Is the Universe Spinning? | General Relativity
In summary, General Relativity allows for the possibility of a spinning universe, but it is difficult to determine if this is the case. Gravity Probe B will be able to provide more definitive answers about the spin rate of the universe.
Always curious
From a universe according to General Relativity can we ascertain if the Universe can be said to be spinning?
Spinning relative to what is a tough question - I would say perhaps a rate of spin relative to the age of the Universe might give a framework if it can be agreed that say 1 second after the BB the Early Universe was spinning or perhaps more properly could at least be said to have had Angular Momentum as it expanded?
I have no Grand Theory attched to this question I was just - as always - curious.
Astronomy news on Phys.org
The famous logician and pal of Einstein, Kurt Goedel devised a spinning Einstein style universe and showed that it contained closed timelike paths - code for achievable time travel.
That sounds interesting - time travle is always interesting though doubtful- what say the theorists?
A Machian view would say that the universe could not spin as a whole as it would need to rotate relative to something else; although one 'half' could rotate relative to the other 'half'.
Goedel's model could then, in a Machian view, to be construed as a refutation of GR.
Alternatively, from a GR point of view, it could construe a refutation of Mach's Principle. Perhaps Gravity Probe B will resolve the issue?
Garth
How?
More precisely, what limits could the 'best' (= most sensitive) results from GPB set on the rotation of the universe?
On another tack, there is at least one research effort underway to measure 'local rotation', using ring lasers ... could that work also constrain 'universal rotation'?
Finally, didn't I read that Hipparcos set some limits (not very stringent) on rotation of FK5? (I'll check later ...).
How?
My cryptic reference to possible non-GR results of that experiment! -and possible Machian alternative results.
As I said on another thread "Mach's Principle", my post #37:
Gravity Probe B will be able to tell, the predictions for General Relativity, the Brans Dicke theory and Self Creation Cosmology are:
Gravity Probe B:
GR prediction: Geodetic effect 6.6144 arcseconds/yr
Gravitomagnetic effect 40.9 millarcseconds/yr
BD prediction: Geodetic effect {(3w+4)/3w+6)}6.6144 arcseconds/yr
Gravitomagnetic effect {(2w+3)/(2w+4)}40.9 millarcseconds/yr
SCC prediction:Geodetic effect 5.5120 arcseconds/yr
Wait and see!
Garth
Thanks guys
When do we get the results of this probe you refer to?
PS: If the Universe is spinning would there be a different rate of spin from the early universe to the present Universe?
If expansion is increasing what would occur to the spinrate?
Always curious said:
Thanks guys
The experiment will end this (northern) Summer. Analysis of the results may take several months and results should be published early next year (06). However everything about GPB has taken twice as long as expected so I wouldn't hold your breath!
If there is an absolute inertial frame relative to which the universe is spinning, and in which angular momentum is conserved, then its spin rate would slow down with expansion. Conversely as you plot back into the Big Bang the spin rate should go up - infinitely so as t -> 0?? Perhaps that is a possible cause of a bounce?
Garth
Garth
Thanks Garth - I will look forward to these fascinating results (or more correctly the results of this fascinating experiment!)
Anyone else have any thoughts on the "bounce" Garth mentions?
Of course if would be a pancake bounce normal to the axis of rotation.
Garth
i have thought for years that it is spinning personally. and i thought this because i knew that galaxies, and everything else, is spinning. so the question is if a galaxy is spinning, then to what is its spin relative? and as far as what is relative to the spin of the universe that is impossible to ever prove. however, it is possible that one universe is spinning realtive to another, or to something bigger. we will just never know. but what we do know is that everything we know of is made of smaller couterparts down to the quark level. so it would make sense that our universe is maybe something similar to a cell in that makes up something even bigger. because to a cell our body would be a universe. and since everything is made on the atomic level, perhaps our universe makes up a bigger part of the "atom" per se.:rofl:
A rotating universe in the context of general relativity isn't rotating in quite the sense we usually think of it--there's no center of rotation, for example. As this page says:
When I tell people about the possibility of a rotating universe, their reaction is usually either a silly smile, or the very well motivated question: With respect to what would the universe rotate? I viciously reply: With respect to something that does not rotate, that is, something that does not experience any centrifugal forces. OK, this is correct, but it needs some elaboration.
First of all, don't try to imagine the universe as rotating as a whole. That way of thinking is misleading. I'll come back to rotation as a whole later.
Second, don't think that this implies some center of rotation. According to the Copernican principle, all places in the universe are equivalent. This is a simplifying assumption adopted by most cosmologists; whether it holds in reality is an open question. On smaller scale the universe is badly inhomogeneous, but there is still hope that the large scale structure is homogeneous.
Third, study carefully the following attempt to visualize a rotating universe.
Imagine you are in a laboratory without windows floating around somewhere in the universe. If you and the other objects in the laboratory get pressed against the walls, you would say that the laboratory is rotating, and centrifugal forces are responsible for the effects. Now, the laboratory happens to be equipped with small engines that can be used to control the rotation. Use the engines until you have totally eliminated the centrifugal forces, and thereby the rotation. When done, drill some peepholes in the laboratory (but please make sure you don't lose your air supply). Observe the galaxies. If you find that the galaxies rotate around you, then the universe is said to be rotating.
You have actually only seen that the universe rotates around the point where you are, but if the Copernican principle holds, then it rotates around any point. That's a rotating universe.
So keep in mind that when I talk about a rotating universe, I mean that the matter of the universe rotates around the non-rotating observer. There is a better word for it: vorticity. In classical hydrodynamics, the vorticity w of a velocity field v is defined using the rot operator:
[see page for image of equation]
In general relativity, there is a similar definition. One expresses the vorticity four-vector in terms of matter four-velocity field (a four-vector is a vector with one 'time' and three 'space' components).
Quoted article by JesseM said:
"...On smaller scale the universe is badly inhomogeneous, but there is still hope that the large scale structure is homogeneous..."
What an odd remark from someone writing about science. :smile:
An interesting topic ..
When one talks about a spinning universe, does one mean that all the galaxies and mass are spinning or does one mean that space (in between the galaxies) is also spinning ? If space itself is spinning, what does this actually mean ? There exists in general relativity also the so-called "frame-dragging" effect (a topic of investigation for the gravity probe B experiment). Could this also be interpreted that space is actually spinning around a rotating body ?
"Rotating universes"
Hi, Always curious,
Just thought I'd recommend some more reading:
You can find a new arXiv eprint with fabulous illustrations of closed timelike curves CTCs in the Goedel lambdadust solution as http://www.arxiv.org/abs/gr-qc/0611093. The classic description is in Hawking and Ellis, The Large Scale Structure of Space-Time, and if you search the arXiv you should find a dozen or so eprints discussing various aspects of this fascinating solution.
I also recommend Cuifolini and Wheeler, Gravitation and Inertia, for more about Mach's principle, frame dragging, gravitomagnetism, and rotating cosmological models, even though I don't feel this book comes up the high standards of exposition set in the classic textbook by Misner, Thorne, and Wheeler, Gravitation, Freeman, 1973.
That's not true in general; the so-called LRS (locally rotationally symmetric models) and the well-known Van Stockum dust are examples of cosmological models in which the matter (source of the gravitational field) is rotating about an axis with a definite location "in space". However, the Goedel lambdadust is homogeneous (not isotropic), so it does have the property you mentioned.
The issue of how to define "rotation" in curved spacetimes gets quite tricky and much ink has been spilled--- unfortunately, some contributions seem to involve "independently committing" the same errors which have been made (and corrected) in the past, so discussion can easily become contentious.
As always, the local versus global distinction is critical. There are distinct notions of "rotation" which are local in the sense of "jet space", principally vorticity (MTW, Hawking and Ellis, the book by Eric Poisson, A Relativist's Toolkit, are all good sources for the kinematical quantities known as the vorticity tensor, expansion tensor, and acceleration vector), and neccessarily more sophisticated notions which are global.
One thing to watch out for (for those who know what these buzzwords mean): in many "rotating" dust models, the "obvious" coframe read off the metric is often already inertial and even comoving with the dust particles, but the frame may be spinning. With luck, as in the Goedel lambdadust, you can "despin" the frame by applying, as you run along the world line of each dust particle, just the right rotation as a function of proper time about one of the spatial frame vectors. Here, note that in curved spacetimes, nonspinning inertial frames correspond to Lorentz frames in flat spacetime. Spinning but inertial frames correspond to, well, you probably get the idea.
Similar remarks hold for circularly polarized plane waves. Speaking of which, the Osvath-Shuecking circularly polarized gravitational plane wave solution is often touted as a "rotating" cosmological solution (although it is an exact vacuum solution, indeed a Petrov type N vacuum, not a fluid solution, so no matter is anywhere in sight!).
Chris Hillman
Supposing the universe rotates - and the galaxies rotate around its centre - and the solar systems rotate around the centre of galaxies - and the planets rotate around the centre of solar systems - is there some crazy math that could posit the Earth as the centre of it all?
No I am not a creationist - just thought it would be fun to try.
  • Haha
Likes davenn
First of all, you're posting in a thread that had its last activity in 2006!
Secondly, why even bother with such a thing since we already know that the Earth is NOT the center of the solar system, much less, the "center of it all"? Is there a reason to want to do this meaningless exercise?
Zz.
Just the math.
Can concentric circles end up with a point of the edge of the first circle as the centre?
  • Haha
Likes davenn
I apologize for digging up a 5 year old thread as my first post but looking into this subject is what lead me here. I have always believed that the galaxies may orbit some type of center and more so that the universe is rotating and possibly in orbit along with others around some larger body. I wasnt sure (although I assumed) that the question had been put forth by anyone else.
Also, Hello. Holland is actually my name. I am a 33 yo Texan, living in Nicaragua with enough free time on my hands to ponder the workings of the heavens. I look forward to reading the information provided in this forum.
FAQ: Can we tell whether the universe is rotating?
It is possible according to general relativity to have cosmologies in which the universe is rotating. This is a non-Machian feature of GR, since the rotation is not relative to anything else. There does not have to be a center of rotation, and such solutions can be homogeneous. One of the earliest cosmological solutions to the Einstein field equations to be discovered was the Gödel metric, which rotates and has closed timelike curves.
Solar-system observations[Clemence 1957] put a model-independent upper limit of 10^-7 radians/year on the rotation, which is an order of magnitude too lax to rule out the Gödel metric. Observations of the cosmic microwave background's anisotropy impose a limit that is tighter (perhaps 10^-9 rad/yr[Su 2009] or 10^-15 rad/yr[Barrow 1985]), but model-dependent.
Because all of the present observation are consistent with zero rotational velocity, it is not possible to attribute any prominent cosmological role to rotation. In particular, centrifugal forces cannot contribute significantly to cosmological expansion.
Clemence, C.M. (1957). 'Astronomical Time', Rev. Mod. Phys. Vol. 29, p. 2
Hawking, S.W. (1969). 'On the Rotation of the Universe', Mon. Not. R. astr. Soc. Vol. 142, p. 529.
Collins, C.B., and Hawking, S.W. (1973). 'The Rotation and Distortion of the Universe', Mon. Not. R. astr.Soc. Vol 162, p. 307.
Barrow, J. D., Juszkiewicz, R., & Sonoda, D. H., "Universal rotation: how large can it be?," 1985 -- http://adsabs.harvard.edu/full/1985MNRAS.213..917B
Su and Chu, "Is the universe rotating?," 2009, http://arxiv.org/abs/0902.4575
In order to imagine the universe or rather the space-time fabric of the universe as 'spinning'...if we increase dimensions to allow the spin to affect the universe in such a way as to produce three dimensional radial acceleration, are we still able to check for the effects of the spin?
I'm making the step from a three dimensional object spinning around a two dimensional axis giving rise to radial acceleration normal to the axis, to a four dimensional object spinning around a three dimensional axis giving rise to acceleration in all directions...I think.
Bryan.
Phaedridge, you have a personal message...!
The Earth IS the center of the universe, already. So is every other point in the universe.
The center is everywhere.
Can we rephrase the question this way "Does universe have a net angular momentum?" If so, what are its implications for cosmology?
In large scale surveys of galaxies, have the studied rotational axis and angular momentum of galaxies. Are these random, or is there a pattern.
If there is a preferred direction of rotation, how can that arise.
What does observation say
Within our own galaxy, what is the distribution of angular momentum of stars and planetary systems. Since most spiral galaxies are formed by mergers of smaller galaxies, would their angular momentum be useful in determining the origins of stars
There have been many articles this year that galaxies may have a preferred axis and direction of rotation, implying that our visible Universe has a non-zero net angular momentum. That's all I know. They should be easy to find.
Hi!
I'm not a phycisist, just interested in the subject. I've studied maths, but not very advanced ones. I just got interested in higgs boson, needless to say why, and watched a 50 mins video about it.
Among other things they talked about symmetry and how the universe seems to have evolved from more symmetric to less symmetric. They used a spinning top to ilustrate how easily symmetry can break down.
Then I asked myself, why not a spinning universe? spinning around what, I don't know, but there's another post in this thread explaining that there's no need of an axis nor a center and Gödel's solution is an example of an isotropic and homogeneous rotating universe (if I didn't misunderstand).
I'd like to advance another idea I've got about this:
Can it be that universe was originally spinning much faster than today? When a spinning top spins very fast, it seem much more simmetric than when it's spinning slowly. It's also much more energetic. On the other hand, when a figure skater wants to spin fast she tightens her arms. So, we could say that universe is 'stretching its arms' (expanding) cos it's spinning slower. The older the slower and so the older the bigger, following an exponential rule as the one that has been observed and has motivated the concept of dark energy. So, we might need no dark energy if we theorize a spinning universe.
Does it make any sense?
No.
There is no evidence at all that the universe is now or ever has been spinning. Quite the contrary, spinning assumes a center and the universe doesn't have a center.
phinds said:
[...]spinning assumes a center and the universe doesn't have a center.
This is incorrect. We now have a FAQ entry that addresses this misconception about a center of rotation: https://www.physicsforums.com/showthread.php?t=506988
No crazy math required. Earth IS the centre of our observable universe.
  • #31
To be more accurate, one could say that every observer is always at the center of their own observable universe.
  • #32
Precisely.
1. Is the universe spinning?
According to the theory of general relativity, the universe is not spinning in the traditional sense. The universe is expanding, but it is not rotating around a central axis like a spinning top. However, some scientists believe that the universe may have a slight rotation due to the leftover angular momentum from the Big Bang.
2. How do we determine if the universe is spinning?
Scientists use various methods to study the motion of galaxies and determine if the universe is spinning. One method is to measure the cosmic microwave background radiation, which can provide clues about the overall motion of the universe. Another method is to study the distribution of galaxies and their velocities, which can reveal any patterns or rotations.
3. What is the role of general relativity in understanding the universe's rotation?
General relativity is a theory that describes how gravity works in the universe. It explains how massive objects, such as planets and stars, affect the fabric of space-time. This theory is essential in understanding the overall structure and motion of the universe, including any potential rotation.
4. Can the universe's rotation affect our daily lives?
No, the universe's rotation does not have a direct impact on our daily lives. The universe's expansion and rotation occur on such a large scale that it does not affect the day-to-day activities on Earth. However, understanding the universe's rotation is crucial in understanding its overall behavior and evolution.
5. Is the universe's rotation constant?
There is no definitive answer to this question as scientists are still studying the universe's rotation. Some theories suggest that the universe's rotation may change over time, while others propose that it remains constant. Further research and observations are needed to determine the true nature of the universe's rotation.
  • Quantum Physics
  • Astronomy and Astrophysics
  • Quantum Physics
10K
