Someone502
- 40
i had a beach ball and i deflated it as much as i could. theni tried to open it after i closed the opening. i couldnt. why and what would happen if i pulled on it from lots of sides?
thanks
thanks
Deflating a beach ball will cause it to decrease in size and lose its round shape. As the air is released from the beach ball, the elastic material will collapse on itself, resulting in a flatter and more compressed shape.
The air inside the beach ball will be released through the valve as it is deflated. This is because the air pressure inside the beach ball is higher than the outside air pressure, causing the air to flow out of the ball until the pressures equalize.
The beach ball becomes more difficult to deflate as it nears full deflation because the air inside is under less pressure. This means that there is less force pushing the air out of the valve, making it harder to remove the remaining air.
Yes, a beach ball can be fully deflated by removing all of the air from inside. However, the beach ball may still retain some of its shape and size due to the material it is made of.
Deflating a beach ball can serve multiple purposes, such as making it easier to store or transport, reducing the risk of it rolling away or blowing away in windy conditions, or simply for the fun and satisfaction of watching it deflate.
