Why doesn't direct current exhibit self-induction?
In summary, the strength of a magnetic field is directly proportional to the current flowing through a wire, and therefore, the magnetic field can change or move when there is a change in current. In direct current, the average speed of the electrons remains constant, resulting in a constant magnetic field. However, when the current increases, the average speed of the electrons also increases, leading to a stronger magnetic field. This change in the magnetic field is known as self-induction.
scientist91
133
Ok, I reformed my question, and I will be very happy if you answer me. I know that the electrons have magnetic field. So if the electrons are moving through a conductor (in direct current) than logically the magnetic field will move also. So there will be also self-induction. Can you give me good, deep and simple explanation for my question. Thank you.
then logically the magnetic field will move also
No, bad logic. Magnetic fields come from moving charges or changing electric fields. You can get a 'good, deep' explanation by studying Maxwell's equations. Or perhaps someone with a lot of time and patience will explain here.
Moving charges create magnetic fields. Moving charges do not necessarily create moving magnetic fields. If all of the electrons in the conductor are moving at (on average) a constant speed, then the magnetic field is constant. It doesn't move.
Think about this. For every electron that moves forward, another electron behind it moves up to take its place. So the magnetic field never goes away.
Does that help?
When you switch on a current, a magnetic field appears.
Therefore, any circuit has a (self-)inductance. (see the definition)
Self-inductance is not a property of a current (in first approximation), but it is a property of a circuit.
However, for very high-frequencies, the current cannot flow anymore in the core of the conductors, and instead it flows in "the skin" of the conductors. This is called "the skin effect". The thickness of the skin depends on the frequency of the current. When the skin effect appears, the inductance of a circuit will also depend on the frequency of the current flowing trhough the conductor. In this case, the self-inductance becomes really a property of the system {circuit+current flowing through it}. This also shows you that inductances are essentially related to circuits. When the current densities within the wires have to be taken into account, or when there is no real wire but only bulk current (eddy current, currents in a tokamak plasma, current within the sun, ...) the concept of inductance becomes less clear and the full Maxwell's equations are needed to give a complete description of such a system. The Lenz law is still valid and described quantitatively by the Maxwell's equations.
Now, in steady-state conditions (constant current, "DC") the self-inductance of a circuit has no effect on anything. The electromotive forces depend on the inductances and only on the time-derivative of the currents (and not on the currents themselves). Therefore when the currents are constant there are no electromotive forces, no "induction". But this does not mean there is no inductance ...
Remember the Lenz law:
(Electromotive force in a loop) = - d(PHI)/dt
where PHI is the flux of the magnetic field through this loop.
When the magnetic field is constant, the flux is constant and therefore the electromagnetic force is zero: no "induction".
Does that help?
Ok, thank you very much for the effort that you put into help me. This which Xezlec said helped me a lot to understand the real thing. I think the speed doesn't matter. In the direct current, the electrons can also have different speed. I think that the strong of the magnetic field depends from the speed.
Explain please, how do the magnetic field is moving (does it change or move?) when the speed of the current is different. Thank you.
From Ampere's law we can show that magnetic field of a long straight wire is directly proportional to the current flowing through the wire. In other words, the greater the current, the greater [stronger] the resultant magnetic field.
And when the magnetic field is changing?
Provided the current is constant, the magnetic field is stationary.
First of all, when the magnetic field changes, it usually moves. And when it moves, it usually changes. So I use "change" and "move" to mean the same thing. "Change" is probably a better word.
When the current is greater, the field is also greater. The faster an electron moves, the stronger the magnetic field it creates.
In direct current, the average speed of all the electrons in the wire doesn't change in time. So, the magnetic field is constant (because it is the combination of the magnetic fields due to all the electrons).
If you increase the current, then you increase the average speed of the electrons, so the magnetic field gets stronger. A magnetic field getting stronger is a change. During that change, while you are increasing the current, self-induction happens.
So let's realize, the magnetic field is not attached on the electron so the magnetic field is not moving with the electron, it stays in one position. All electrons make one magnetic field, and it is created when there is current inside the conductor (electric field) and it is changing (moving) when there is different speed of the electrons.
Sounds about right to me :approve:
And on all things that can be magnetized, are the magnetic fields are created around the electrons?
Wouldn't the magnetic field components be simply following the flow of individual eletrons? It would only be the sum of these components that wouldn't be flowing.
As an analogy, imagine a process where energy was converted into electrons at one end of a evacuated tube, that the electrons traveled to the other end of a tube where they were converted back into energy. You'd have both tiny magnetic and gravitation fields moving along with the electrons. Only when the density of this stream of electrons got sufficiently high enough would these tiny fields sum up to appear as a single continuous non-moving field.
1. Why does direct current not have self-induction?
The main reason why direct current does not have self-induction is because it is a constant and unchanging flow of electrical charge. Unlike alternating current, which constantly changes direction, direct current does not create a changing magnetic field that would induce a voltage in the same conductor.
2. Is self-induction completely absent in direct current?
No, self-induction can still occur in direct current circuits, but it is significantly less compared to alternating current. This is because direct current can still create a magnetic field, but it remains constant and does not induce a voltage in the same conductor.
3. How does the absence of self-induction affect direct current circuits?
The absence of self-induction in direct current circuits means that the circuit will not experience a change in voltage or current due to the presence of inductance. This allows for more efficient transmission of electricity and less energy loss.
4. Can direct current circuits still use inductors?
Yes, direct current circuits can still use inductors, but their purpose is different. In AC circuits, inductors are used to block or reduce the flow of current. In DC circuits, inductors are used to store energy in the form of a magnetic field, which can be released when the current is interrupted.
5. How does direct current compare to alternating current in terms of self-induction?
Direct current is often preferred over alternating current in terms of self-induction because it does not experience voltage drops due to inductance. This makes it more efficient for long-distance transmission and is one of the reasons why direct current is used in high-voltage power lines.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
