What is order parameter and how to find critical temperature?
In summary: This estimate is correct to the first order in the order parameter. The order parameter is also the only quantity that can unambiguously distinguish between different phases of a material.
KFC
488
I am reading some material on phase transition. In those, they use order parameter quite a lot, but what is order parameter? What's the physical significance of it?
If I got the free energy , which involving order parameter m, how can I find the critical temperature?
Science news on Phys.org
The order parameter is the number that indicates in which phase you are, briefly put.
What the order parameter is, depends on your system. For example, if you are looking at a ferromagnet, the order parameter would be the average magnetisation (above the critical temperature, the magnetisation is random so the average is zero, below the critical temperature there is a clear preferred direction and the average will be non-zero); for a phase transition between liquid and gas, the order parameter may be the density.
The name comes from the fact that a phase transition usually (dis)orders the system - depending on which phase you are going to - for example by ordering / randomising the magnetisation directions or by ordering molecules in a lattice / breaking the lattice structure.
The phase transition usually occurs when the free energy changes minima. For example, if the free energy is of the form
[tex]F \sim \alpha(T) T^4 + \beta(T) T^2[/tex]
with [itex]\alpha > 0[/itex], then for [itex]\beta > 0[/itex] F only has a global minimum at T = 0. However, when beta changes sign, a new global minimum occurs at some temperature T > 0 and the system may "slip" from the now local minimum at T = 0 to the new minimum which has even lower energy.
Likes Ludwig64
The post of CompuChip pretty much explains it all. A small contribution:
In what is called Landau theory (= theory of second order phase transitions) one has the important property that the free energy is expressed in terms of the order parameter. On the basis of symmetries of the Hamiltonian, a proper order parameter and the fact that the free energy is an analytic function one can come up with a reasonable estimate (Taylor series) of the free energy.
1. What is an order parameter?
An order parameter is a measure of the degree of order or organization in a system. It is a physical quantity that can describe the state of a system in terms of its symmetry or structure.
2. How is order parameter related to critical temperature?
In systems undergoing a phase transition, the order parameter is directly related to the critical temperature. As the temperature approaches the critical temperature, the order parameter increases and reaches its maximum value at the critical temperature.
3. How do you determine the critical temperature of a system?
The critical temperature of a system can be determined experimentally by measuring the changes in the order parameter as the temperature is varied. The critical temperature is typically identified as the temperature at which the order parameter reaches its maximum value.
4. Can the critical temperature be predicted theoretically?
Yes, the critical temperature of a system can be predicted theoretically using various mathematical models and theories, such as the Landau theory or the mean field theory. However, these predictions may not always accurately reflect the experimental results.
5. Is the critical temperature the same for all systems undergoing a phase transition?
No, the critical temperature varies depending on the specific system and the type of phase transition. Different systems may have different critical temperatures even if they undergo the same type of phase transition.
  • Atomic and Condensed Matter
  • Thermodynamics
11K
  • Thermodynamics
