Calculating Percentage Change in Tension for Tuning a Guitar String
In summary, the G string of a guitar which should be 392 Hz is playing flat at 380 Hz. To tune the string to 392 Hz, a 6.42% change in the tension of the wire is required. This can be calculated algebraically by using the wave velocity equation and the relationship between tension and linear mass density. The percentage change in tension is equivalent to the percentage difference between the two tensions.
warmfire540
53
The G string of a guitar which should be 392 Hz is playing flat at 380 Hz. What percentage change in the tension of the wire is required so as to tune the string to 392 Hz?
I just need to help getting started on this one, I don't know how to relate tension to frequency without knowing lamda
The velocity of the waves on the string will be the product of the frequency and wavelength. Changing the tension in the string alters the velocity of the waves, but since the fundamental tone of the string is produced by a standing wave, that wavelength is constant. So you will not need to know it (or the length of the string itself).
Okay, well where would I derive a formula to find the tension, or therefore the change of tension in this case?
You don't have to know lambda in order to manipulate it algebraically.
How come? I don't get why we don't need lambda? What other equation is there? How do you do it "algebraically?"
:cry:
You have the wave relation
v = f · lam.
For the untuned string, then, you have
v_1 = f_1 · lam_1
and, for the properly tuned string,
v_2 = f_2 · lam_2 .
But the length of the G string doesn't change, so neither does the fundamental standing wavelength at which it vibrates. So we have
lam_1 = lam_2 = lam .
If we now compare the wave velocities, we get
v_2/v_1 = (f_2 · lam)/(f_1 · lam) = f_2/f_1 .
So we don't need to know the length of the string or the fundamental standing wavelength.
You know the relationship between wave velocity, string tension, and string linear mass density, so you can work out the ratio of the tuned versus untuned string tension. (BTW, you don't need to know the linear mass density of the string either: that also will cancel out.)
From the ratio of the tensions, you can find the fractional tension change, and from that, the percentage of tension change in the string.
Okay
Well from here i see that f2/f1 = 392/380 = 1.0316
So the tuned string's tension is 1.0316 times more than the untuned strings tension.
This is also seen as a 96.94%, or a 3.06% in tension.
It is true that f2/f1 = v2/v1. But isn't the wave velocity equal to sqrt( T / mu ) ?
Yeah..so we sub v for the sqrt( T / mu )
so f2/f1= sqrt( T2 / mu )/sqrt( T1 / mu )
1.0316=sqrt( T2 / mu )/sqrt( T1 / mu )
1.0642=(T2/mu) / (T1/mu)
1.0642=T2/T1
So T1*1.0642 = T2
This is a 93.98% difference between strings, where as the difference in percent is 6.02%
That is close, but be careful about the definition. The question asks for the percentage change in the tension of the wire. This will be
(delta_T / T) x 100% = [ (T2 - T1) / T1 ] x 100% .
The fractional change is equivalent to
(T2 - T1)/T1 = (T2/T1) - (T1/T1) = (T2/T1) - 1 = 1.0642 - 1 = 0.0642 .
So your percentage change should be 6.42% . (Or is 6.02% just a typo?)
Ah i See! thank you soo much!
What is tension and frequency?
Tension refers to the force applied to an object, while frequency is the number of times an event occurs within a specific time period.
How are tension and frequency related?
Tension and frequency are directly proportional, meaning that as tension increases, frequency also increases. This relationship is known as Hooke's law.
What are some real-life examples of tension and frequency?
One example is a guitar string. The tighter the string (higher tension), the higher the frequency of the sound produced when plucked. Another example is a swing, where the greater the force applied (higher tension), the faster the swing moves (higher frequency).
How do tension and frequency affect waves?
In waves, tension and frequency determine the speed of the wave. Higher tension and frequency result in faster waves, while lower tension and frequency result in slower waves.
How can tension and frequency be measured?
Tension can be measured using a force gauge or a spring scale, while frequency can be measured using a frequency meter or by counting the number of cycles within a specific time period using a stopwatch.
  • Art, Music, History, and Linguistics
