What would happen if two Earth size planets very slowly collided?
In summary, if a pseudo-Earth with similar mass and size suddenly appeared and followed the same orbit as Earth, but moved slightly faster, and eventually collided with Earth at a slow pace, the gravitational effects would be chaotic and intense. The two planets would pull each other towards themselves, causing a gradual increase in speed and decrease in orbit distance. This would result in an unforgettable sight as the planet approaches and passes the orbit of the moon. However, the exact effects would be difficult to predict due to factors such as initial distance between the planets, time until impact, and the influence of orbital acceleration and tidal effects.
blarznik
Hypothetically this pseudo-Earth suddenly appears and follows the same orbit as Earth, but moves slightly faster. If it eventually collides with Earth at snail pace what would the gravitational effects be like? (maybe ignore the moons)
Astronomy news on Phys.org
You mean like Earth #2 chasing Earth #1? well, it would be one hell of an unforgettable sight for a few weeks as the planet approaches. I assume E1 would slow down in it's orbit around the sun as E2 gains speed towards us. Can you imagine the sight as it passes the moons orbit? Scary but fascinating. I picture the planets from the movie Pitch Black, except we all die a feiry explosive death from a planet collision.
I believe the two planets would pull each other towards themselves and eventually both would be falling towards each other at 9.8 m/s^2 right before they hit.
That approximation fails magnificently when you start talking about entire earth-sized objects on a collision course :)
Well, since g = GMearth/Rearth, and the distance between the centres of the two planets would be 2Rearth right before they hit each other, one would think that the acceleration at that instant would be g/2, no?
This is assuming that the planets have not only the same mass, but also the same size.
EDIT: Nevermind. At this point they really can't be considered to act as point masses and you have to take into account tidal effects and all that...
I had this big chart with a bunch of the stats of gravitational acceleration for both planets at certain distances and velocity changes and all that jazz took a while to do on my computer calculator. But alas I had most of it on an Excel chart and blam crashola program not responding, I was on a roll and hadn't saved in a while... My initial obsessive motivation has mostly drained out of me for now. Might pick it up again tomorrow.
I did make a few mental notes though. Two big factors came into play: initial distance between Earth 1 and Earth 2, and time until impact. You have any idea what you want those to look like? Either one would do nicely I assume this is for a story. If not and it's just for your own curiosity I'll just throw something together saying they started like 630,729,000m apart moving at the same speed.
I think at point of impact it would be more like an acceleration of 39.2266 m/s2 because Earth 2 is accelerating at 19.6133 m/s2 due to its pull on Earth 1 (9.80665 m/s2) plus Earth 1's pull on it (9.80665 m/s2) and at the same time Earth 1 is decelerating at 19.6133 m/s2 due to the same factors. I could be wrong though.
But regardless the acceleration at point of impact isn't really what matters because you take into account the acceleration due to gravity across the vast distances of space between them and it continually builds up decelerating Earth 1 and accelerating Earth 2 until the impact and at that point it doesn't really matter how snail pace faster Earth 2 was moving or even if Earth 2 was moving slower initially. By the time they collide the impact due to their velocity differential would be quite something. This all of course depends on the initial distance between them.
I was mostly using the equation gh=go(re/(re+h))2 and the variations I derived from it would that equation be correct? Or would I have to double re because there are two Earths?
gh= Earth's gravitational acceleration on a object at a distance outside Earth's radius m/s2
go= Earth's standard gravitational acceleration of an object in m/s2 (usually 9.80665m/s2 but I used both 19.6133m/s2 and 39.2266m/s2 to get results due to 2 Earths being present)
re= Radius of Earth in meters
h= Distance in meters of object outside of Earth's radius
Oh and all my work is disregarding the whole orbital part I haven't really studied orbital acceleration and orbital factors very extensively yet. Also disregarding spin and the influence of the moons. That's just a bit much for me right now.
Yup it gets a bit crazy :D
Yep. I don't know the math to say anything else more correct though.
If you want it to hit the Earth, you don't want it appearing in the same orbit as the Earth.
Here's why. As it begins to approach the Earth from behind, the Earth's gravity starts to pull forward on it. But a forward force acting on a orbiting object pushes it into a higher orbit. higher orbits are slower orbits.
Meanwhile, the planet is pulling backward on the Earth, causing it to fall into a lower faster orbit
So what happens is that before the planet reaches the Earth it will be pushed into an orbit that is higher and slower and the Earth drifts into a lower faster one and will begin to pull away from the planet.
Fast forward up to the point where the faster Earth is catching up to the slower planet. Now the Earth pulls back on the planet and the Planet pulls forward on the Earth. The Earth drifts into the slower orbit and the planet into the faster one. The planet pulls away until it begins to catch up with the Earth again and we are back where we started.
This is called a "horseshoe" orbit, from the the fact that the path of one planet looks like a horseshoe from the perspective of the other.
Can you elaborate on this a bit? If one object is slowed down and pulled into a "faster" orbit, does that object take a full revolution to get to the required speed for that orbit? And why wouldn't an object that is sped up in it's orbit be lost? How does it slow down to get into the slower orbit?
I imagine not. As soon as it descends "deeper" into the sun's gravitational potential well, the potential energy it loses is turned into kinetic energy gained.
Same reason as above, only opposite. It expends energy climbing higher out of the sun's potential well.
So if it lost 100 m/s and fell towards the sun, then it gained that 100 m/s plus extra back? That makes sense. As does the opposite effect. Thanks!
What happens when Earth1 and Earth2 pass within each others' http://en.wikipedia.org/wiki/Roche_limit" ?
I don't know this stuff well so sure could be wrong, but my understanding is that the Roche limit has to do with loosely bound objects such as comets and would not apply to strongly bound objects such as a planet.
There would still be huge tidal stresses, massive earthquakes, and anything not nailed down (like oceans, atmosphere, people, soil...) would shift in a big way.
It reminds me of science-fiction stories (Rocheworld, heh) by Dr. Robert L. Forward of two planets which were so close that ocean and atmosphere would occasionally spill back and forth.
It would apply to any object that was massive enough that its own gravity determined its shape. (essentially anybody that has pulled itself into a sphere).
Since I don't know this stuff well, I have no trouble believing I have a misconception about this and maybe you can clear it up for me. Here's my confusion:
(1) It seems to me that a loosely cohesive grouping of rocks that had brought itself into more or less of a sphere would be torn apart far further out from a planet than would an object that was one solid rock (USED to be many rocks but has brought itself into a sphere then cooled off enough to no longer have a liquid core).
(2) The Roche limit is based on the mass of the planet and is independent of the approaching object.
If both of these were true then only one of the incoming objects could be torn apart specifically at the Roche limit, so I assume I'm wrong about one or the other, possibly both.
Thanks
The Roche limit for a rigid body would be less for that of a loose collection, yes. But since no object is perfectly rigid, the true limit will be somewhere between these two extremes. Even if an object no longer has a liquid core, its shape can be determined by gravity and it will flex somewhat under tidal forces.
The Roche limit is actually related to the ratio of the body's densities. Each body has a Roche limit in terms of the other. The less dense of two objects will start to break up when the objects are further apart then the denser object will. It is even possible, the ratio is large enough, for the Roche limit of one object to be inside the other.
Thanks
In pretty much every case, one object will be smaller or less dense than the other, and this object will be the one that breaks up.
For example, the Roche limit for the Moon with respect to the Earth is 9,496 km (rigid body limit) but for the Earth with respect to the Earth, it is only 1932 km. Since this is the center to center distance, and this is smaller than the Earth's radius, you wouls not see the Earth being torn apart by the Moon.
If however, both bodies were of the same mass and density, then the Roche limit would be the same for both.
Very clear. Thank you.
1. What would happen if two Earth size planets very slowly collided?
If two Earth size planets were to collide very slowly, the outcome would depend on various factors such as the speed and angle of collision, as well as the composition and density of the planets. In general, the collision would result in a massive impact that would cause both planets to break apart and form a new, larger planet. However, if the collision was slow enough, the planets may merge together and form a new, combined planet.
2. Would the collision result in the destruction of both planets?
The destruction of both planets would depend on the speed and angle of collision. If the collision was slow and gentle, the planets may merge together and form a new, larger planet. However, if the collision was fast and forceful, it is likely that both planets would break apart and form a debris field around the new planet.
3. What would happen to the atmosphere and surface of the planets during the collision?
The atmosphere and surface of the planets would be greatly affected by the collision. The impact would release a huge amount of energy, causing massive earthquakes, volcanic eruptions, and tsunamis. The atmosphere would also be disrupted, potentially leading to changes in climate and weather patterns.
4. Could life survive on the new, merged planet?
It is difficult to say whether life could survive on the new, merged planet. The impact and resulting changes to the atmosphere and surface could make it inhospitable for life as we know it. However, it is possible that some forms of life may adapt and survive in this new environment.
5. How would the collision of two Earth size planets impact the rest of the solar system?
The collision of two Earth size planets would have a significant impact on the rest of the solar system. The gravitational pull of the new, larger planet could affect the orbits of other planets and objects in the solar system. There may also be an increase in asteroid and comet activity due to the disturbance caused by the collision.
  • Astronomy and Astrophysics
