Which quantities are naturally forms, and which are (multi)vectors?
In summary, the conversation discusses the confusion between identifying whether a physical quantity is more naturally a (multi)vector or a form. Some examples, such as displacement vector and gradient being vectors, and reciprocal lattice vectors being 1-forms, are given to illustrate this confusion. The conversation also touches on the different interpretations of momentum and angular momentum as both a 1-form and a vector or a 2-form and a bivector, respectively. The question of whether there is a principled way to determine the natural form or vector for a given physical quantity is also raised.
chogg
129
Which quantities are "naturally" forms, and which are (multi)vectors?
I'm undertaking a self-study of geometric algebra and differential forms. It is very enlightening, but I find I'm getting a bit confused by which kind of beast is most "natural" for a particular physical quantity.
Where I'm at so far: I feel like I intuitively "get" the picture of contraction (vector with 1-form, bivector with 2-form, etc.), and how these quantities are naturally paired, without any need for a metric. References [1], [2], and [3] (among others) have been very helpful in attaining this intuition. Similarly, I "get" that there's a 1-to-1 mapping between vectors and 1-forms, bivectors and 2-forms, etc., but only if there's a metric.
What I really don't get is: for a given quantity, how do you tell whether it's "naturally" a (multi)vector or a form? Let me give some examples.
First, some easy ones. The displacement vector is obviously a plain old "pointy" vector, not a 1-form. Similarly, the gradient is a 1-form, not a vector, as [3] makes clear. It also seems to me that the reciprocal lattice vectors of crystallography are clearly 1-forms and not vectors; I find it very enlightening to visualize them as the lattice planes themselves.
What about momentum? MTW [2, sec. 2.5] discuss it as both a 1-form and a vector, saying they are equivalent by the dot product (which assumes a metric). I like the association with the wavefronts of the de Broglie wave (which favors the 1-form intepretation), but since it's the derivative of displacement, and displacement is a vector, isn't momentum more "naturally" a vector too?
Angular momentum is another source of confusion for me. The paper in [4] discusses it as a 2-form, based on converting x and p to their equivalent one-forms. But Lasenby and Doran [5, ch. 3] discuss it as a bivector. I think it makes more sense to me as a bivector! Then again, good ol' Wikipedia lists it as a 2-form.[6]
And what about the electromagnetic field? Bivector, or two-form? The venerable MTW [2, ch. 4] discuss it in terms of the latter. John Denker treats it as a bivector [7,8,9,10], but also mentions it as a 2-form [11]. I find it easy to think of F as a bivector, but its formulation as a 2-form seems more natural to me in many ways (i.e. increasing field strength corresponds to increasing density of field lines)
Is there a principled way to take a given physical quantity, and ascertain whether it's best to think of it as a form or a (multi)vector? Any pointers would be appreciated.
Thanks,
Chip
(References:)
[1] Weinreich, Gabriel. "Geometrical Vectors". University Of Chicago Press, 1998
[2] Misner, C., Thorne, K., and Wheeler, J. "Gravitation". W. H. Freeman, 1973
[3] http://www.av8n.com/physics/thermo-forms.htm#fig-bump-hump
[4] http://panda.unm.edu/Courses/Finley/P495/TermPapers/relangmom.pdf
[5] Doran, C. and A. Lasenby. "Geometric algebra for physicists". Cambridge University Press, 2003
[6] http://en.wikipedia.org/wiki/Angular_momentum
[7] http://www.av8n.com/physics/pierre-puzzle.htm
[8] http://www.av8n.com/physics/magnet-relativity.htm
[9] http://www.av8n.com/physics/maxwell-ga.htm
[10] http://www.av8n.com/physics/straight-wire.htm
[11] http://www.av8n.com/physics/partial-derivative.htm#sec-vis
Whoa Ho! That's sort of my modus operandi as well. Weinreich gives you the answer to some degree, its how they transform. Let me add one more reference: Theodore Frankel's book: The Geometry of Physics. He's all about what's natural.
Its tricky I think. I was just writing (and deleting) how momentum can be defined as fiber derivative of the Lagrangian (fancy words for what you'd see in any mechanics book) and those transform as components of a covector. But then you can also argue that the momenta are components of the Hamiltonian vector field on phase space.
Both have some metrical like properties I haven't fully sorted out yet. Depending on the Lagrangian the kinetic energy can define a metric and thus an inner product on tangent spaces and so you can just associate velocities to momenta via the metric. On phase space there's a very special 2-form which while not a metric, does create relations between contravariant and covariant critters via Hamilton's equations.
That being said momentum certainly seems naturally a 1-form since velocities are contra and the contraction of the two gives energy.
Not really an answer, but a reply :)
Thanks,
Chip
(References:)
In general forms and vectors can be transformed into each other with a metric.
The classic case is when the differential of a function is turned into a gradient vector.
df acts on vectors but in the presence of an inner product there is a vector called grad f which has the property that df(v) = <grad f,v> where <,> is the inner product.
In Euclidean space, especially in Physics courses, the distinction is often overlooked and this I guess is why you view the gradient of a function as a 1 form. really it is a vector and the one form is <grad f, > or simply df.
If one takes a force field - say the gravitational field - then it is usually described as a field of vectors. But really one knows the field from the work it does. The work is expressed as the integral of an inner product with the force field and that is a 1-form.
Thanks for the replies. A very interesting discussion of velocities and momenta. It made me realize I had been assuming that velocity and momentum are "naturally" the same kind of quantity, having [tex]p=mv[/tex] in my mind or something. Framing it in terms of the Lagrangian helps me see the difference. I think I follow when you say the energy can define a metric (in the abstract phase space), but I would need further study before I become really comfortable with it.
cous
I can understand your confusion about which quantities are naturally forms and which are (multi)vectors. This is a common question in the study of geometric algebra and differential forms. Let me try to provide some clarification.
First, it's important to understand that both forms and (multi)vectors are mathematical objects used to describe physical quantities. Forms are mathematical objects that represent geometric properties such as orientation, while (multi)vectors represent geometric entities such as points, lines, planes, etc. Both forms and (multi)vectors are important in understanding physical quantities, and the choice of which one to use depends on the specific problem.
Now, to answer your question about how to tell whether a quantity is naturally a form or a (multi)vector, there are a few things to consider. First, you need to understand the physical meaning of the quantity you are dealing with. For example, displacement is a vector because it represents a physical quantity that has both magnitude and direction. On the other hand, gradient is a form because it represents the rate of change of a scalar quantity in a particular direction.
Secondly, you need to understand the geometric properties of the quantity. For example, momentum is a vector because it has both magnitude and direction, just like displacement. However, angular momentum is a bivector because it has two components, magnitude and direction of rotation, which can be represented by a bivector.
In the case of the electromagnetic field, it can be represented as both a bivector and a 2-form. The bivector representation is useful for understanding the rotational properties of the field, while the 2-form representation is more useful for understanding the flux of the field.
In general, there is no one "correct" way to represent a physical quantity as either a form or a (multi)vector. It depends on the specific problem and what properties of the quantity you are trying to understand. It's important to have a good understanding of both forms and (multi)vectors and to use the appropriate representation for each problem.
I hope this helps clarify your understanding of which quantities are naturally forms and which are (multi)vectors. Keep studying and exploring, and you will continue to develop your intuition for geometric algebra and differential forms. Good luck!
1. What is the difference between a quantity and a (multi)vector?
A quantity is a numerical value that represents a physical property, such as length, mass, or time. A (multi)vector, on the other hand, is a mathematical object that contains both magnitude and direction and can represent quantities with multiple components, such as velocity or force.
2. How do I determine if a quantity is a naturally formed or (multi)vector?
A naturally formed quantity is one that arises directly from physical measurements or observations, such as length or mass. (Multi)vectors, on the other hand, are mathematical constructs that are used to represent physical quantities in a specific way, such as force or torque. To determine if a quantity is a (multi)vector, one must consider its properties and how it is used in a given context.
3. Can a quantity be both a naturally formed and (multi)vector?
Yes, a quantity can have both a natural form and be represented as a (multi)vector. For example, velocity is a naturally formed quantity that can also be represented as a (multi)vector with magnitude and direction.
4. Are all physical quantities naturally formed?
No, not all physical quantities are naturally formed. Some quantities, such as electric and magnetic fields, are not directly measurable and must be represented as (multi)vectors in order to understand and analyze their properties.
5. How are (multi)vectors used in scientific research?
(Multi)vectors are used extensively in scientific research to represent and analyze physical quantities that have magnitude and direction. They are particularly useful in fields such as physics, engineering, and mathematics, where understanding and manipulating these quantities is crucial for understanding natural phenomena and developing new technologies.
  • Differential Geometry
  • Quantum Interpretations and Foundations
