Two Body problem with RK4 in C++
In summary: RK4_func".Also, on the line that begins with "mass1=mass1*10^20", the "^" is not the power operator. I think you want the "pow(a, b)" function. Or you could just multiply by 1e20.In summary, the conversation outlines the steps needed to output an excel file with the results of the trajectories of a two body problem, with initial position and velocity. The program is not compiling and there is a suggestion to check the function RK4_func, which includes a list of variables that may need to have actual parameter names. Additionally,
atsquishy
I want to output an excel file with the results of the trajectories of a two body problem, with initial position and velocity. But my program is not compiling. Any suggestions/problems that you can see?
Code:
#include <iostream>
#include <vector>
#include <fstream>
using namespace std;
void RK4_func(double,double,double,double,double,double,double,double,double,double,double,double);
int main(){
//initialise variables
	double time_end,time_step,mass1,x1x,y1y,v1x,v1y,mass2,x2x,y2y,v2x,v2y;
//Get the value
	cout << "Enter Simulation Duration in seconds" << endl;
	cin >> time_step;
	cout << "\n";
	cout << "Enter Precision (Time step)" << endl;
	cin >> time_end;
	cout << "\n";
	cout << "Enter mass of body 1 with 10^20kg scale" << endl;
	cin >> mass1;
	cout << "\n";
	cout << "Enter initial body 1 x position" << endl;
	cin >> x1x;
	cout << "\n";
	cout << "Enter initial body 1 y position" << endl;
	cin >> y1y;
	cout << "\n";
	cout << "Enter initial body 1 x velocity" << endl;
	cin >> v1x;
	cout << "\n";
	cin >> v1y;
	cout << "\n";
	cout << "Enter mass of body 2 with 10^20kg scale" << endl;
	cin >> mass2;
	cout << "\n";
	cout << "Enter initial body 2 x position" << endl;
	cin >> x2x;
	cout << "\n";
	cout << "Enter initial body 2 y position" << endl;
	cin >> y2y;
	cout << "\n";
	cout << "Enter initial body 2 x velocity" << endl;
	cin >> v2x;
	cout << "\n";
	cout << "Enter initial body 2 y velocity" << endl;
	cin >> v2y;
	cout << "\n";
//Pass values int RK4_func
mass1=mass1*10^20
mass2=mass2*10^20
RK4_func(time_end,time_step;mass1;x1x,y1y,v1x,v1y,mass2,x2x,y2y,v2x,v2y);
//Output data
	return 0;
//Assume function  enters data in SI units
void RK4_func (double timeend, double steps, double m1, double x1, double y1, double vx1, double vy1, double m2, double x2, double y2, double vx2,double vy2)
//Excel file creation
	ofstream outfile1 ("RK4.xls");
outfile1<<"time"<<'\t'<<"x1"<<'\t'<<"y1"<<'\t'<<"vx1"<<'\t'<<"vy1"<<'\t'<<"x2"<<'\t'<<"y2"<<'\t'<<"vx2"<<'\t'<<"vy2"<<endl;
outfile1<<0<<'\t'<<x1<<'\t'<<y1<<'\t'<<vx1<<'\t'<<vy1<<'\t'<<x2<<'\t'<<y2<<'\t'<<vx2<<'\t'<<vy2<<endl;
	constant double G = 6.67E-11;
	double datalength = 1+(timeend/steps);
	double data [8][datalength];
	double t=0;
	data[0][0]=x1;
	data[1][0]=y1;
	data[2][0]=x2;
	data[3][0]=y2;
	data[4][0]=vx1;
	data[5][0]=vy1;
	data[6][0]=vx2;
	data[7][0]=vy2;
	for (int i=0; i<datalength; i++)
		vector<double> interdata(12), k1 (8), k2 (8), k3 (8), k4 (8);
		// let 0~3 indicate position x1y1x2y2 4~7 indicate vx1vy1vx2vy2 8~11 indicate ax1ay1ax2ay2
		//acceleration x1 y1 x2 y2
		interdata[0]=data[0][i];
		interdata[1]=data[1][i];
		interdata[2]=data[2][i];
		interdata[3]=data[3][i];
		interdata[4]=data[4][i];
		interdata[5]=data[5][i];
		interdata[6]=data[6][i];
		interdata[7]=data[7][i];
		interdata[8] = G*m2*/(((((data[0][i]-data[2][i])^2)+((data[1][i]-data[3][i])^2))^(1/2))^3)*(data[2][i]-data[0][i]);
		interdata[9] = G*m2*/(((((data[0][i]-data[2][i])^2)+((data[1][i]-data[3][i])^2))^(1/2))^3)*(data[3][i]-data[1][i]);
		interdata[10] = G*m1*/(((((data[0][i]-data[2][i])^2)+((data[1][i]-data[3][i])^2))^(1/2))^3)*(data[0][i]-data[2][i]);
		interdata[11] = G*m1*/(((((data[0][i]-data[2][i])^2)+((data[1][i]-data[3][i])^2))^(1/2))^3)*(data[1][i]-data[3][i]);
		//k1 is Euler Step
		k1[0] = steps*interdata[8];
		k1[1] = steps*interdata[9];
		k1[2] = steps*interdata[10];
		k1[3] = steps*interdata[11];
		k1[4] = steps*interdata[4];
		k1[5] = steps*interdata[5];
		k1[6] = steps*interdata[6];
		k1[7] = steps*interdata[7];
		interdata[0] = interdata[0]+0.5*k1[4];
		interdata[1] = interdata[1]+0.5*k1[5];
		interdata[2] = interdata[2]+0.5*k1[6];
		interdata[3] = interdata[3]+0.5*k1[7];
		interdata[4] = interdata[4]+0.5*k1[0];
		interdata[5] = interdata[5]+0.5*k1[1];
		interdata[6] = interdata[6]+0.5*k1[2];
		interdata[7] = interdata[7]+0.5*k1[3];
		interdata[8] = G*m2*/(((((interdata[0]-interdata[2])^2)+((interdata[1]-interdata[3])^2))^(1/2))^3)*(interdata[2]-interdata[0]);
		interdata[9] = G*m2*/(((((interdata[0]-interdata[2])^2)+((interdata[1]-interdata[3])^2))^(1/2))^3)*(interdata[3]-interdata[1]);
		interdata[10] = G*m1*/(((((interdata[0]-interdata[2])^2)+((interdata[1]-interdata[3])^2))^(1/2))^3)*(interdata[0]-interdata[2]);
		interdata[11] = G*m1*/(((((interdata[0]-interdata[2])^2)+((interdata[1]-interdata[3])^2))^(1/2))^3)*(interdata[1]-interdata[3]);
		//k2
		k2[0] = steps*interdata[8];
		k2[1] = steps*interdata[9];
		k2[2] = steps*interdata[10];
		k2[3] = steps*interdata[11];
		k2[4] = steps*interdata[4];
		k2[5] = steps*interdata[5];
		k2[6] = steps*interdata[6];
		k2[7] = steps*interdata[7];
		interdata[0] = interdata[0]+0.5*k2[4];
		interdata[1] = interdata[1]+0.5*k2[5];
		interdata[2] = interdata[2]+0.5*k2[6];
		interdata[3] = interdata[3]+0.5*k2[7];
		interdata[4] = interdata[4]+0.5*k2[0];
		interdata[5] = interdata[5]+0.5*k2[1];
		interdata[6] = interdata[6]+0.5*k2[2];
		interdata[7] = interdata[7]+0.5*k2[3];
		//k3
		k3[0] = steps*interdata[8];
		k3[1] = steps*interdata[9];
		k3[2] = steps*interdata[10];
		k3[3] = steps*interdata[11];
		k3[4] = steps*interdata[4];
		k3[5] = steps*interdata[5];
		k3[6] = steps*interdata[6];
		k3[7] = steps*interdata[7];
		interdata[0] = interdata[0]+k3[4];
		interdata[1] = interdata[1]+k3[5];
		interdata[2] = interdata[2]+k3[6];
		interdata[3] = interdata[3]+k3[7];
		interdata[4] = interdata[4]+k3[0];
		interdata[5] = interdata[5]+k3[1];
		interdata[6] = interdata[6]+k3[2];
		interdata[7] = interdata[7]+k3[3];
		//k4
		k4[0] = steps*interdata[8];
		k4[1] = steps*interdata[9];
		k4[2] = steps*interdata[10];
		k4[3] = steps*interdata[11];
		k4[4] = steps*interdata[4];
		k4[5] = steps*interdata[5];
		k4[6] = steps*interdata[6];
		k4[7] = steps*interdata[7];
		data[0][i+1] = data[0][i]+(1.0/6.0)*(k1[0]+2*k2[0]+2*k3[0]+k4[0]);
		data[1][i+1] = data[1][i]+(1.0/6.0)*(k1[1]+2*k2[1]+2*k3[1]+k4[1]);
		data[2][i+1] = data[2][i]+(1.0/6.0)*(k1[2]+2*k2[2]+2*k3[2]+k4[2]);
		data[3][i+1] = data[3][i]+(1.0/6.0)*(k1[3]+2*k2[3]+2*k3[3]+k4[3]);
		data[4][i+1] = data[4][i]+(1.0/6.0)*(k1[4]+2*k2[4]+2*k3[4]+k4[4]);
		data[5][i+1] = data[5][i]+(1.0/6.0)*(k1[5]+2*k2[5]+2*k3[5]+k4[5]);
		data[6][i+1] = data[6][i]+(1.0/6.0)*(k1[6]+2*k2[6]+2*k3[6]+k4[6]);
		data[7][i+1] = data[7][i]+(1.0/6.0)*(k1[7]+2*k2[7]+2*k3[7]+k4[7]);
	//output new values
for (int i=0; i<datalength; i++){
outfile1<<i*steps<<'\t'<<data[0][i]<<'\t'<<data[1][i]<<'\t'<<data[4][i]<<'\t'<<data[5][i]<<'\t'<<data[2][i]<<'\t'<<data[3][i]<<'\t'<<data[6][i]<<'\t'<<data[7][i]<<endl;
    outfile1.close();
Technology news on Phys.org
I'm no C++ expert, but I think there's something funny when void RK4_func has a variable list which consists of 'double,double,double, double, etc.)
Shouldn't there be some actual parameter names in there somewhere?
Forward declarations don't need them. The actual function is much farther down.
OP, aren't you getting errors in your compiler? What do they say? You should be, because I'm getting a ton.
Don't you think it would help if you tell us the error messages that the compiler is giving you? :confused:
You have lots of typos and some more principal problems.
Always start from the top of your compiler error output. Correct simple typos (commas, semicolons, etc.)
Exponentiation is different in c++, you need to import pow() function or overload ^ as such beforehand.
Sorry sorry, yes I've made some fundamental problems. Not very used to C++, I'm rewriting it now and I'll post up the new code. I'll also be deleting the forward declaration, and making it easier to read.
People often put variable names in function declarations, but strictly speaking it's better not to.
Think what could happen if a "variable name" was redefined in a header file that you included, for example. At best you would get a very confusing error message. At worst, the code would be valid, but not what you thought you had written.
I redid it, but I still get this error.
TwoBodies.cpp: In function ‘void RK4_func(double, double, double, double, double, double, double, double, double, double, double, double)’:
TwoBodies.cpp:87: error: size of array ‘data’ has non-integral type ‘double’
line 87 is double data [8][datalength];
The code is
Code:
#include <iostream>
#include <vector>
#include <fstream>
#include <math.h>
void RK4_func (double, double, double, double, double, double, double, double, double, double, double, double);
int main(){
	double time_end,time_step,mass1,x1,y1,vx1,vy1,mass2,x2,y2,vx2,vy2;
	//Get the value into variables
	cin >> time_end;
	cout << "\n";
	cout << "Enter Precision (Time step. Recommended 100 to 300 seconds )" << endl;
	cin >> time_step;
	cout << "\n";
	cin >> mass1;
	cout << "\n";
	cin >> x1;
	cout << "\n";
	cin >> y1;
	cout << "\n";
	cin >> vx1;
	cout << "\n";
	cin >> vy1;
	cout << "\n";
	cin >> mass2;
	cout << "\n";
	cin >> x2;
	cout << "\n";
	cin >> y2;
	cout << "\n";
	cin >> vx2;
	cout << "\n";
	cin >> vy2;
	cout << "\n";	//Pass values into RK4_func and Output data via Excel File
	RK4_func(time_end,time_step,mass1,x1,y1,vx1,vy1,mass2,x2,y2,vx2,vy2);
	return 0;
	//Declare constants and array
	const double G = 6.67*pow(10,-11);
	double data[8][datalength];
	data[0][0]=x1;
	data[1][0]=y1;
	data[2][0]=x2;
	data[3][0]=y2;
	data[4][0]=vx1;
	data[5][0]=vy1;
	data[6][0]=vx2;
	data[7][0]=vy2;
		interdata[8] = G*m2/pow(pow((pow((data[0][i]-data[2][i]),2)+pow((data[1][i]-data[3][i]),2)),(1/2)),3)*(data[2][i]-data[0][i]);
		interdata[9] = G*m2/pow(pow((pow((data[0][i]-data[2][i]),2)+pow((data[1][i]-data[3][i]),2)),(1/2)),3)*(data[3][i]-data[1][i]);
		interdata[10] = G*m1/pow(pow((pow((data[0][i]-data[2][i]),2)+pow((data[1][i]-data[3][i]),2)),(1/2)),3)*(data[0][i]-data[2][i]);
		interdata[11] = G*m1/pow(pow((pow((data[0][i]-data[2][i]),2)+pow((data[1][i]-data[3][i]),2)),(1/2)),3)*(data[1][i]-data[3][i]);
		//k1 is Euler Step
		interdata[8] = G*m2/pow(pow((pow((interdata[0]-interdata[2]),2)+pow((interdata[1]-interdata[3]),2)),(1/2)),3)*(interdata[2]-interdata[0]);
		interdata[9] = G*m2/pow(pow((pow((interdata[0]-interdata[2]),2)+pow((interdata[1]-interdata[3]),2)),(1/2)),3)*(interdata[3]-interdata[1]);
		interdata[10] = G*m1/pow(pow((pow((interdata[0]-interdata[2]),2)+pow((interdata[1]-interdata[3]),2)),(1/2)),3)*(interdata[0]-interdata[2]);
		interdata[11] = G*m1/pow(pow((pow((interdata[0]-interdata[2]),2)+pow((interdata[1]-interdata[3]),2)),(1/2)),3)*(interdata[1]-interdata[3]);
		//k2
		//k3
		//k4
		//Form the next position and velocity
	//output new values
	outfile1.close();
// Display via GnuPlot
You must used a fixed point type as an index into an array, you can't use a floating point value. Likewise you must have a fixed point count of objects (same thing). You can't have 3.2 elements in the array...
so how do i specify that? do i use long int or int?
EDIT: Yes. I switched the data into unsigned long int, then it compiled! but now the RK4 seems off since it doesn't give me a result.
You have no experience in programming? It sounds like you don't even know where to begin when it comes to debugging.
Sorry, I don't really have that much experience. It's my first course, and it's only been a few months since I started learning C++/programming. But it's compiling now. I just think the RK4 is off now, because it gives me the excel file, but the numbers are ridiculous. Is there something that I did wrong with my RK4? I mean, I'm sure there must be, but I don't see it.
The RK4 function is here:
Code:
	unsigned long int datalength = 1+(timeend/steps);
	data[0][0]=x1;
	data[1][0]=y1;
	data[2][0]=x2;
	data[3][0]=y2;
	data[4][0]=vx1;
	data[5][0]=vy1;
	data[6][0]=vx2;
	data[7][0]=vy2;
		//k1 is Euler Step
		//k2
		//k3
		//k4
	//output new values
	outfile1.close();
Being confused is normal. Knowing how to dissect the problems are the key.
To be honest, I don't understand your code. k1[0] to k1[3] should give the derivative of coordinates (velocity) times the stepsize, but you have second derivative instead (the acceleration).
Same goes for k1[4] to k[7]. Shouldn't they have stepsize times the acceleration instead?
Of course then you seem to flip it back to correct places in interdata, but the final calculation uses k vectors where the problem remains.
Maybe it's possible to correct the problem by only changing the coefficient vector numbering in
data[0][i+1] = data[0] + ...
etc
If all else fails try doing only Euler step method at first ( comment the rest out). Then there's less to think about.
1. What is the Two Body problem in physics?
The Two Body problem is a classic problem in physics where two point masses interact with each other solely through the force of gravity. It is used to describe the motion of two objects, such as planets or stars, in space.
2. What is RK4 in C++?
RK4, or the Runge-Kutta method, is a numerical method used to solve differential equations, including those that describe the motion of objects in space. It is a popular choice for solving the Two Body problem due to its accuracy and efficiency.
3. How does RK4 work in solving the Two Body problem?
RK4 works by approximating the solution of a differential equation at a given point through a series of smaller steps. In the case of the Two Body problem, RK4 calculates the position and velocity of each object at each time step, taking into account the gravitational force between them.
4. What is the advantage of using RK4 in C++ for the Two Body problem?
The advantage of using RK4 in C++ for the Two Body problem is that it allows for a more accurate and efficient solution compared to other methods. This is especially useful when dealing with complex systems or when high precision is required.
5. How can I implement RK4 in C++ for the Two Body problem?
To implement RK4 in C++ for the Two Body problem, you will need to define the initial conditions, such as the masses and positions of the objects, and set up the differential equations that describe their motion. Then, using a loop, you can calculate the position and velocity of each object at each time step using the RK4 method. The final result will be a set of coordinates that describe the motion of the objects over time.
