Dirac Expression for Vector Potential of a Magnetic Monopole Problem
In summary, the problem is to calculate the vector potential \vec{A}(\vec{x}) explicitly and show that it has components A_{r}, A_{\theta}, and A_{\phi}. The vector potential is given by the integral \vec{A}(\vec{x}) = \frac{g}{4\pi} \int_{-\infty}^{0} \frac{dz' \hat{z} \times (\vec{x} - z' \hat{z})}{\vert \vec{x} - z' \hat{z} \vert ^{3}}, and the components are A_{r} = 0, A_{\theta} = 0, and A
Harry134
Hi,
Consider the vector potential, [itex]\vec{A}(\vec{x})[/itex], below. The problem is to calculate [itex]\vec{A}(\vec{x})[/itex] explictly, and show that it has components [itex]A_{r}[/itex], [itex]A_{\theta}[/itex] and [itex]A_{\phi}[/itex]
[itex]\vec{A}(\vec{x})[/itex] = [itex]\frac{g}{4\pi} \int_{-\infty}^{0} \frac{dz' \hat{z} \times (\vec{x} - z' \hat{z})}{\vert \vec{x} - z' \hat{z} \vert ^{3}}[/itex]
[itex]A_{r} = 0[/itex], [itex]A_{\theta} = 0[/itex], [itex]A_{\phi} = \frac{g}{4 \pi} \frac{\tan{\theta / 2}}{R}[/itex]
This is a homework problem and I have seen the solution to it. However, I do not understand any of the solution or even where to start the problem.
Thanks
Just evaulate the integral and check whether it coincides with what's given as the vector potential in terms of spherical coordinates.
BTW: It might be easier to work with the local form of the Maxwell equations, extended with the presence of a magnetic point charge. You only need to consider the magnetostatics equations,
[tex]\vec{\nabla} \times \vec{B}=0, \quad \vec{\nabla} \cdot \vec{B}=g \delta^{(3)}(\vec{x}).[/tex]
Now except at the origin you have [itex]\vec{B}=\vec{\nabla} \times \vec{A}[/itex]. So you must find a vector potential with an appropriate singularity along a semiinfinite line (the famous Dirac string) such that it reproduces the [itex]\delta[/itex]-distribution singularity. In terms of [itex]\vec{A}[/itex] the equations read
[tex]\vec{\nabla} \times (\vec{\nabla} \times \vec{A})=0, \quad \vec{\nabla} \cdot (\vec{\nabla} \times \vec{A})=g \delta^{(3)}(\vec{x}).[/tex]
Another approach is to avoid the string and use different gauges in different regions of space along the lines of the very illuminating paper
T. T. Wu and C. N. Yang. Concept of nonintegrable phase factors and global formulation of gauge fields. Phys. Rev. D, 12:3845, 1975.
http://link.aps.org/abstract/PRD/v12/i12/p3845
1. What is the Dirac expression for the vector potential of a magnetic monopole problem?
The Dirac expression for the vector potential of a magnetic monopole problem is given by:
A = (g/4πr) * (1 - cosθ) * Ȳ + (g/4πr) * (1 + cosθ) * Ȳ + (g/4πr) * sinθ * ϕ
where A is the vector potential, g is the magnetic charge of the monopole, r is the distance from the monopole, θ is the angle between the radial direction and the position vector, and ϕ is the azimuthal angle.
2. What is the significance of the Dirac expression for the vector potential of a magnetic monopole problem?
The Dirac expression for the vector potential of a magnetic monopole problem is significant because it provides a solution to the long-standing problem of the existence of magnetic monopoles in nature. It is also important in the study of electromagnetism and quantum field theory.
3. How was the Dirac expression for the vector potential of a magnetic monopole problem derived?
The Dirac expression for the vector potential of a magnetic monopole problem was derived using mathematical techniques from quantum field theory. It was first proposed by physicist Paul Dirac in 1931, and later proven by physicist Julian Schwinger in 1948.
4. Can the Dirac expression for the vector potential of a magnetic monopole problem be applied to real-life situations?
While there is currently no experimental evidence for the existence of magnetic monopoles, the Dirac expression for the vector potential of a magnetic monopole problem can still be applied in theoretical and mathematical studies. It has also been used in the study of other fundamental particles and interactions in physics.
5. Are there any other proposed solutions to the magnetic monopole problem?
Yes, in addition to the Dirac expression, other theoretical solutions have been proposed to the magnetic monopole problem, such as the Schwinger solution and the Wu-Yang solution. However, these solutions have not been experimentally verified and the existence of magnetic monopoles remains a topic of ongoing research and debate in physics.
