Individual contributions of molecular orbitals to the total density of states
In summary, the question is about the contribution of molecular orbitals to the total density of states in a two-probe system and how it is calculated. The response is that it can be calculated using the principal and magnetic quantum numbers, but the method may vary depending on the software used.
lepido
Hi,
I have a question regarding the contribution of some molecular orbitals (e.g HOMO, LUMO) to the total density of states of a two-probe system.
How exactly are the contributions of the MO ( that look similar to the DOS plots ) calculated, do they have something to do with the local density of states?
Is there a possibility to calculate the dos for a given eigenstate?
Thank you for any help,
Lepido
lepido said:
Hi,
Lepido
Yes you can. When you calculate the PDOS based upon the principal (n) and magnetic quantumnumbers (l and m_z). The procedure depends upon the software that you use though.
marlon
Hello Lepido,
Thank you for your question. The contributions of molecular orbitals (MOs) to the total density of states (DOS) can be calculated using various theoretical methods, such as density functional theory (DFT) or Hartree-Fock theory. These methods calculate the electronic structure and energy levels of a system based on the positions and interactions of the constituent atoms and their electrons.
The MOs themselves represent the distribution of electrons in space, and their contributions to the total DOS can be determined by analyzing the electron density within each orbital. This can be done using techniques such as Mulliken population analysis, which calculates the amount of electron density in each orbital, or Bader analysis, which divides the electron density into atomic basins and calculates the contribution from each atom.
The local density of states (LDOS) is related to the DOS, but it specifically refers to the electronic density at a particular point in space. The LDOS can be calculated for a given eigenstate by taking the square of the wavefunction for that state and multiplying it by the total DOS. This gives the LDOS at each point in space for that particular eigenstate.
I hope this helps answer your question. Best of luck with your research.
Best regards,
1. What is the concept of "Individual contributions of molecular orbitals to the total density of states"?
The concept of "Individual contributions of molecular orbitals to the total density of states" refers to the specific energy levels or orbitals of a molecule and how they contribute to the overall density of states, which is a measure of the number of available energy states within a certain energy range.
2. How do molecular orbitals contribute to the total density of states?
Molecular orbitals contribute to the total density of states by representing the energy levels of electrons within a molecule. Each molecular orbital has a specific energy level, and the sum of all these energy levels makes up the total density of states.
3. What is the significance of studying individual contributions of molecular orbitals to the total density of states?
Studying the individual contributions of molecular orbitals to the total density of states can provide valuable information about the electronic structure and properties of molecules. It can also help in understanding the behavior and reactivity of molecules in chemical reactions.
4. How can the individual contributions of molecular orbitals be calculated?
The individual contributions of molecular orbitals can be calculated using quantum mechanical methods such as density functional theory or Hartree-Fock theory. These methods use mathematical equations to describe the electronic structure of molecules and calculate the energy levels of individual molecular orbitals.
5. Are there any limitations to studying individual contributions of molecular orbitals to the total density of states?
Yes, there are some limitations to this approach. For complex molecules, it may be difficult to accurately determine the individual contributions of each molecular orbital. Additionally, the calculations can be computationally intensive and require specialized software and expertise.
  • Atomic and Condensed Matter
9K
  • Quantum Physics
  • Quantum Physics
