New Reply
Angular speed in terms magnetic field
Share Thread Thread Tools
Aug5-12, 02:31 PM   #1
1. The problem statement, all variables and given/known data
3. A particle with magnetic dipole moment of magnitude μ (be careful—this is not a magnetic
permeability) and spin angular momentum of magnitude S is immersed in a magnetic field
of magnitude B. For simplicity, assume that the spin and magnetic-moment vectors (which
are either in the same or opposite directions) are perpendicular to the magnetic field. The
particle will precess, i.e., its spin angular momentum vector will rotate about the direction
of the magnetic field, with angular speed Ωp.
Find Ωp, in terms of the properties of the particle and the magnetic field. HINT: Remember
that Newton’s Second Law for rotation states that the torque equals the rate of change of
angular momentum.
2. Relevant equations
I did have to substitute in the variable notation given in the problem for the following equations.
Im not entirely sure what equations to use. But I've jotted down these.
angular momentum (S)= moment of inertia (I) x angular speed (Ωp)
precession angular velocity= T/L= ωr/Iω
Magnetic Field: B= mΩp/q
b]3. The attempt at a solution[/b]
B = mΩp/q
= m (S/I)/ q
I solve B for Ωp and Ωp= Bq/m
μ= q/2m S S is the angular momentum
solve μ for q then but that in Ωp equation
so I then got:
Ωp= B2μ/S
Does this make any sense?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
New Reply
Thread Tools
Similar Threads for: Angular speed in terms magnetic field
Thread Forum Replies
Angular speed of rotating coil in the Earth's magnetic field Introductory Physics Homework 0
angular momentum in electric field and magnetic field Classical Physics 5
Magnetic field outside a solenoid in 3D in terms of position General Physics 1
Angles made by angular momentum vector with magnetic field Introductory Physics Homework 2
