Skhandelwal
- 400
- 3
First of all, can someone delete my table tennis post? Second, why does a tennis ball in a serve right after it bounces reduces its speed to half and increases its spin to double?
The purpose of spin on a tennis serve is to make the ball curve in a specific direction after it bounces on the opponent's side of the court. This can make it more difficult for the opponent to return the serve and create an advantage for the server.
The type of spin used on a tennis serve can affect the speed of the ball. Topspin adds extra speed to the ball as it bounces and travels through the air, while slice or underspin can slow down the ball. The speed of a serve can also be affected by the angle and trajectory of the ball, in addition to the spin.
A half speed serve in tennis is a serve that is hit with less power and speed than a full speed serve. This can be used as a tactic to surprise the opponent or to increase the chances of the serve going in. A full speed serve is hit with maximum power and speed, and is typically used to try to ace the opponent or create a difficult return.
In doubles tennis, the serve bounce and spin can be affected by the position of the server's partner. If the partner stands close to the net, the serve may need to be hit with less spin to avoid hitting the partner. Additionally, the type of spin used may vary depending on the type of return the server's team is trying to set up.
The tennis serve bounce is important in doubles because it can determine the type of return the opponent's team can make. A high bounce may allow for a more aggressive return, while a low bounce may make it more difficult for the opponent to hit a powerful return. The server's team can also use the bounce to their advantage by setting up specific plays or strategies based on the height and speed of the bounce.
