| New Reply |
Differential equation resembling to cycloid |
Share Thread | Thread Tools |
| Nov15-12, 10:58 AM | #1 |
What is the function corresponding to this ODE:
![]() In complex notation it obviously shows up like this: a * z''(t) + b * |z'(t)| * z'(t) + c = 0; The numerical solution shows a graph resembling to a cycloid. Thanks for any help! Tom |
| Nov15-12, 09:30 PM | #2 |
Recognitions:
If you divide through by the surd and subtract the 1st eqn from the second, I believe you get something integrable. |
| Nov16-12, 06:30 AM | #3 |
Thank you for your comment. I tried to devide and subtract. The problem is the term in the middle: (y' - eps*x') vs. (x' + eps*y')
It makes the situation even worse - I did not succeed in finding a simplified pattern. The complex notation in my first post has been derived by simply multiplying the 2nd equation by i and adding the result to the first equation. What I investigated in the meanwhile: The cycloid ODE in complex notation should be a * z''(t) + b * z'(t) + c = 0; The only difference is the multiplication with |z'| in the middle which in fact produces a value near 1 for curtate cycloids with r1 << r0 (the point tracing out the curve is inside the circle, which rolls on a line AND it is close to the center). The ODEs in my first posts describe a phugoid, a more general form of the cycloid I suppose. It seems that the phugoid has no analytic solution. Any suggestions? Tom |
| Nov16-12, 02:07 PM | #4 |
Recognitions:
Sorry, I overlooked what happens to the RHS. My original suggestion was nonsense.
| New Reply |
| Thread Tools | |
Similar Threads for: Differential equation resembling to cycloid
| Thread | Forum | Replies | ||
| Use the differential operator to solve this differential equation | Calculus & Beyond Homework | 1 | ||
| Simple Sturm-Liouville system resembling Associated-Legendre equation? | Differential Equations | 5 | ||
| Simple Differential Equation (Ordinary Differential Equation) | Differential Equations | 7 | ||
| Electric current density in conductors not resembling a wire | General Physics | 4 | ||
| Parametric equation of a Curtate cycloid | Introductory Physics Homework | 2 | ||
