality |ab + ac| - bc ≤ 1 to be obeyed?
Similarly if we calculate the "ab" correlation from the first set of photons, the "ac" correlation from the second set of photons and the "bc" correlation from the third set of photons (ie a1b1, a2c2, b3c3), is it reasonable to expect the inequality |C(a,b) + C(a,c)| - C(b,c) ≤ 1 to be obeyed?
I say the answer to the above two questions is NO. Let us see why, by verifying the maximum value of left hand side |a1b1 + a2c2| - b3c3
Clearly, the LHS is maximum when b3c3 = -1, a1b1 = a2c2 = ±1
Therefore the correct inequality for three different pairs is
|a1b1 + a2c2| - b3c3 ≤ 3 NOT |a1b1 + a2c2| - b3c3 ≤ 1
And, the correct inequality for 3 different sets is
|<a1b1> + <a2c2>| - <b3c3> ≤ 3 NOT |<a1b1> + <a2c2>| - <b3c3> ≤ 1
In other words, the relationship we derived from properties within a single pair of photons does not apply between properties from 3 different pairs of photons.
Do you agree?
No.
Because you are making the assumption that somehow the LHV knows on beforehand what the polarizer settings will be, which of course is non-locality.
Then only (best) feasible way to implement your “three-stage rocket” is to create a “random generator” that will assign 1 of 3 possible values/predetermined outcome, i.e. for (+30°, 0°) and (0°, -30°) and (+30°, -30°). The first two values/predetermined outcomes gives the same result/correlation, which gives you only 2 possible choices. Looking good, huh?
Now, you’re the “Bayesian Grandmaster Flash” and can easily do the calculations for this. However, I skip this part and tell you right away that there’s no way in h*ll your “random generator” (that delivers the right answer 50% of the time for 2 possibilities x 3 pairs/set) can beat QM that get it right 100% of the time, for every pair/set.
No way.
Sorry Bill, good try but it doesn’t work.
[I’ll get back on your first replies soon/later]
  • #359
I apologize, but I've been examining in great detail the inequality we've been talking about. On the other hand, if you give me an analysis of a completely different inequality, and ask me my opinion of that analysis, I can't readily spot whether or where you're making errors. So again, can you phrase your argument in terms of the concepts and terminology we've been discussing all this time?
  • #360
But I've already answered this question. I've already agreed that if the relative frequency of "something" is the same in three disjoint sets, then the relative frequency of that same "something" will be the same in the union of those three disjoint sets. The part you are not understanding, which I disagree with is if you take a single set, and measure the relative frequency of three different but logically related things in that same set, and write an inequality which relates those three things, that inequality which you have now written, does not necessarily apply to the three disjoint sets. For this to be obvious, you will have to write down clearly how you arrived at the inequality from the single set, by writing down clearly the starting equation. I'm talking about the statement
lugita15 said:
do you agree that
the relative frequency of getting (1,-1) or (-1,1) for f(-30,30) in s is less than or equal to the relative frequency of getting (1,-1) or (-1,1) for f(-30,0) in s, plus the relative frequency of getting (1,-1) or (-1,1) for f(0,30) in s?
I agreed to this question already. However, to make things clear, please can you prove this inequality by deriving it, it will be evident later why this is important and since you brought it up, let it be on you to derive it from a single set "s".
  • #361
DevilsAvocado said:
No.
And where did you get such a ridiculously wrong idea from, in anything I said?
  • #362
OK, let us start by you deriving the inequality you brought up, quoted in my previous post to you.
  • #363
The ridiculous idea:
--> I say the answer to the above two questions is NO. <--
If you could just explain in fairly simple English exactly how three (3) different photon pair/sets are going to violate Bell’s inequality without CHANGING their properties between the three (3) different photon pair/sets?
It doesn’t work, does it?
Without change you will get THE SAME result as “one pair/set”, right?
Now, what are you going to use as ‘parameter’ for your change? I’m all ears...
  • #364
Why do they have to change anything? They are three different pairs, each pair is free to have values +1 and -1 for each of the outcomes.
Wrong. Again you are surely confused about something, there is no changing involved. For a single a pair, you have 8 possible outcome combinations, ALL of which satisfy the inequality. For three separate pairs, you have 64 possible outcome combinations, 16 of which violate the inequality.
  • #365
The same ridiculous idea:
I’m just wondering... of 64 possible outcome combinations you have the grand opportunity to get it right – and violate the inequality – in one out of four = 25% ... what are you going to do with the 75% that blow your dream into pieces?? Dismiss them as “illegal”??
  • #366
A single violation is enough to disqualify the inequality as a valid rule for three separate pairs. What part of that don't you understand? If you want to keep the inequality for three separate pairs, it is you who will have to design a system which actively eliminates the 25% "illegal" cases.
  • #367
Please Bill, you can’t be serious... you are going to cherry pick 16 combinations out of 64 and stop there and convince yourself that this is science/math...
Gosh... I thought you knew probability theory. I can win the lottery every day with your “magical formula”...
I guess this is getting way out in “Outer Crackpot Space”. I’m sorry Bill, my time is unfortunately not infinite and this is going absolutely nowhere (except to OCS)...
Take care and have a nice summer.
  • #368
billschnieder said:
But I've already answered this question. I've already agreed that if the relative frequency of "something" is the same in three disjoint sets, then the relative frequency of that same "something" will be the same in the union of those three disjoint sets..
Well, you did seem to agree initially. But then when I asked you whether all three relative frequencies have the same value for s that they do for p, q, and r, you said no. Well, if you don't think all three relative frequencies have the same value for s as they do for p, q, and r, then that means you think that at least one of them DOESN'T have the same value for s as it does for p, q, and r. In other words, you must think the relative frequency of something can be different for the union even though it's the same for the three sets. Where am I going wrong here?
All right, for any photon pair in s, if f(-30,30) is equal to (1,-1) or (-1,1), then either f(-30,0) is equal to (1,-1) or (-1,1), or f(0,30) is equal to (1,-1) or (-1,1).
Therefore, the number of photon pairs in s for which f(-30,30) is equal to (1,-1) or (-1,1) is less than or equal to number of photon pairs in s for which f(-30,0) is equal to (1,-1) or (-1,1), plus the number of photon pairs in s for which f(0,30) is equal to (1,-1) or (-1,1). Dividing both sides by the total number of photon pairs in s, it follows that the relative frequency in s of f(-30,30) being equal to (1,-1) or (-1,1) is less than or equal to the relative frequency in s of f(-30,0) being equal to (1,-1) or (-1,1), plus the relative frequency in s of f(0,30) being equal to (1,-1) or (-1,1).
  • #369
I don't what to make any assumptions about your ability to understand simple logic so I will explain again and hopefully you will understand this time. If somebody argues that A ≤ B, and I produce one instance in which A > B, the argument is disproved. Do you understand this simple logic? So if out of 64 possible outcomes A > B for 16 of them, those are 16 different reasons, each powerful enough to disprove the argument on it's own, but together providing overwhelming evidence that without a doubt, the original argument is false. There is no cherry picking involved. It is the person making the original argument who will now have to cherry pick and say, "but A ≤ B is valid only for these 48 possibilities, in which those 16 are not allowed". Do you understand this simple logic?
If you do not understand even this, then there is no hope left. :cry: Maybe if you read DrC's signature, you might understand it.
  • #370
Obviously, this is not an accurate representation of my disagreement. We are discussing a topic with may subtle elements and it pays to be proper in characterizing the components of the discussion. When you talk of "all three relative frequencies" it could mean f(-30,0) in p, f(-30, 0) in q and f(-30, 0) in r. But it could mean f(-30,0) in p, f(-30,30) in q and f(0, 30) in r. So you may be thinking that I disagree with one thing, when actually I disagree with something else and it has appeared to me at times that you are going back and forth between them without realizing the difference. For this reason, I would advice and appreciate that you adopt a more terse notation since your current one of talking about "f(-30,30) is equal to (1,-1) or (-1,1)" can easily obscure subtle issues. Since we are talking about mismatch at (-30, 30), I would suggest you simply say "M(-30,30)" if you don't mind, or any other more terse notation.
  • #371
Why must that be the case? Please be explicit.
I would say for 3 predetermined outcomes from a single pair of photons at -30, 0, 30, if the outcome at -30 mismatches the outcome at 30, then the outcome at 0 must mismatch one of either -30 or 30. Do you agree that this is how you arrived at the above?
This is a giant leap. Please I'll appreciate if you could show step by step how you went from the above to this inequality.
  • #372
Final comment:
Don’t want to crush your dreams or something, but you are not Einstein and you will not get a Nobel Prize for this mess, but it doesn’t matter much.
Go have a beer or two, see a football match, listen to some good music, dance with a beautiful girl, go out and enjoy the sun, swim in a lake – do anything but this crazy activity – because it will take you nowhere = total waste of time.
Now, listen to a wise-guy-avocado! :grumpy:
  • #373
OK, I'm fine with abbreviating "f(θ1,θ2) equals (1,-1) or (-1,1)" as M(θ1,θ2). Let me restate what I said in terms of this notation.
You agreed that the relative frequency of M(-30,0), the relative frequency of M(0,30), and the relative frequency of M(-30,30), are the same for p, q, and r. However, you disagreed that the relative frequency of M(-30,0), the relative frequency of M(0,30), and the relative frequency of M(-30,30), are the same for s as they are in p, q, and r. That means that you believe that the relative frequency of either M(-30,0), M(0,30), or M(-30,30) has a different value for s than it does for p, q, and r. Do I have that right?
  • #374
Yes, that's exactly how I arrived at it. (Except of course I'd replace "the outcome at" with "the outcome you would get at".) I was only talking about a single photon pair in that quote.
OK, so we know that for each photon pair in s, M(-30,30) implies M(-30,0) or M(0,30). Therefore, the set of photon pairs in s for which M(-30,30) is a subset of the set of photon pairs in s for which M(-30,0) or M(0,30). And this implies that the number of photon pairs in s for which M(-30,30) is less or equal to the number of photon pairs in s for which M(-30,0) or M(0,30). And then the number of photon pairs in s for which M(-30,0) or M(0,30) is less than or equal to the number of photon pairs in s for which M(-30,0), plus the number of photon pairs in s for which M(0,30). Therefore, the number of photon pairs in s for which M(-30,30) is less than or equal to the number of photon pairs in s for which M(-30,0), plus the number of photon pairs in s for which M(0,30).
  • #375
You keep jumping steps directly to the inequality. Is there a specific reason why? In other words, why is the set of pairs in s for M(-30,30) only a subset of pairs in s for "M(-30,0) or M(0,30)". Please be explicit.
  • #376
DevilsAvocado said:
Final comment:
Really! :biggrin: I doubt it. :rolleyes:
Translation: "My mind is made up, don't confuse me with the facts!"
  • #377
Sorry, I think you're having a misunderstanding about what subset means. A subset is allowed to equal the whole set. I think the term you're thinking of is proper subset.
A set A is said to be a subset of a set B if a being an element of A implies that a is an element of B. In our case, for any given photon pair in s, if M(-30,30), then M(-30,0) or M(0,30). Therefore, by definition of subset the set of photon pairs for which M(-30,30) is a subset of the set of photon pairs for which M(-30,0) or M(0,30).
  • #378
No. I think you are having a misunderstanding. I did not say it can not be the whole set. You said it was a subset. I'm asking you why you use the word "subset" to begin with rather than "whole set". You are implying by the choice of the word that there could be a situation in which it might not be the whole set and there might be situations in which it might be the whole set. I'm asking you to state explicitly what those situations are. In other words, I'm asking you to justify the inequality rather than just state it.
But since you did not answer, let me answer the question and you can tell me if you agree or disagree.
({M(-30, 0)} U {M(0, 30)}) * {M(-30,0)&M(0, 30)} = {M(-30,30)}
In words, the set in s where M(-30,30) is the difference of the set in s where "M(-30,0) or M(0,30)" and the set in s where "M(-30,0) and M(0, 30)". In the case where the set with "M(-30,0) and M(0, 30)" is null, the set where M(-30, 30) will be the same as the set where "M(-30,0) or M(0,30)". In other words the inequality implies that the set in s where "M(-30,0) and M(0, 30)" is either null or non-empty. Do you agree?
This is a crucial missing piece in your description as will be evident later.
  • #379
Yes, I agree with this, although I didn't need it to derive the inequality.
  • #380
Thought I'd dive in here:
That only works because (referring to the notation used in derivations of Bell inequalities), you've not only allowed the past information [itex]\lambda[/itex] to change from one round of a Bell test to the next, but you've given a model where the hidden variables are specifically tuned for the measurement settings in each round.
Suppose I add a subscript [itex]i[/itex] to the individual correlators, referring to the correlator's expectation value in the [itex]i[/itex]th round of a Bell experiment. Then if I understand you correctly, you're saying that Bell's theorem would only establish something like
[tex]C_{i}(\bar{a}, \bar{b}) + C_{i}(\bar{a}, \bar{c}) - C_{i}(\bar{b}, \bar{c}) \leq 1 \,, \quad \forall i \,. \quad(*)[/tex]
But in an actual Bell test, Alice and Bob might measure [itex](\bar{a}, \bar{b})[/itex] in the first round, [itex](\bar{a}, \bar{c})[/itex] in the second round, and [itex](\bar{b}, \bar{c})[/itex] in the third. There's no particular reason the inequality should hold for correlators from different rounds, so it is entirely possible that
[tex]C_{1}(\bar{a}, \bar{b}) + C_{2}(\bar{a}, \bar{c}) - C_{3}(\bar{b}, \bar{c}) \nleq 1 \,.[/tex]
If that's your point, then it's true but it doesn't invalidate Bell's theorem or render it untestable. The reason is that Alice and Bob's measurements are supposed to be chosen randomly, so you don't know in advance which measurements they're going to perform in each round. This matters because, while you can arrange for the Bell inequality to be violated for a particular sequence of measurements with a locally causal model, you can't arrange for it to be violated for all of them.
This is easy to see. Suppose we consider a three-round Bell test where each of the three terms in the inequality is measured once*, and we define [itex]S_{ijk} = C_{i}(\bar{a}, \bar{b}) + C_{j}(\bar{a}, \bar{c}) - C_{k}(\bar{b}, \bar{c})[/itex], with the labels [itex]ijk[/itex] identifying which correlator was tested in each round (there are six possible permutations: 123, 132, 231, 213, 312, 321). Then it is entirely possible that the inequality [itex]S_{123} \leq 1 [/itex] is violated, but not for instance all three of [itex]S_{123} \leq 1[/itex], [itex]S_{231} \leq 1[/itex], and [itex]S_{312} \leq 1[/itex] simply because the condition (*) above implies
[tex]S_{123} + S_{231} + S_{312} \leq 3 \,.[/tex]
The average over the six possible tests, which is also the expectation value of the full Bell correlator, satisfies the inequality: [itex]\langle S_{ijk} \rangle \leq 1[/itex].
So while it is possible to observe a Bell inequality violation according to local causality, such a violation would constitute a statistical outlier. It cannot be guaranteed deterministically if Alice's and Bob's measurements are not known in advance, and the probability of a significant Bell inequality violation drops exponentially fast in the number of rounds.
The bottom line is: to get anything more than an "accidental" Bell inequality violation in a locally causal model, it's not enough just to let the hidden variable [itex]\lambda[/itex] vary from one round of a Bell experiment to the next. It must also be correlated with Alice's and Bob's measurement choices (in violation of what's sometimes called the "no conspiracies" or "free will" assumption).
As an aside, is there a reason that this discussion has been based around Bell's original 1964 inequality? Refreshing my memory on it, my impression is that more modern Bell inequalities (such as CHSH) admit cleaner and more "black box" derivations.
* This is just for simplicity of exposition. Of course, there would be no way for Alice and Bob to do this without communicating with each other.
  • #381
wle said:
Thought I'd dive in here:...
Welcome to PhysicsForums, wle!
  • #382
Clearly then, you obtain your inequality by extending a relationship which exists between "outcomes you would get" for a single pair of photons to a set of such photons. That is you started with
What if you start with 3 different pairs of photons (1,2,3). Do you now agree that the following statement is not necessarily true:
M1(-30,30) implies M2(-30,0) or M3(0,30)
And consequently do you agree that the inequality you obtained by extending the relationship from a single pair to a single set is not necessarily true for three separate pairs and consequently 3 separate sets?
If you agree to the above two questions, do you agree that for the relationship for a single pair to be true for 3 different pairs, you MUST make an additional assumption? If you agree, I would like you to state that particular assumption and explain why it changes the relationship from one which is not necessarily true to one which is necessarily true.
  • #383
I do not agree with this characterization. There is no specific tuning involved in anything I've described. I've been talking about individual pairs, 3 different pairs, a single set, and three distinct sets. So I'm not sure what you mean by "round" in anything I described.
Suppose I add a subscript i to the individual correlators, referring to the correlator's expectation value in the ith round of a Bell experiment. Then if I understand you correctly, you're saying that Bell's theorem would only establish something like
That is not an accurate characterization of my argument. You can find the argument laid out clearly in three posts #270, #345 and #346. To obtain the inequality for a single set, I started with the relationship within a single pair and extended it to the single set just like Bell did. In other words, the inequality appears to be a relationship between statistics, but it is in fact an arithmetic identity in a single pair that has been extended to a single set.
  • #384
So you agree that the inequality is not a valid inequality for three separate pairs? Do you agree that the correct inequality for 3 separate pairs has a maximum of 3 on the RHS? Nobody claimed that the inequality must be violated for every 3 pairs. One is enough to demonstrate that the inequality is not valid for 3 separate pairs. If you want to apply it to 3 separate pairs, you must make an additional assumption about the 3 separate pairs. As concerns 3 separate sets, there is a long way between ≤1 and ≤3, and 1.1 is a violation just as much as 3. If somebody were claiming (though nobody is) a maximal violation of 3, then you could make the argument that it should be violated everytime.
But you do realize that
[tex]\langle S_{123} + S_{231} + S_{312}\rangle \neq \langle S_{123}\rangle + \langle S_{231}\rangle + \langle S_{312}\rangle[/tex] read that as not necessarily equal.
So the above argument is invalid unless you are making an additional assumption that whenever there is a violation in one of correlators, there will be a compensating correlation in the other correlators, and how is that possible without action at a distance. In otherwords, for your argument to be valid, you must assume action at a distance/conspiracy.
  • #385
Bell's inequality is about three separate expectation values, not three separate pairs. The results you actually measure for three pairs need not match the expectation values.
  • Quantum Interpretations and Foundations
11K
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
