Construct a continuous function in metric space
In summary, Homework Equations requires a continuous function f : X \to [0,1] that is uniformly continuous on X, and also satisfies the following two conditions: 1) A \subseteq f^{-1}({0}) and B \subseteq f^{-1}({1}) and 2) there are disjoint sets U,V \subset X such that A \subset U and B \subset V.
complexnumber
62
Let [tex](X,d)[/tex] be a metric space, and let [tex]A,B \subset X[/tex] be disjoint closed subsets.
1. Construct a continuous function [tex]f : X \to [0,1][/tex] such that [tex]A \subseteq f^{-1}({0})[/tex] and [tex]B \subseteq f^{-1}({1})[/tex]. Hint: use the functions below.
2. Prove that there are disjoint sets [tex]U,V \subset X[/tex] such that [tex]A \subset U[/tex] and [tex]B \subset V[/tex].
[tex]f(x) := d(x,A) = \inf \{ d(x,y) | y \in A \}[/tex] is uniformly continuous on [tex]X[/tex].
1. I see that for points in [tex]A[/tex] the hint function will always return [tex]0[/tex]. So the preimage of [tex]\{ 0 \}[/tex] is set [tex]A[/tex]. But how can I make the maximum distance from any point to [tex]A[/tex] to [tex]1[/tex] and keep the function continuous? And also how should I make this function return [tex]1[/tex] for all points in [tex]B[/tex]?
2. I don't understand this (second) part of the question. Is this related to part one? Otherwise it seems obviously true.
Why don't you try to raise to powers?
[tex] a^0 =1 [/tex]
You know how to make the function return 0 for x in B don't you, and you know that x in B will return a finite value d(x,A).
some ideas, though they haven't been fully worked...
- first try drawing the hint function on a 1 d interval
- then consider the minimum distance between A & B, as they're closed & disjoint, can you say anything about it?
- how about adding a scale factor & max value to your function
for the 2nd part i think you can probably use your continuous function, how about considering the preimage under f on open sets... that said as you say you can probably do it otherwise with just properties of open & closed sets
Oh I was thinking
[tex] d(x,A)^{d(x,B)} [/tex]
Does this not work
nice function & that works in A & B, but what about outside them? might have to clip it to 1? (not that it effects the 2nd part of the question)
1. What is a metric space?
A metric space is a mathematical concept that describes a set of objects, where the distance between any two objects is well-defined and satisfies certain properties. This distance function is known as a metric, and it allows us to measure the distance between objects in the space.
2. What is a continuous function?
A continuous function is a mathematical function that does not have any abrupt jumps or breaks in its graph. This means that as the input values change, the output values change smoothly and without any sudden changes. In a metric space, a continuous function is one in which the distance between the function values is always smaller than a given positive number, no matter how small that number may be.
3. How do you construct a continuous function in a metric space?
To construct a continuous function in a metric space, you need to first define the metric and the set of objects in the space. Then, you need to specify the properties that the function should satisfy, such as continuity. From there, you can use various mathematical techniques, such as limits and sequences, to construct a function that meets these requirements.
4. Why is constructing a continuous function in a metric space important?
Constructing a continuous function in a metric space is important because it allows us to describe and analyze the behavior of objects in the space. Continuous functions are useful for modeling real-world phenomena and making predictions based on data. They also have a wide range of applications in fields such as physics, engineering, and economics.
5. What are some common examples of continuous functions in metric spaces?
Some common examples of continuous functions in metric spaces include polynomial functions, trigonometric functions, and exponential functions. These functions are commonly used to model various physical and mathematical phenomena, and their continuity allows for accurate predictions and analysis.
