Cold shutdown that doesn't require coolant circulation?
In summary, coolant circulation is necessary for removing decay heat from a reactor after it has been shut down. This is typically done through a residual heat removal (RHR) system or an emergency core cooling system (ECCS). However, there are designs, such as the Isolation Condenser (IC), that require no active systems and can passively cool the reactor for extended periods of time. The AP1000 westinghouse design uses natural forces for circulation and can maintain cooling for 72 hours with no human interaction or electrical power. Gen 4 designs are even more passive and can go for extended periods of time with no active systems. However, some plants have replaced the IC with the RCIC system, which is a pump driven by
  • #71
Hiddencamper said:
It is an (n,p) reaction:
O16 + n -> N16 + p
The oxygen is from the water in the reactor vessel.
Ah of course, I should have seen that.
Continuing, the fuel itself is an oxide. I would think that would create problems, rapidly braking the oxide bonds of the fuel in the conversion of O to N.
  • #72
The fuel pellet is pretty much lost the moment you do your first heatup on the fuel. It's known to expand, crack, and under some very nasty transients or against heat limits, shatter/vaporize. Over time, due to changes in the composition of the fuel pellet itself, and changes in the cladding, your thermal limits become more limiting and your heat transfer rates get reduced. These are all accounted for in both core design and core modelling, and are validated in real time against actual plant data.
  • #73
mheslep said:
Just curious: that's due only to the tritium atoms in the water? Not another source?
There is little tritium in BWRs, since they have almost no deuterium, and produce tritium by other means than D+n->T. Tritium production is only significant in heavy water reactors.
Hiddencamper said:
While the fuel in BWRs (and PWRs) is solid, all solid material has some miniscule amounts of diffusion.
Not only that. A large BWR contains on the order of 50 thousands of individual fuel rods. With such a large number of rods, it's impractical to ensure that absolutely all of them stay watertight. Thus, BWRs are not stopped when tests indicate that just one single rod ruptured and water is now in touch with its fuel ceramic pellets, washing out some fission products.
  • #74
Reactor water chemistry is regularly sampled for the difference between diffusion, and actual leakage/seepage/cracking of the fuel. Once ratios of specific elements like iodine and xenon are seen to go outside of normal, in a BWR you can perform suppression testing. What we've found is if you push control rods in near the suspected leakers, you will see a decrease in radioactive inventory in the reactor coolant system. If you then push in 1 or 2 face adjacent controls rods and possibly a diagonal rod it will greatly suppress the amount of leakage from the leaky bundle, almost returning it to 'normal' levels for the reactor. You can then continue operating the unit, albeit with lost effective full power days.
In a PWR, a fuel leak almost always requires the fuel be removed and replaced. PWRs cannot run with a rod full into suppress it the way a BWR can.
  • #75
O16 + n -> N16 + p
BTW, what happens to the continuously generated hydrogen, the H2 left behind (and the p when it neutralizes)?
  • #76
In a BWR, non-condensible gases end up in the condenser vacuum system, recombiners to recombine most O2 and H2 back to water, then to the off-gas system to be delayed and filtered, and eventually to the atmosphere through the stack.
Hydrogen has a nasty habit of moving with steam in the primary piping and accumulating in places where steam condenses (e.g. inside certain valves), causing fragility issues with certain steel materials.
  • #77
Another note about this is BWRs usually inject hydrogen into their water to help protect the core and vessel from oxidation. This has some unpleasant side effects like increased radiation rates, fouling of venturis and instrument lines, and plating out of materials (could be good or bad), but is all in all beneficial for the plant as it prevents certain types of stress corrosion cracking.
  • #78
So...you guys think that a convective loop could be constructed that could deal with a recently shut down or scrammed reactor or do you know of a reactor design of similar power to current reactors that could be shut down and not need continuous power to run cooling pumps?
  • #79
That design gets pretty close:
http://www.rosatom.ru/wps/wcm/connect/spb_aep/site/resources/f3b59380478326aaa785ef9e1277e356/AES-2006_2011_EN_site.pdf [Broken]
  • #80
The GE ESBWR is a boiling water reactor that operates by natural convection. The emergency core cooling system is a huge gravity-fed water tank that can keep the core cool with no offsite power or operator intervention for 3 days, after which it only requires replacing the water inventory at atmospheric pressure.
  • #81
Really glad to see that there are designs that won't "go up" from loss of electrical power or fuel to run diesel generators and pumps.
  • #82
I see some mention about cooldown limits of the RCS, which brings up a question.
I take it that when ALL power is lost (normal and Emerg.), the steam/turbine driven AFW pumps are used to deliver AFW to the S/G, and the RCS will be cooled in order to let borated water be injected from the refueling water storage tank (or VCT?), but the concern of RCS cooldown is brittle fracture, so that's why it is stopped at a certain point. Brittle fracture wasnt mentioned in this thread so I was wondering if this was true. I read about it in the Westinghouse Technology Systems Manual (Section 3.2).
Also, in terms of a tube rupture, when the RCS is cooling, I imagine that the cooldown is useful to allow the RCS to de-pressurize (in order to help prevent further coolant leakage).. Is this correct?
edit: This is in reference to PWRs
  • #83
In a BWR, any small leaks are, for the most part, caught and decayed in the condenser off-gas system.
If there is an increase in rad-levels in the offgas system, then the system will isolate and an alarm will go off. chemistry will perform sampling to confirm a fuel leak based on iodine/xenon ratios. Based on how bad the leak is, there is a criteria for what is allowable. If you do not exceed that, then operations will perform "Power Suppression Testing". For small leaks in a BWR, if you insert control rods near the fuel bundle, the reduction in fuel rod pressure/temperature will almost completely stop the fuel leak. If the location can be confirmed during testing, AND if the leak rate decreases back below the 'normal' limits, then that fuel cell, and the cells directly adjacent to it, will have their control rods inserted to suppress those cells and stop the leak. Operation can be continued through the end of the next operating cycle, however a single leaker tends to reduce cycle length by up to 10% or so (Obviously, the later you are in the cycle, the less of an impact there will be. leakers tend to happen during the first startup and preconditioning following a refuel).
At the next refuel cycle, the leakers will be confirmed by siping. The individual rods may be sent back to the fuel vendor for analysis. Leakers really suck, because now you have to deal with iodine in your systems, which makes a whole new set of radiation concerns whenever you have to breach a potentially contaminated system. Dose rates all over the plant shoot up, and areas that normally aren't rad or high rad areas will become high rad areas. You end up spending a lot of time during the next outage flushing pipes and installing shielding just to get dose rates in general areas down. It's sucky.
PWRs cannot operate with these types of leakers. If the leak rates are too bad, they cannot simply drop in 1 control rod assembly, as they will get flux tilt in excess of allowable limits. PWRs need to come offline for bundle replacement.
  • #84
PWR's do not go offline to replace leakers, they continue normal operation (unless the RCS activity levels go beyond allowable limits, which I've personally never heard of happening). Leakers usually show up after coming back online from a trip in the middle of the cycle. Most contamination is filtered out, but the primary systems will be more radioactive during the next outage. After the cycle is complete, we use sipping to identify the leaker. Typically they occur in the final fuel cycle for the assembly, in which case nothing special is done. If the leaker occurs in a 2nd cycle assembly, a replacement with equivalent burnup from the fuel pool is used. In the less likely event a 1st cycle assembly has failed, the assembly is reconstituted by replacing the leaking rod with a stainless steel filler rod.
Note that PWRs can operate with a dropped rod, depending on the specifics of the unit. I remember some years ago we redid our safety analysis to allow the unit to continue to end of cycle with a dropped rod late in the cycle - it was doable because late in the cycle peaking factors are low enough and rod worth high enough to meet all safety parameters. However you are correct that PWR's do not intentionally insert a single rod for any purpose :shy:
  • #85
Ok makes sense.
One of our PWRs had a leaker and came off about 5 years ago. But obviously not every leak is the same, and PWRs have a lot of variation.
As for drop rod, the same PWR in my company only allows a rod drop for a few hours, and if it can't be fixed, they need to trip.
  • #86
Hiddencamper said:
Ok makes sense.
Yes that's the tech specs but it is possible to re-do the safety analysis to accommodate the dropped rod to resume operation with it still stuck in without having to go into refueling.
  • #87
Thanks, very informative!
Are you saying BWR plant personnel can remove a spent fuel assembly and remove individual rods from it?
I thought that spent fuel, especially freshly unloaded one, sits in the pool for a few years as a minimum before anything is done to it.
  • #88
A whole fuel bundle must cool for 5 years before it can be moved to dry storage. But individual rods can be shipped out for analysis as the decay heat load of a single rod is only a fraction of the total.
  • #89
nikkkom said:
...I thought that spent fuel, especially freshly unloaded one, sits in the pool for a few years as a minimum before anything is done to it.
Individual rods can be removed from the spent assemblies; the work is done with special tools while the assembly remains submerged in the pool. AFAIK, this is kind or rare for PWR fuel, but it can be done.
  • #90
Modern LWR fuel is 'reconstitutable', i.e., the upper nozzles or tie plates can be removed and the fuel rods removed, and examined. Some fuel rods are removed for various measurements.
  • #91
5 years is the requirement for long term storage/dry cask.
there are storage casks that can be used for transport/shipping. Remember a single fuel bundle or even fuel rod has drastically less heat density than a dry storage cask containing 60+ bundles. There is nothing legally that prevents casks from accepting fuel less than 5 years. The cask designer must demonstrate that the cask or container/etc is safe with the number of bundles that have been installed.
When we have failed fuel, typically we disassemble the upper tie plate and we can pull individual rods out. Each individual rod has a barcode etched in, so we record the rod numbers in that bundle, sipe the rods, look for the leaker. get video of it. We can do different ultrasonic techniques or whatever to try and measure what we can. Typically you can tell just by looking at it whether it was internal/external, and get a good idea. If more data is needed that's when you look into moving it to another facility, but in most/all cases that's all you really care about when you have a failed bundle.
Remember, all of this is done under water due to both heat and dose rates.
<h2>1. What is a "cold shutdown"?</h2><p>A cold shutdown refers to the state of a nuclear reactor when it has been completely shut down and the temperature of the reactor core has reached a low enough level to prevent any further nuclear reactions from occurring.</p><h2>2. Why would a cold shutdown not require coolant circulation?</h2><p>A cold shutdown without coolant circulation may be necessary in certain situations, such as when a reactor is being decommissioned or when there is a loss of coolant accident. In these cases, the reactor has already been shut down and the residual heat can be removed through other means, such as natural convection or heat transfer to the surrounding environment.</p><h2>3. How is a cold shutdown achieved without coolant circulation?</h2><p>A cold shutdown without coolant circulation can be achieved by using passive cooling systems, such as natural convection or heat transfer to the surrounding environment. These systems do not require any external power or pumps to operate.</p><h2>4. Is a cold shutdown without coolant circulation safe?</h2><p>Yes, a cold shutdown without coolant circulation is considered safe as long as the residual heat is effectively removed from the reactor core. This can be achieved through various passive cooling systems and is regularly practiced in nuclear power plants during maintenance or decommissioning.</p><h2>5. How long does it take to achieve a cold shutdown without coolant circulation?</h2><p>The time it takes to achieve a cold shutdown without coolant circulation can vary depending on the specific situation and the effectiveness of the passive cooling systems in place. In general, it can take several days to a week for the residual heat to be effectively removed and for the reactor to reach a stable cold shutdown state.</p>
  • Nuclear Engineering
9K
  • Thermodynamics
  • Mechanical Engineering
